SkyConnect as a router?
You can use either one of them as the co-ordinator, but you can’t have both. Only one co-ordinator allowed per network - the other can’t double as a router without re-flashing.
You can use two co-ordinators to run two separate networks, one with the ZHA integration and the other with Z2M. There can’t be any crossover between them, though.
Sounds as if you need more routers.
