Iâve been in direct contact with their product team.
Not sure how to find out but keep an eye out for the version mentioned below.
The public version is expected to be released before August 3, 2023, and the version string will start with âx060820â (x is S or G, indicating that the firmware belongs to GW-01 or GW-02, respectively).
Apologies for jumping in, but I am after a smart sprinkler (I just posted a little while ago here) and during my searching I found the Link-Tap water timers.
Has anyone had any success with pairing their Link-Tap water timers with a Home Assistant Zigbee gateway and so it becomes the part of the Home Assistant Zigbee network, or must we use the additional Link-Tap gateway?
I saw that they have the some limited data on using it with MQTT, but that seems to go via their gateway if I am not mistaken.
Yes, saw that but didnât reply as you wrote inexpensive.
There are much cheaper options out there (but I would question their reliability) - very glad I bought LinkTap.
The reason I said inexpensive because for my usecase it would be for a smallish garden and I only need it to work for a couple of weeks a year when I am on holiday.
I am sure Link-Tapâs solution is one of the better options available and it is nice that they already support Home Assistant via MQTT, but really I donât want to start spending ÂŁ100+ for this.
It is a shame they use a proprietary version of Zigbee, in summary it seems youâre forced to shell out for another piece of kit that has only one use and potentially adds more noise to what you already have. At the moment, it is the gateway that is the deal breaker for me (and the additional cost of it).
It is at times like this where I wish I knew a bit more about programming and could reverse engineer these protocols and create an emulated gateway similar to the one we have with Hue. Maybe one day
There are some bluetooth options that work with HA; so there is no requirement for an additional hub.
FWIW you could use a sonoff SV or an esp8266/32 and esphome with a cheap water solenoid. I have a couple of these I setup many years ago that are still going strong.
Sure, its not strictly wireless but in some situations that isnt necessarily required.
Has anybody else found that if it hasnât been used for a while (24 hours) and you attempt to turn it on from HA it doesnât? The switch remains ON but the Watering is Watering remains OFF.
If I switch it off and then on again it works.
Doing the same (24 hours later) from the LinkTap app works fine.
I notice something similar each day. The first âwatering startâ command gets ignored every day, then everything works as expected.
I now run a loop in the automation until the âwateringONâ notification is recieved from the linktap, but itâs so reliable that I could as well just send the first âwatering startâ twice.
Yes. That happens to me with the first start, nothing happens. I have four zones and when I run an automation to have them run in sequence, after the first false start on the first zone, they all run fine, so I am guessing it is the gateway waking up.
