I thought i’d just quickly add the device, and see if it worked with a different device and JSUI a good few months after i first saw it happen. Was quick to include manually once i stopped smartstart.
After the 4th node creation I just stopped it.
One things for sure, it did it both on the official add on and JSUI, so neither one are specifically responsible.
The logs are below, right from adding the provisioning, through to subsequent re-interview/inclusions
Excuse the other data in the stream from other nodes (i.e. not node 120-124). I couldn’t add the whole log as its over the character limit, but it just repeats.
2023-09-30T23:22:30.616Z CNTRLR Enabling Smart Start listening mode...
2023-09-30T23:22:30.649Z CNTRLR Smart Start listening mode enabled
2023-09-30T23:22:48.455Z CNTRLR Received Smart Start inclusion request
2023-09-30T23:22:48.456Z CNTRLR NWI Home ID found in provisioning list, including node...
2023-09-30T23:22:48.457Z CNTRLR Including SmartStart node with DSK 33793-35377-14396-01032-04544-01096-02048-0
0532
2023-09-30T23:22:48.476Z CNTRLR handling add node request (status = Ready)
2023-09-30T23:22:52.558Z CNTRLR handling add node request (status = NodeFound)
2023-09-30T23:22:52.864Z CNTRLR handling add node request (status = AddingSlave)
2023-09-30T23:24:32.290Z CNTRLR handling add node request (status = ProtocolDone)
2023-09-30T23:24:32.293Z CNTRLR finishing inclusion process...
2023-09-30T23:24:32.406Z CNTRLR The inclusion process was stopped
2023-09-30T23:24:32.420Z CNTRLR finished adding node 120:
basic device class: Routing Slave
generic device class: Repeater Slave
specific device class: Repeater Slave
supported CCs:
· Basic (0x20)
· Z-Wave Plus Info (0x5e)
· Association (0x85)
· Multi Channel Association (0x8e)
· Association Group Information (0x59)
· Transport Service (0x55)
· Version (0x86)
· Manufacturer Specific (0x72)
· Device Reset Locally (0x5a)
· Indicator (0x87)
· Powerlevel (0x73)
· Security 2 (0x9f)
· Supervision (0x6c)
· Firmware Update Meta Data (0x7a)
controlled CCs:
2023-09-30T23:24:32.423Z CNTRLR » [Node 120] Assigning SUC return route...
2023-09-30T23:24:32.423Z CNTRLR » [Node 120] Deleting SUC return route...
2023-09-30T23:24:35.149Z CNTRLR [Node 120] The node did not respond after 3 attempts, it is presumed dead
2023-09-30T23:24:35.151Z CNTRLR [Node 120] Security S2 bootstrapping failed, the node was not granted any S2 s
ecurity class: The node did not acknowledge the command (ZW0204)
2023-09-30T23:24:35.153Z CNTRLR Enabling Smart Start listening mode...
2023-09-30T23:24:35.156Z CNTRLR [Node 120] Beginning interview - last completed stage: None
2023-09-30T23:24:35.157Z CNTRLR [Node 120] new node, doing a full interview...
2023-09-30T23:24:35.157Z CNTRLR » [Node 120] querying protocol info...
2023-09-30T23:24:35.190Z CNTRLR Smart Start listening mode enabled
2023-09-30T23:24:35.204Z CNTRLR « [Node 120] received response for protocol info:
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2023-09-30T23:24:35.211Z CNTRLR [Node 120] Interview stage completed: ProtocolInfo
2023-09-30T23:24:35.212Z CNTRLR » [Node 120] pinging the node...
2023-09-30T23:24:37.209Z CNTRLR [Node 120] The node did not respond after 1 attempts, it is presumed dead
2023-09-30T23:24:37.210Z CNTRLR [Node 120] ping failed: The node did not acknowledge the command (ZW0204)
2023-09-30T23:24:37.211Z CNTRLR » [Node 120] querying node info...
2023-09-30T23:24:37.212Z CNTRLR » [Node 120] pinging the node...
2023-09-30T23:24:37.836Z CNTRLR [Node 120] The node did not respond after 1 attempts, it is presumed dead
2023-09-30T23:24:37.838Z CNTRLR [Node 120] ping failed: The node did not acknowledge the command (ZW0204)
2023-09-30T23:24:37.839Z CNTRLR [Node 120] Interview attempt (1/5) failed, node is dead.
2023-09-30T23:24:42.758Z CNTRLR Received Smart Start inclusion request
2023-09-30T23:24:42.759Z CNTRLR NWI Home ID found in provisioning list, including node...
2023-09-30T23:24:42.759Z CNTRLR Including SmartStart node with DSK 33793-35377-14396-01032-04544-01096-02048-0
0532
2023-09-30T23:24:42.773Z CNTRLR handling add node request (status = Ready)
2023-09-30T23:24:46.862Z CNTRLR handling add node request (status = NodeFound)
2023-09-30T23:24:47.172Z CNTRLR handling add node request (status = AddingSlave)
2023-09-30T23:24:47.187Z CNTRLR Node 121 was included by another controller:
supported CCs:
· Version (0x86)
· Indicator (0x87)
· Powerlevel (0x73)
· Security 2 (0x9f)
2023-09-30T23:24:47.187Z CNTRLR [Node 121] Waiting for initiate command to bootstrap node...
2023-09-30T23:24:47.361Z CNTRLR Node 121 was (supposedly) included by another controller, but it is already pa
rt of the network. Ignoring the message...
2023-09-30T23:24:49.250Z CNTRLR Node 121 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:24:57.192Z CNTRLR [Node 121] no initiate command received, bootstrapping node...
2023-09-30T23:24:57.192Z CNTRLR » [Node 121] Assigning SUC return route...
2023-09-30T23:24:57.193Z CNTRLR » [Node 121] Deleting SUC return route...
2023-09-30T23:25:09.486Z CNTRLR [Node 121] Timed out while waiting for a response from the node (ZW0201)
2023-09-30T23:25:09.487Z CNTRLR [Node 121] Security S2 bootstrapping failed: did not receive the node's desire
d security classes.
2023-09-30T23:25:09.488Z CNTRLR Enabling Smart Start listening mode...
2023-09-30T23:25:09.491Z CNTRLR [Node 121] Beginning interview - last completed stage: None
2023-09-30T23:25:09.492Z CNTRLR [Node 121] new node, doing a full interview...
2023-09-30T23:25:09.492Z CNTRLR » [Node 121] querying protocol info...
2023-09-30T23:25:09.510Z CNTRLR Smart Start listening mode enabled
2023-09-30T23:25:10.518Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:25:11.622Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:25:13.728Z CNTRLR [Node 121] Error during node interview: Timeout while waiting for an ACK from
the controller (ZW0200)
2023-09-30T23:25:19.735Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:25:20.839Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:25:49.734Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:25:50.838Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:25:56.863Z CNTRLR handling add node request (status = ProtocolDone)
2023-09-30T23:25:56.863Z CNTRLR inclusion is NOT active, ignoring it...
2023-09-30T23:25:59.078Z CNTRLR Received Smart Start inclusion request
2023-09-30T23:25:59.081Z CNTRLR NWI Home ID found in provisioning list, including node...
2023-09-30T23:25:59.081Z CNTRLR Including SmartStart node with DSK 33793-35377-14396-01032-04544-01096-02048-0
0532
2023-09-30T23:25:59.106Z CNTRLR handling add node request (status = Ready)
2023-09-30T23:26:03.178Z CNTRLR handling add node request (status = NodeFound)
2023-09-30T23:26:03.425Z CNTRLR » [Node 056] Meter CC values may be stale, refreshing...
2023-09-30T23:26:03.426Z CNTRLR » [Node 056] querying meter value (type = Electric, scale = kWh)...
2023-09-30T23:26:03.493Z CNTRLR handling add node request (status = AddingSlave)
2023-09-30T23:26:03.503Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:26:03.515Z CNTRLR Node 122 was included by another controller:
supported CCs:
· Version (0x86)
· Indicator (0x87)
· Powerlevel (0x73)
· Security 2 (0x9f)
2023-09-30T23:26:03.515Z CNTRLR [Node 122] Waiting for initiate command to bootstrap node...
2023-09-30T23:26:03.686Z CNTRLR Node 122 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:26:03.689Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:26:05.763Z CNTRLR Node 122 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:26:06.284Z CNTRLR [Node 056] Timed out while waiting for a response from the node (ZW0201)
2023-09-30T23:26:06.285Z CNTRLR » [Node 056] querying meter value (type = Electric, scale = W)...
2023-09-30T23:26:13.519Z CNTRLR [Node 122] no initiate command received, bootstrapping node...
2023-09-30T23:26:13.520Z CNTRLR » [Node 122] Assigning SUC return route...
2023-09-30T23:26:13.520Z CNTRLR » [Node 122] Deleting SUC return route...
2023-09-30T23:26:45.714Z CNTRLR [Node 056] The node did not respond after 3 attempts, it is presumed dead
2023-09-30T23:26:45.731Z CNTRLR [Node 056] The node is now dead.
2023-09-30T23:26:45.737Z CNTRLR [Node 056] failed to refresh values for Meter CC: The node did not acknowledge
2023-09-30T23:26:45.793Z CNTRLR » [Node 056] Multilevel Sensor CC values may be stale, refreshing.. [Endpoint 7]
2023-09-30T23:26:45.800Z CNTRLR » [Node 056] querying Voltage sensor reading... [Endpoint 7]
2023-09-30T23:26:45.805Z CNTRLR [Node 056] No scale preference for sensor type 15, using the last [Endpoint 7]
-used scale 0
2023-09-30T23:26:45.807Z CNTRLR » [Node 056] pinging the node...
2023-09-30T23:26:59.417Z CNTRLR [Node 056] The node did not respond after 1 attempts, it is presumed dead
2023-09-30T23:26:59.419Z CNTRLR [Node 056] ping failed: The node did not acknowledge the command (ZW0204)
2023-09-30T23:26:59.422Z CNTRLR [Node 056] failed to refresh values for Multilevel Sensor CC: The [Endpoint 7]
message cannot be sent because node 56 is dead (ZW0202)
2023-09-30T23:27:10.601Z CNTRLR [Node 122] Timed out while waiting for a response from the node (ZW0201)
2023-09-30T23:27:10.602Z CNTRLR [Node 122] Security S2 bootstrapping failed: did not receive the node's desire
d security classes.
2023-09-30T23:27:10.603Z CNTRLR Enabling Smart Start listening mode...
2023-09-30T23:27:10.605Z CNTRLR [Node 122] Beginning interview - last completed stage: None
2023-09-30T23:27:10.605Z CNTRLR [Node 122] new node, doing a full interview...
2023-09-30T23:27:10.605Z CNTRLR » [Node 122] querying protocol info...
2023-09-30T23:27:10.628Z CNTRLR Smart Start listening mode enabled
2023-09-30T23:27:11.637Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:27:12.740Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:27:14.844Z CNTRLR [Node 122] Error during node interview: Timeout while waiting for an ACK from
2023-09-30T23:27:17.857Z CNTRLR handling add node request (status = ProtocolDone)
2023-09-30T23:27:17.858Z CNTRLR inclusion is NOT active, ignoring it...
2023-09-30T23:27:19.221Z DRIVER Dropping message because it could not be deserialized: The command class Appli
cation Status is not implemented (ZW0303)
2023-09-30T23:27:58.215Z CNTRLR [Node 068] Timed out while waiting for a response from the node (ZW0201)
2023-09-30T23:30:12.763Z CNTRLR » [Node 008] Multilevel Sensor CC values may be stale, refreshing...
2023-09-30T23:30:12.764Z CNTRLR » [Node 008] querying Air temperature sensor reading...
2023-09-30T23:30:12.765Z CNTRLR [Node 008] No scale preference for sensor type 1, using the last-used scale 0
2023-09-30T23:30:13.167Z CNTRLR « [Node 008] received current Air temperature sensor reading: 12.8 °C
2023-09-30T23:30:13.193Z CNTRLR » [Node 008] Multilevel Sensor CC values may be stale, refreshing.. [Endpoint 3]
2023-09-30T23:30:13.194Z CNTRLR » [Node 008] querying Air temperature sensor reading... [Endpoint 3]
2023-09-30T23:30:13.197Z CNTRLR [Node 008] No scale preference for sensor type 1, using the last- [Endpoint 3]
used scale 0
2023-09-30T23:30:13.917Z CNTRLR « [Node 008] received current Air temperature sensor reading: 12.8 [Endpoint 3]
°C
2023-09-30T23:30:51.931Z CNTRLR [Node 056] The node is now alive.
2023-09-30T23:31:06.013Z CNTRLR Received Smart Start inclusion request
2023-09-30T23:31:06.015Z CNTRLR NWI Home ID found in provisioning list, including node...
2023-09-30T23:31:06.015Z CNTRLR Including SmartStart node with DSK 33793-35377-14396-01032-04544-01096-02048-0
0532
2023-09-30T23:31:06.027Z CNTRLR handling add node request (status = Ready)
2023-09-30T23:31:10.113Z CNTRLR handling add node request (status = NodeFound)
2023-09-30T23:31:10.431Z CNTRLR handling add node request (status = AddingSlave)
2023-09-30T23:31:10.446Z CNTRLR Node 123 was included by another controller:
supported CCs:
· Version (0x86)
· Indicator (0x87)
· Powerlevel (0x73)
· Security 2 (0x9f)
2023-09-30T23:31:10.447Z CNTRLR [Node 123] Waiting for initiate command to bootstrap node...
2023-09-30T23:31:10.618Z CNTRLR Node 123 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:31:12.708Z CNTRLR Node 123 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:31:20.457Z CNTRLR [Node 123] no initiate command received, bootstrapping node...
2023-09-30T23:31:20.458Z CNTRLR » [Node 123] Assigning SUC return route...
2023-09-30T23:31:20.458Z CNTRLR » [Node 123] Deleting SUC return route...
2023-09-30T23:31:23.993Z CNTRLR [Node 123] The node did not respond after 3 attempts, it is presumed dead
2023-09-30T23:31:23.996Z CNTRLR [Node 123] Security S2 bootstrapping failed, the node was not granted any S2 s
2023-09-30T23:31:23.997Z CNTRLR Enabling Smart Start listening mode...
2023-09-30T23:31:23.999Z CNTRLR [Node 123] Beginning interview - last completed stage: None
2023-09-30T23:31:24.000Z CNTRLR [Node 123] new node, doing a full interview...
2023-09-30T23:31:24.000Z CNTRLR » [Node 123] querying protocol info...
2023-09-30T23:31:24.015Z CNTRLR Smart Start listening mode enabled
2023-09-30T23:31:25.022Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:31:26.142Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:31:28.248Z CNTRLR [Node 123] Error during node interview: Timeout while waiting for an ACK from
2023-09-30T23:31:50.932Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:31:52.038Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:32:20.929Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:32:22.032Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:32:50.241Z CNTRLR handling add node request (status = ProtocolDone)
2023-09-30T23:32:50.242Z CNTRLR inclusion is NOT active, ignoring it...
2023-09-30T23:32:50.244Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:32:56.265Z CNTRLR Received Smart Start inclusion request
2023-09-30T23:32:56.266Z CNTRLR NWI Home ID found in provisioning list, including node...
2023-09-30T23:32:56.266Z CNTRLR Including SmartStart node with DSK 33793-35377-14396-01032-04544-01096-02048-0
0532
2023-09-30T23:32:56.275Z CNTRLR handling add node request (status = Ready)
2023-09-30T23:33:00.369Z CNTRLR handling add node request (status = NodeFound)
2023-09-30T23:33:00.692Z CNTRLR handling add node request (status = AddingSlave)
2023-09-30T23:33:00.709Z CNTRLR Node 124 was included by another controller:
supported CCs:
· Version (0x86)
· Indicator (0x87)
· Powerlevel (0x73)
· Security 2 (0x9f)
2023-09-30T23:33:00.710Z CNTRLR [Node 124] Waiting for initiate command to bootstrap node...
2023-09-30T23:33:00.929Z CNTRLR Node 124 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:33:03.118Z CNTRLR Node 124 was (supposedly) included by another controller, but it is already pa
2023-09-30T23:33:10.713Z CNTRLR [Node 124] no initiate command received, bootstrapping node...
2023-09-30T23:33:10.714Z CNTRLR » [Node 124] Assigning SUC return route...
2023-09-30T23:33:10.714Z CNTRLR » [Node 124] Deleting SUC return route...
2023-09-30T23:33:14.424Z CNTRLR [Node 124] The node did not respond after 3 attempts, it is presumed dead
2023-09-30T23:33:14.427Z CNTRLR [Node 124] Security S2 bootstrapping failed, the node was not granted any S2 s
2023-09-30T23:33:14.429Z CNTRLR Enabling Smart Start listening mode...
2023-09-30T23:33:14.432Z CNTRLR [Node 124] Beginning interview - last completed stage: None
2023-09-30T23:33:14.433Z CNTRLR [Node 124] new node, doing a full interview...
2023-09-30T23:33:14.433Z CNTRLR » [Node 124] querying protocol info...
2023-09-30T23:33:14.454Z CNTRLR Smart Start listening mode enabled
2023-09-30T23:33:15.461Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:33:16.570Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:33:18.674Z CNTRLR [Node 124] Error during node interview: Timeout while waiting for an ACK from
2023-09-30T23:33:20.415Z CNTRLR disabling Smart Start listening mode...
2023-09-30T23:33:21.424Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:33:22.528Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:33:24.635Z CNTRLR Smart Start listening mode could not be disabled: Timeout while waiting for an
ACK from the controller (ZW0200)
2023-09-30T23:33:30.643Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:33:31.746Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:34:00.644Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:34:01.751Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:34:02.941Z CNTRLR » [Node 120] pinging the node...
2023-09-30T23:34:04.858Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:34:05.961Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:34:08.069Z CNTRLR [Node 120] ping failed: Timeout while waiting for an ACK from the controller (
ZW0200)
2023-09-30T23:34:09.085Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:34:10.188Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:34:26.338Z CNTRLR » [Node 120] pinging the node...
2023-09-30T23:34:27.344Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:34:28.449Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:34:30.552Z CNTRLR [Node 120] ping failed: Timeout while waiting for an ACK from the controller (
ZW0200)
2023-09-30T23:34:31.559Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-09-30T23:34:32.665Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-09-30T23:34:40.665Z CNTRLR handling add node request (status = ProtocolDone)
2023-09-30T23:34:40.665Z CNTRLR inclusion is NOT active, ignoring it...
2023-09-30T23:34:40.667Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
