Smart lawn watering - searching for smart irrigation valves connected to HA
What detail do you need? It’s really easy and you can make use of a lot’s of components (maybe already in your drawer :card_file_box:?)
  • esp82xx, esp32 or a raspberry pi pico for the :brain: of operation
  • 12V DC PSU (or something else :zap:)
  • Valves, for example 12V DC (or again, something else :potable_water:)
  • Some flow meter if you wanna know the amount of water (specially useful if you have alternating pressure on the system - for example because of using a tank which stores rainwater :sweat_drops:)
  • some relays (which fit your valves, typically all AC/DC ones will do or maybe some solid state ones :control_knobs:)
  • DC-DC buck converter to power the esp/pipico from your PSU :tada:
Well, that was easy an cheap. I just upcycled :recycle: :do_not_litter: some pastic container (~5L) for that task and installed is as a cover like seen in the picture :point_down:
works :tm: since ages :raised_hands:
