the Smart Irrigation
component just looks at the location you configured in Home Assistant.
Thanks for the quick reply. I have the location in HA set correctly.
Are the attributes in the hourly adjusted run time updated based on a future forecast? We have rain coming today in about an hour. I wonder if the system is calculating the expected rain. My netto_precip is now at 0.24 and still no rain, but itās coming.
it looks at the hourly forecast on every update, so if open weather API is kind of accurate it should pick the rain up. Thatās why the docs says that open weather is not the best way to get accurate results.
Then I donāt understand what is going on with my install. The first few days it seemed to be working but now I am seeing
hourly:
daily:
rain: 0.01
snow: 0.0
precipitation: 0.01
evapotranspiration: 0.2
netto_precipitation: -0.19
water_budget: 91.06
adjusted_run_time_minutes: 59.6
water_budget: 0
bucket: 0.11
lead_time: 0
maximum_duration: -1
adjusted_run_time_minutes: 0
I expect to see some runtime in the daily.
I believe Iām having same issue with daily now being updated. Not sure what would cause that. Any info I can post that would be helpful?
I think that mine doesnāt appear to reset the daily adjusted run time to zero before adding adding the accumulated evaptransiration for the day which can result in very negative or very large bucket numbers over time.
I think there might be a setting to manually reset the bucket daily.
According to docs, When automation is called. Once it is complete it will call " ```
smart_irrigation.reset_bucket
Yeah, I think perhaps Iāve somehow deactivated that by accident somewhere.
i believe you have to have it added to your automation. It doesnt know when/how to run. its just told when
Iāve been looking at this wrong for ages⦠thanks!
Have we found a fix on why hourly wont go into daily? @jeroenterheerdt
Here is logs:
2022-06-03 12:20:00 INFO (SyncWorker_7) [custom_components.smart_irrigation.sensor] _bucket_updated, received bucket value 3.0999195809199493 from event_dict: {'event_type': 'Front_Lawn_bucketUpd', 'data': {'bucket': 3.0999195809199493}, 'origin': 'LOCAL', 'time_fired': '2022-06-03T17:20:00.864770+00:00', 'context': {'id': '01812a94c1608364cbba137b38df383e', 'parent_id': None, 'user_id': None}}
2022-06-03 12:20:00 INFO (SyncWorker_7) [custom_components.smart_irrigation.sensor] updated_adjusted_run_time_from_event called.
2022-06-03 12:20:00 INFO (SyncWorker_7) [custom_components.smart_irrigation.sensor] Calculated water_budget = 0 and adjusted_run_time: 0 for type: Daily Adjusted Run Time. Bucket value was: 3.0999195809199493, and base schedule index is: 748.0519185980178, force mode is: False, force mode duration is: 0, lead_time is: 0, maximum_duration: -1, change percentage: 1.0, type: Daily Adjusted Run Time
2022-06-03 12:20:00 INFO (SyncWorker_7) [custom_components.smart_irrigation.sensor] updated_adjusted_run_time_from_event: got result: {'wb': 0, 'art': 0}. Setting attributes of daily adjusted run time (including result['wb']) and state == result['art']
2022-06-03 12:20:00 INFO (SyncWorker_4) [custom_components.smart_irrigation.sensor] _bucket_updated, received bucket value 3.0999195809199493 from event_dict: {'event_type': 'Front_Lawn_bucketUpd', 'data': {'bucket': 3.0999195809199493}, 'origin': 'LOCAL', 'time_fired': '2022-06-03T17:20:00.864770+00:00', 'context': {'id': '01812a94c1608364cbba137b38df383e', 'parent_id': None, 'user_id': None}}
2022-06-03 12:20:00 INFO (SyncWorker_4) [custom_components.smart_irrigation.sensor] updated_adjusted_run_time_from_event called.
2022-06-03 12:20:00 INFO (SyncWorker_4) [custom_components.smart_irrigation.sensor] Calculated water_budget = 0 and adjusted_run_time: 0 for type: Daily Adjusted Run Time. Bucket value was: 3.0999195809199493, and base schedule index is: 748.0519185980178, force mode is: False, force mode duration is: 0, lead_time is: 0, maximum_duration: -1, change percentage: 1.0, type: Daily Adjusted Run Time
2022-06-03 12:20:00 INFO (SyncWorker_4) [custom_components.smart_irrigation.sensor] updated_adjusted_run_time_from_event: got result: {'wb': 0, 'art': 0}. Setting attributes of daily adjusted run time (including result['wb']) and state == result['art']
2022-06-03 12:20:00 INFO (SyncWorker_4) [custom_components.smart_irrigation.sensor] sun_rise: 2022-06-04 10:37:15.927879+00:00
2022-06-03 12:20:00 INFO (SyncWorker_4) [custom_components.smart_irrigation.sensor] Front_Lawn_start will fire at 2022-06-04 10:37:15.927879+00:00
2022-06-03 12:20:00 INFO (SyncWorker_7) [custom_components.smart_irrigation.sensor] sun_rise: 2022-06-04 10:37:15.927879+00:00
2022-06-03 12:20:00 INFO (SyncWorker_7) [custom_components.smart_irrigation.sensor] Front_Lawn_start will fire at 2022-06-04 10:37:15.927879+00:00```
Hi @jeroenterheerdt, Iām trying to update my settings and happy to delve into the configuration files but I canāt see what Iām looking to update in the device registry? I want to change the area and flow rate from what I setup. Iām happy that I can just reinstall but that seems a clunky way to achieve this.
Can you tell me what Iām looking to update in the device registry for these values? I canāt see the values I initially set.
Thanks,
James
can you do a search in the log for: āAuto refresh is enabled.ā? this should show once after a reboot. Please see if that is showing up and what time is included in the log as well. If it doesnāt show up then the auto refresh for daily never gets scheduled and we may have gotten a bug somehow. Weirdly things work fine on my end.
It appears issue is for the newer build I think .78. I will get back to you on Monday . Thanks for reply
hey, at your own risk, you can edit the files here: .storage/core.config_entries
. Just search for āareaā and you will find the componentās config values.
im having issues with the newer version.
2022-06-03 13:45:03 INFO (MainThread) [custom_components.smart_irrigation] Auto refresh is enabled. Scheduling for 0:00.
Iām still trying to fine-tune my system, Iām curious if the bucket
and the netto_precipitation
numbers are referencing actual precipitation. So, if my netto_precipitation
state is 0.25 does that mean that I got 0.25 inches of net moisture that day? Or is the netto_precipitation
number just a number and doesnāt necessarily mean thatās the amount of precipitation I received?
- The difference between
precipitation
andevapotranspiration
is thenetto precipitation
: negative values mean more moisture is lost than gets added by rain/snow, while positive values mean more moisture is added by rain/snow than what evaporates.
Yep, Iām aware of how itās calculated. Iām just wondering if the nber (ex 0.25) relates to an actual measurement, like inches.
Another way to put it, if my bucket is at -0.25 does that mean that my yard needs 0.25 inches of water? Or is the -0.25 just a number calculated by the system and not tied to any real-world measurement?
I believe that -.25 is for the bucket after update. There for depending on that number it will calculate how many seconds in needs to run to restore that amount.
The Adjusted Run Time (ART) is the number of seconds the irrigation needs to run to compensate for moisture lost that is not compensated by rain or sno
