Thanks @briss this is fantastic!
Hey fellas!
Really enjoying the component so far - had an issue crop up through where all of a sudden after working fine, a restart has the smartweather component failing with the following log popping up in Hass:
019-05-13 19:38:56 ERROR (MainThread) [homeassistant.setup] Error during setup of component smartweather
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/config/custom_components/smartweather/__init__.py", line 94, in setup
data.update()
File "/usr/local/lib/python3.7/site-packages/homeassistant/util/__init__.py", line 224, in wrapper
result = method(*args, **kwargs)
File "/config/custom_components/smartweather/__init__.py", line 121, in update
self.data = weather.currentdata()
File "/config/deps/lib/python3.7/site-packages/pysmartweatherio/models.py", line 25, in currentdata
dtformat = datetime.datetime.fromtimestamp(self.json['obs'][0]['timestamp']).strftime('%Y-%m-%d %H:%M:%S')
IndexError: list index out of range
Has anyone seen this before, have already checked to make sure the files are up to date, but no luck there.
UPDATE: Turns out the station I was using was no longer available (no recent observation) - switching to an alternate corrected the problem!
This is a great component but today I have some weirdness.
About an hour ago I stopped getting any light based info. Other monitored conditions still work so the station is still on line and looking on the website the figures I want are still being measured.
Any idea what is going on?
I’ve done all the usual checks like restart HA and there is no mention of Smartweather in my logs.
#=== Smart Weather sensors
- platform: smartweather
monitored_conditions:
- temperature
# - feels_like_temperature
# - heat_index
# - wind_chill
# - dewpoint
# - wind_speed
# - wind_gust
# - wind_bearing
# - wind_direction
- precipitation
- precipitation_rate
- precipitation_last_1hr
- precipitation_last_24hr
- precipitation_yesterday
# - humidity
# - pressure
- uv
- solar_radiation
- illuminance
scan_interval:
minutes: 10
From the Smart Weather website:
Showing when it stopped working.
HA dev tools
On vacation right now. Will look at when I am back in a week
That seems like a reasonable excuse
Thanks and have a great time!
Sorry for the long delay. I moved house when getting back from vacation, so the delay was a bit a longer:grinning: Do you still have the problem? If yes, what is the Station ID you are using?
Thanks but no I don’t, strangely enough it came back all by itself a couple of days ago.
Very strange.
I’ll let you know if it happens again.
briis, I had an error occur today - no changes on my end to HA. Here are the logs:
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 156, in _async_setup_component
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/homeassistant/.homeassistant/custom_components/smartweather/__init__.py", line 94, in setup
data.update()
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/__init__.py", line 224, in wrapper
File "/home/homeassistant/.homeassistant/custom_components/smartweather/__init__.py", line 121, in update
File "/srv/homeassistant/lib/python3.5/site-packages/pysmartweatherio/models.py", line 61, in currentdata
Conversion.volume(float(self.json['obs'][0]['precip_accum_last_24hr']), self.units),
KeyError: 'precip_accum_last_24hr'
I haven’t investigated much, but this is probably the kick I need to finally move over to your other plugin which avoids the cloud altogether - although this error means the Darksky forceasting component is also broken. But anyway, would it have anything to do with this?
I just found that out also. I am working on an update to remove the precip_accum_last_24hr from the calls as a quick fix. I will add the new values as soon as possible.
Cheers mate!
The problem should now be fixed, and a new version is available on Github. A breaking change is that the sensor precipitation_24_hr does no longer exist.
I also made some changes on how Custom_Updater is working, so that you will only have 1 entry in the Tracker Card going forward. So if Custom_Updater does nor work, please delete all files in the SmartWeather folder and re-download from Github.
Thanks Bjarne, all working again - this is a great component.
Hi
I am trying to use this component without a ‘Smart Weather Station’, I only want to use:
weather:
api_key:
Any idea or suggestion to check for this error in HASSIO?
from log: 2019-08-14 16:00:23 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform smartweather.weather: Unable to set up component.
Invalid config
The following components and platforms could not be set up:
- smartweather
- smartweather.weather
Please check your config.
my configuration.YAML
weather:
api_key: MYKEY
mode: daily
In order to use this component you MUST apply a station_id, as described in the documentation.
[https://github.com/briis/smartweather]
smartweather:
station_id: <your station id>
api_key: <Your WeatherFlow API Key>
Hi
I got both APY key, one for smartweather and another for DarkSKY.
For smartweather I got the correct data…
temperature: 25.7
humidity: 94
dewpoint: 24.7
feels_like: 25.7
ozone: 287.1
precipitation: 0.0
precipitation_rate: 0.0
pressure: 1011.7
wind_bearing: 74
wind_speed: 0
wind_gust: 1.4
wind_lull: 0
visibility: 15.524
attribution: Powered by Dark Sky and SmartWeather Weather Station
but for DarkSky data I am not able to get, I only optain:
forecast: [object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]
friendly_name: smartweather
So you get all the data - great - Sorry then I misunderstood your question.
What you are getting back in the forecast attribute, is a data array, and this will only work with the standard Lovelace Weather Card or one of the many Custom Weather Cards you can find in this forum.
Thanks buddy, let me check
How can I install this using HACS?? I keep getting : briis/smartweather/ is not a valid format. Correct format is ‘https://github.com/DEVELOPER/REPOSITORY’ or ‘DEVELOPER/REPOSITORY’.
I have tried to follow the instructions on the HACS developer site, but I get the same result as you. So currently I don’t have a solution. When I have time I will look in to this again.
Since my upgrade today to 102.2, SmartWeather isn’t working any more.
Following errors in the log :
2019-11-27 12:54:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component smartweather
File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
component.setup, hass, processed_config # type: ignore
data.update()
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 240, in wrapper
File "/usr/local/lib/python3.7/site-packages/pysmartweatherio/models.py", line 44, in currentdata
feels_like = self.json['obs'][0]['feels_like']
KeyError: 'feels_like'
2019-11-27 12:54:13 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform smartweather.weather: Unable to set up component.
2019-11-27 12:54:13 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform smartweather.binary_sensor: Unable to set up component.
2019-11-27 12:54:13 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 5.3 seconds.
What can be wrong ? Config unchanged.
