Smart Irrigation - save water by precisely watering your lawn/garden
Thank you for all that work!
Is it possible to show the calculated values like rain and evapotranspiration that are used?
You cant see them in the UI but you can see them in the storage file. What’s the use of seeing these two things? Why not the other 10 values we take into account?
I would like to visualize the main parameters in my Lovelace layout to see how the irrigation amount is made up. That was the reason for my question. Interesting to read that many other parameters are included in the calculation.
Getting error message of OWM api not configured. But it shows setup.
one thing I did not do. and not sure where is link OWM api to smart irrigation.
“Error calculating zone Rear. You have configured forecasting but but there is no OWM API configured. Either configure the OWM API or stop using forcasting on the PyETO module.”
you can configure an OWM api by selecting ‘configure’ in the screenshot you shared. Or, if you don’t want to use OWM and forecasting, just disable it on the PyETO module.
I did configure it , I have 2 services and 27 reporting entries. So not sure what I am missing?
Can I ask you to open an issue on github? That way we can collect the required info to troubleshoot this.
Great job with V2. I like the flexibility.
Can I ask you to run your eye over my sensor definitions. I am calculating the solar radiation in the Modules page, but all other sensors are from my weather station. Following is a screenshot of the Bureau of Meteorology calculation of an ET of 4.3 but Smart Irrigation is calculating a much larger number by a factor of 10. Perhaps my sensor configuration is wrong.
Here are the actual values from my weather station.
Screenshot 2023-10-03 172117
I am getting unexpected and very strange values with v2. I follow the migration steps from the wiki.
In my v1 I had the following values, I had calculated them out based on ETO forum.
    "number_of_sprinklers": 1.0,
    "flow": 0.55,
    "area": 60.0,
    "coastal": true,
Per the wiki I multiply 1.0 x 0.55 = 0.55 and enter this for Throughput (gal/minute).
Then I enter the value 60.0 in Size (sq ft)
I enter the value -2.0 for the bucket. I click on update & then Calculate and reload the page to see the new values.
This results in a duration of 985 and a new bucket -5.7! The duration is way too short for a -5.7 or even a -2.0 bucket. Where does this massive change in bucket even come from? With V1 and the above settings I would see about 985 run time for just around a -0.15 or -0.20 bucket.
Thanks, can I please ask you to open an issue on github so we can collect the required diagnostic file? Same for @ahj391
Can you please give me a further information?
I managed to create a sensor, that reads p.e. the sum of all precipitation values from the storage file smart_irrigation.storage.
For my visualisation:
What values should I use to get the the precipitation value that is calculatet in the actual bucket?
The rest should be the evapotranspiration, right?
Hi. I am currently moving over from the homebridge plugin
to your HA plugin. As I have good experience with the calculated watering values of the homebridge plugin, I am trying to achieve the same values with your plugin. The only option for fine-tuning I can find is the Multiplier (default 1) in the zone settings. Is that correct, or is there any other option (plant density, wind exposure etc.)?
With the multiplier I have one problem: I cannot enter a decimal number (like 1,25), only integers seem to be allowed, which makes it useless for fine-tuning. Am I missing something?
I updated to 2.0 It has slowed my system to a crawl when Smart Irrigation is installed. If I delete it everything goes back to normal. Has anyone else experienced this?
you should be able to enter decimal values, have you tried using a ‘.’ instead of a ‘,’? So, try using 1.25
I have not heard about this before. Is there anything in the log?
Here is the log. It’s odd, the HA webpage gets slower the longer Smart Irrigation is installed in HA. If I close my tab then reopen HA in a new tab it’s fast again but then slowly slows down.
2023-10-07 21:02:28.573 ERROR (MainThread) [homeassistant.components.sensor] Error adding entities for domain sensor with platform smart_irrigation
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 507, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 616, in _async_add_entity
    device = dev_reg.async_get(self.hass).async_get_or_create(
  File "/usr/src/homeassistant/homeassistant/helpers/device_registry.py", line 527, in async_get_or_create
    raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Can't link device to unknown config entry 42707b4eb72ed189aaf75ff785995db1
2023-10-07 21:02:28.578 ERROR (MainThread) [homeassistant.components.sensor] Error adding entities for domain sensor with platform smart_irrigation
2023-10-07 21:02:32.286 WARNING (MainThread) [homeassistant.config_entries] Config entry '00:01:95:98:93:83' for bluetooth integration not ready yet: hci0 (00:01:95:98:93:83): Timed out starting Bluetooth after 15 seconds; Retrying in background
2023-10-07 21:02:36.322 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.office_tablet_active_notification_count exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2023-10-07 21:02:40.031 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.11/site-packages/anyio/_core/_sockets.py", line 167, in try_connect
    stream = await asynclib.connect_tcp(remote_host, remote_port, local_address)
  File "/usr/local/lib/python3.11/site-packages/anyio/_backends/_asyncio.py", line 1627, in connect_tcp
    await get_running_loop().create_connection(
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
    raise exceptions[0]
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 628, in sock_connect
    return await fut
  File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 668, in _sock_connect_cb
    raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.1.190', 80)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
    yield
  File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 114, in connect_tcp
    stream: anyio.abc.ByteStream = await anyio.connect_tcp(
  File "/usr/local/lib/python3.11/site-packages/anyio/_core/_sockets.py", line 225, in connect_tcp
    raise OSError("All connection attempts failed") from cause
OSError: All connection attempts failed
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
    yield
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 353, in handle_async_request
    resp = await self._pool.handle_async_request(req)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 262, in handle_async_request
    raise exc
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 245, in handle_async_request
    response = await connection.handle_async_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection.py", line 92, in handle_async_request
    raise exc
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection.py", line 69, in handle_async_request
    stream = await self._connect(request)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection.py", line 117, in _connect
    stream = await self._network_backend.connect_tcp(**kwargs)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/auto.py", line 31, in connect_tcp
    return await self._backend.connect_tcp(
  File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 112, in connect_tcp
    with map_exceptions(exc_map):
  File "/usr/local/lib/python3.11/contextlib.py", line 155, in __exit__
    self.gen.throw(typ, value, traceback)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
    raise to_exc(exc) from exc
httpcore.ConnectError: All connection attempts failed
  File "/usr/local/lib/python3.11/site-packages/onvif/managers.py", line 189, in _renew_or_restart_subscription
    await self._renew_subscription() or await self._restart_subscription()
  File "/usr/local/lib/python3.11/site-packages/onvif/managers.py", line 154, in _restart_subscription
    return await self._start()
  File "/usr/local/lib/python3.11/site-packages/onvif/managers.py", line 223, in _start
    result = await notify_service.Subscribe(
  File "/usr/local/lib/python3.11/site-packages/zeep/proxy.py", line 64, in __call__
    return await self._proxy._binding.send_async(
  File "/usr/local/lib/python3.11/site-packages/zeep/wsdl/bindings/soap.py", line 156, in send_async
    response = await client.transport.post_xml(
  File "/usr/local/lib/python3.11/site-packages/zeep/transports.py", line 235, in post_xml
    response = await self.post(address, message, headers)
  File "/usr/local/lib/python3.11/site-packages/zeep/transports.py", line 220, in post
    response = await self.client.post(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1848, in post
    return await self.request(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1530, in request
    return await self.send(request, auth=auth, follow_redirects=follow_redirects)
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1617, in send
    response = await self._send_handling_auth(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1645, in _send_handling_auth
    response = await self._send_handling_redirects(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1682, in _send_handling_redirects
    response = await self._send_single_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1719, in _send_single_request
    response = await transport.handle_async_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 352, in handle_async_request
    with map_httpcore_exceptions():
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
    raise mapped_exc(message) from exc
httpx.ConnectError: All connection attempts failed
2023-10-07 21:02:40.038 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
    raise exceptions[0]
    return await fut
    yield
    yield
    raise exc
    raise exc
Yes, it’s weird. I can not enter if I put in 1,25. But I found a workaround: I have to enter 125, then use left arrow ← to navigate the cursor between 1 and 2, then I can enter the decimal comma. Maybe it’s related to my browser, I am using Safari.
That is weird. Just to be sure, did you try using a dot instead of a comma?
Tried both, ‘,’ and ‘.’
as soon as I press , or . the number in the field vanishes.
This video shows me deleting the existing value 1,15 then entering 1 TAB (which works), then entering 1, (field goes empty) then entering 1. (field goes empty again) and then 115 ← <-- , which then finally works.
I am very eager to use the new version of the smart irrigation controller. However, it seems I cannot get passed the OpenWeather API part.
I enabled the key via the OpenWeather website, enabled the billing but keep on getting the message that the version or API is incorrect.
Anybody any clue?
