I finally got MQTT Bridge working. It seems the issue was that the Docker container does not accept an alternate port. I tried using first settings,but once I used second container and config options below, I started getting MQTT data from Smartthings.
-p 8001:8001
and
port=8001
-p 8001:8080
and
port=8080
I uncommented the default configurations in the config file and tried sending return messages, however Smartthings does not respond.
2019-01-28T01:57:35.799Z - info: Incoming message from SmartThings: smartthings/Dining Room Light/switch/state = on
2019-01-28T01:57:35.896Z - info: Incoming message from SmartThings: smartthings/Dining Room Light/level/state = 34
2019-01-28T01:58:21.210Z - info: Incoming message from MQTT: smartthings/Dining Room Light/switch/set_state = off
2019-01-28T01:59:03.964Z - info: Incoming message from MQTT: smartthings/Dining Room Light/switch/cmd = off
Smartthings Live Log:
[ba8bf222-ca3a-457c-8534-00df90d27f9f](https://graph-na04-useast2.api.smartthings.com/ide/logs#ba8bf222-ca3a-457c-8534-00df90d27f9f) 9:22:12 PM: error received a request with an unknown path: POST / HTTP/1.1
host: 192.168.86.43:39500
accept: application/json
content-type: application/json
content-length: 74
Connection: close
[ba8bf222-ca3a-457c-8534-00df90d27f9f](https://graph-na04-useast2.api.smartthings.com/ide/logs#ba8bf222-ca3a-457c-8534-00df90d27f9f) 9:22:12 PM: debug Msg '[index:10, mac:00012E6C42E0, headers:[content-length:74, connection:close, host:192.168.86.43:39500, content-type:application/json, accept:application/json, post / http/1.1:null], body:{"name":"Dining Room Light","type":"switch","value":"off","command":false}, header:POST / HTTP/1.1
content-length: 74
Connection: close, data:[command:false, name:Dining Room Light, type:switch, value:off], json:[command:false, name:Dining Room Light, type:switch, value:off]]'
[ba8bf222-ca3a-457c-8534-00df90d27f9f](https://graph-na04-useast2.api.smartthings.com/ide/logs#ba8bf222-ca3a-457c-8534-00df90d27f9f) 9:20:52 PM: error received a request with an unknown path: POST / HTTP/1.1
content-length: 73
Connection: close
[ba8bf222-ca3a-457c-8534-00df90d27f9f](https://graph-na04-useast2.api.smartthings.com/ide/logs#ba8bf222-ca3a-457c-8534-00df90d27f9f) 9:20:52 PM: debug Msg '[index:0E, mac:00012E6C42E0, headers:[content-length:73, connection:close, host:192.168.86.43:39500, content-type:application/json, accept:application/json, post / http/1.1:null], body:{"name":"Dining Room Light","type":"switch","value":"off","command":true}, header:POST / HTTP/1.1
content-length: 73
Connection: close, data:[command:true, name:Dining Room Light, type:switch, value:off], json:[command:true, name:Dining Room Light, type:switch, value:off]]'
