Skyconnect not being detected on home assistant green
hey all I’m brand new to this and have only recently gotten a smart home green to jump in, i have also purchased a skyconnect usb and have been trying to set it up to no use, i have been doing as the instructions say and plugging the usb into the extender and that into the home assistant green but it is not discovering the device when i plug it in? wondering if anyone can help out? (as a side note i know it is connected as i stumbled into seeing it when trying to manually connect a zigbee connector but after a factory reset to make sure everything is as it should be / an attempt to get it detected automatically it refuses to automatically detect the usb device)
edit: also just wanted to throw in a second question not as important as the first but as im new to all of this I’m just wondering if this usb dongle will help connect every zigbee device i get? so i dont have to buy so many different hubs for each zigbee device (i have discovered that tp link compatibility isn’t perfect per say (some of my plugs / devices are not showing) with home assistant i believe, so am returning the smart valves i got from tp link to replace them with these zigbee valves (https://shorturl.at/tyzM7) alongside looking for new smart plugs i believe i may also go for zigbee? (perhaps these? https://shorturl.at/kyTZ6) )
thanks if anyone can help!
Around a month or so ago, a few users began reporting a similar problem and found that the batch of SkyConnects they received were not properly programmed with the correct USB identifiers, so HA didn’t recognize the devices as a SkyConnect. The SkyConnect still works, its just the HA auto-detect did not.
Here is a post of a solution:
Both ZHA and Zigbee2MQTT support a large number of different kinds of Zigbee devices, so much so that people are replacing any hubs they may have hade previously.
unfortunately there is still no auto detection nor any multi thread option in the hardware menu :frowning:
Does anyone have an update on this? I recently got a HA Green and Skyconnect. It’s a brand-new install of HA, and Skyconnect is not detected in discovered devices. The Skyconnect S/N is 242303.
Thank you so much for this, to whom ever found this out :slight_smile:
This worked as a charm! My setup is running HAOS and Proxmox and SkyConnect were there but not detected.
