I can confirm the situation⦠the drainage value seems to make the ET calculation obsolete. Need some advice on how to use it.
I remember two values as good start in this thread somewhere ⦠sandy or clay soil ⦠as I cannot find the corresponding entry ⦠does anyone can repeat the figures?
According to my knowledge the soil water content is what important for grass. If excess water (like a heavy rain) occured that is where drainage comes into play. Over saturated soil will get the water drained at the rate of its specific drainage (good approx is 50 mm/h). So if you have rain (or irrigation) of 23 mm and the soil can keep approx 10 mm than the above 13 mm will get away in 13/50 hours (~15min). After this water drained away evaporation (ET) is responsible for lower rate of soil water loss influenced by the local weather conditions (wind speed, humidity, temperature). Grass is evaporating and the soil too so the overall rate is dependent on the ratio of plants covering your soil. That is a real complex calculation that has a lots of scientific papers on it. TLDR: Drainage takes away excess water, evaporation use up the water stored in the soil.
I really donāt know how Smart Irrigation calculates with drainage. This should be explained by jeroenterheerdt.
Is looks like, however that the current advise of what value to use is wrong as it diminishes the impact of the et calculation. I need to investigate it, maybe there is a bug. For now, Iād leave it empty or 0 and use it only when you have drainage issues.
I might found another bug. I selected the option of current precipitation of Sensor Groups (0. Default Sensor Group - I have only one defined) and the entered entity name disappears on page refresh (Iāve tried to tab out or click outside of the input box, too). Since than the zone irrigation times are not updated. Logs has the following:
2024-09-02 12:02:01.144 ERROR (Recorder) [homeassistant] Error doing job: Task exception was never retrieved (None)
File "/config/custom_components/smart_irrigation/__init__.py", line 841, in _async_update_all
self.store.async_update_mapping(mapping_id, changes)
File "/config/custom_components/smart_irrigation/store.py", line 690, in async_update_mapping
old.data_last_entry = dict(old.data_last_entry)
ValueError: dictionary update sequence element #0 has length 9; 2 is required
Iāve read through the docs of your project and really like it and will definately go for it once my irrigation is installed.
I do not have an irrigation system (yet), but only a lawn mower. The issue I have now is, I only want to let it mow when the grass is dry and have no clue how to determine that. So I was wondering if maybe your logic could not only apply to irrigation but also for lawn mowers to only mow when the surface of the grass is dry, by somehow calculating participation and evaporation?
Would be interisting to have your thoughts on this.
Hi there, that is an awesome idea! I am not sure how this would work, but I think you could set the throughput to zero to indicate you have no irrigation and then you could monitor the bucket to investigate if itās dry. Although, any rain might not mean itās dry and you could still see a negative bucket⦠Itās tricky.
I think quite a bunch of your logic for irrigation could be used. Unfortunately my knowledge on amending or even developing an integration is besically zero, so I can only delivery my thoughts on this
I think the precipitation would be made up from
Rain
Air Humidity (the tricky part here is to determine how much from the relative humidity sets down on the lawn in ml).
The buckt should be updated hourly as the value differences are expexted to be much higher than with soil.
I know it is trick, I am trying to find a solution how to dertermine if the lawn is wet or dry for some time now, but so far I have not been able to. This also involves quite some math, obviously a sensor would be easier, but also no success so far
one thing you could potentially look at is a soil moisture sensor? those are hyper-localized, so maybe not ideal, but they would give you some idea of how wet your soil is. You put them not very deep youād be measuring the moisture in the top part of your soil and I think with some experimentation over time you could come up with values of soil moisture that you consider ādry grassā. I donāt know, just thinking out loud here.
Yeah, Iāve been trying with hooking one of these Rainsensor to an Aqara Water sensor to see if any moisture or rain accumulates on the gras surface. The issue here is that the Aqara sensor would be digged into earth which kills the Zigbee signal and the Rainsensor would need to lay on top (or close to) the surface of the grass and would get killed when the mower goes over it. I havenāt found a good Wifi solution that is battery powered (no wires around) to overcome the issue with the sending part of the sensor being slightly burried.
So it is not about knowing the soil moisture but the surface moisture. It could for example be the case that the soil is dry (no rain for days) but the surface is wet (morning dew).
I noticed that, a few updates ago, you changed the unit of measure for ācurrent precipitationā to mm/h. However, it seems you also updated the unit for āprecipitation.ā Since precipitation is a cumulative value, shouldnāt it be measured in mm rather than mm/h?
@jeroenterheerdt great work. I took your advice from the Github and adjusted the drain rate. This parameter didnāt work as I expected, but I have the system working. It appears to be functioning properly. I am watching with soil sensors to get a good baseline. Currently I am triggering off of bucket value less than -.7. All is well. I do have a question. Since Im in Florida I may not see rain here for a couple months I cant confirm this without messing up the system. Iām assuming if it rains .3 during the day the next time the system revaluates for the day the value will adjust back to -.4 or something close. This is how understand it should work. Im running 18 zones so this is a fairly large project. I started out just trying to save a little water and electric. It looks like it is going to be a significant savings.
Small note to improve the āhow it worksā docs: The English translation from ānettoā is ānettā, as in ānett precipitationā, says the Cambridge dictionary.
Also, it seems the link(s) to the examples is not functional.
Great work, this Smart Irrigation
Have you thought about using the dewpoint. Itās perhaps not a waterproof method (pun intended), but it can give you a good approximation of when dew will form and your lawn wet. It is the temperature for a given humidity at which the air will be oversaturated and it will precipitate out. Forming mist and/ or dewdrops. I canāt properly explain it so I would definitely check out the formula/ calculations.
Hey, yeah. I tested a few ātheoreticalā methods but surprisingly all of them have failed in more than 80% of the days.
Also tried with a water leak sensor but that hat too many contacts (grass) closing the circuit and leading to false positives.
Hello everyone,
Would it be possible to adjust the throughput value via an automation?
Iām building an irrigation control unit using an ESP32 with ESPHome and a flow sensor. Iāve created a sensor that tracks the average flow rate during irrigation. Iād like to set up an automation that updates the throughput value for the respective zone based on this average, effectively fine-tuning the system for the next activation.
Can you please advise what I am doing wrong. I installed the addon few months ago I never get any calculated value in seconds. I notice the evaporation is always 0 and my buckets calculated always >0.
I am struggling with understanding:
Why I cannot change the Evapotranspiration source. I have a sensor group that is based on my garden Meteo station sensors(the station sensor entities work and have regularly changed values), so I tried to set the Evapotranspiration to none (to get the calculated values ). But when I chose either none or Static, when I come back it is re-set to Sensor with no value. I do not have a sensor for it⦠Is this a bug and this is the reason the evaporation is calculate d always 0?
Second I struggle to understand the formula in Zone info :āNew Bucket value is [old_bucket]+ delta=0.3+0.0.-10=0.3ā
From mathematical point of view makes no sense. It should be negative not 0.3
