Could you share your config? I’m trying to get my G3 to work and there is not much data about that to work with.
Have you managed to create full config file for ESPhome? Would be really great if i could save some time porting it for G3 by myself
I would need help. In the case of “8.8 KTLX-3”, where should the TTL converter be connected?
I tried it on “Electric meter RS485A” and “Electric meter RS485B” but without success.
Where should it be plugged in? It doesn’t have an RJ45 shape for me.
I will add a picture from the manual.
Thanks for help
Thomas
Or 7 and 12 ports should I use?
7 to the negative and 12 to the positive?
Just so you know I have started to add in support for Sofar Solar on my SolaX custom_component SolaX Inverter by Modbus (No Pocket WiFi) ( now a custom_component ) if you fancy Beta testing give it ago and let me know. (It will probably fail on the serial number check (only checks first couple of digits to determine model) but that can be easily fixed once we know what it is)
Did you get connected?
I don’t own a Sofar but looking at that Diagram you want Pins 1&3 or 2&4 You might need to connect Ground as well Pin7 but on SolaX Inverters that’s normally not required.
witam .
do sofara udało mi się wyciągnąć adresy i mam nadzieję że wszystkie są poprawne poniżej podaję kod z mojego home-esp
substitutions:
devicename: sofarsolar-logger
friendly_name: SofarSolar
hostname: "esp8266-sofar"
comment: "SofarSolar modbus interface"
icon: "mdi:solar-power-variant-outline"
restore_mode: "restore_default_off"
wifi:
ssid: "1231233123"
password: "22222222222222222222"
fast_connect: true
reboot_timeout: 120s
power_save_mode: none
ap:
ssid: "Fallback-AP-${devicename}"
password: ""
ap_timeout: 300s
api:
password: "TbkEdpMbU5555555552"
ota:
password: "TbkEdpMbU55555552"
safe_mode: False
captive_portal:
#mdns:
# disabled: True
#web_server:
# port: 80
# ota: false
esphome:
platform: ESP8266
# board: esp01_1m
board: d1_mini
board_flash_mode: dout
comment: SofarSolar Logger (Modbus/RS485)
#esp8266:
# board: d1_mini
logger:
# level: INFO
# baud_rate: 0
status_led:
pin:
number: GPIO2
inverted: true
external_components:
- source:
type: git
url: https://github.com/ssieb/custom_components
components: [ heapmon ]
#uart:
# id: mod_bus
# tx_pin: 1
# rx_pin: 3 # to piny używane do wgrywania i raportu
# baud_rate: 9600
# stop_bits: 1
uart:
rx_pin: D1
tx_pin: D2
baud_rate: 9600
#baud_rate: 38400
# baud_rate: 19200 #9600
stop_bits: 1
debug:
modbus:
modbus_controller:
- id: sofarsolar
address: 0x01
modbus_id: mod_bus_sofar
update_interval: 5s
text_sensor:
name: "ESP-Sofar Uptime (human readable)"
icon: "mdi:clock-start"
update_interval: 5s
- platform: modbus_controller
modbus_controller_id: sofarsolar
register_type: holding
icon: "mdi:information-outline"
address: 0x0404
response_size: 2
lambda: |-
auto z = "Unknown";
char d = data[item->offset+1];
if (d == 0) z = "Czeka";
else if (d == 1) z = "Check";
else if (d == 2) z = "Produkuje";
else if (d == 3) z = "Fault";
else if (d == 4) z = "Permanent";
else if (d == 5) z = "główny błąd";
else if (d == 6) z = "szejść";
else if (d == 7) z = "siedem";
return {z};
- platform: wifi_signal
name: "ESP-Sofar WiFi Signal"
update_interval: 60s
icon: "mdi:wifi"
- platform: uptime
filters:
- lambda: return x / 60.0;
unit_of_measurement: minutes
- platform: heapmon
name: "ESP-Sofar Heapsize"
icon: "mdi:memory"
update_interval: 5s
name: ${friendly_name} DC1 Voltage
# address: 0x0006
address: 0x0584
unit_of_measurement: "V"
state_class: "measurement"
device_class: "voltage"
icon: "mdi:alpha-v-circle-outline"
value_type: U_WORD
accuracy_decimals: 1
filters:
- multiply: 0.1
name: ${friendly_name} DC1 Current
# address: 0x0007
address: 0x0585
unit_of_measurement: "A"
device_class: "current"
icon: "mdi:alpha-a-circle-outline"
value_type: U_WORD
accuracy_decimals: 2
filters:
- multiply: 0.01
name: ${friendly_name} DC2 Voltage
#address: 0x0008
address: 0x0587
value_type: U_WORD
filters:
- multiply: 0.1
name: ${friendly_name} DC2 Current
# address: 0x0009
address: 0x0588
value_type: U_WORD
filters:
- multiply: 0.01
name: ${friendly_name} DC1 Power
# address: 0x000a
address: 0x0586
unit_of_measurement: "W"
device_class: "power"
icon: "mdi:solar-power"
value_type: U_WORD
filters:
- multiply: 10
name: ${friendly_name} DC2 Power
# address: 0x000b
address: 0x0589
value_type: U_WORD
filters:
- multiply: 10
name: ${friendly_name} AC Power
address: 0x0485
# address: 0x0485 - niemam pewności czy to to
# address: 0x0488 # nie podaje ale wczesniej było .. ***************************************111111111111111
value_type: U_WORD
filters:
- multiply: 10
name: ${friendly_name} AC Reactive Power
address: 0x0487 ##
# address: 0x000d ##
unit_of_measurement: "kVar"
#device_class: "reactive_power"
icon: "mdi:math-cos"
value_type: S_WORD
filters:
- multiply: 10
name: ${friendly_name} AC Freq
address: 0x0484 ## jest ok.
unit_of_measurement: "Hz"
#device_class: "frequency"
icon: "mdi:current-ac"
value_type: U_WORD
filters:
- multiply: 0.01
name: ${friendly_name} L1 Voltage
## address: 0x098b
## address: 0x000f
address: 0x048D
icon: "mdi:alpha-v-circle"
value_type: U_WORD
filters:
- multiply: 0.1
name: ${friendly_name} L1 Current
# address: 0x0010
address: 0x048E
icon: "mdi:alpha-a-circle"
value_type: U_WORD
filters:
- multiply: 0.01
name: ${friendly_name} L2 Voltage
address: 0x0498
# address: 0x0011
value_type: U_WORD
filters:
- multiply: 0.1
name: ${friendly_name} L2 Current
# address: 0x0012
address: 0x0499
value_type: U_WORD
filters:
- multiply: 0.01
name: ${friendly_name} L3 Voltage
# address: 0x004BA
address: 0x04A3
# address: 0x0586 # faluje 2.1 2,2
# address: 0x0013
value_type: U_WORD
filters:
- multiply: 0.1
name: ${friendly_name} L3 Current
################ tu sprawdzam.
# address: 0x0418 # podaje o.14 - temperatura ? w aplikacji jest taka temperatura singla ambied
# address: 0x0483 # 249.59
# address: 0x0585 # podaje 0,66 to jagby jeden string ampery .
# address: 0x0587 # 38,56
# address: 0x0588 # ampery na linię pv2 dc
address: 0x04A4
value_type: U_WORD
filters:
- multiply: 0.01
name: ${friendly_name} Energia całkowita Produkcji Parking
##### address: 0x0015
address: 0x0686 # licznik całkowitej energi
unit_of_measurement: "kWh"
device_class: "energy"
state_class: "total_increasing"
value_type: U_DWORD
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.1
#unit_of_measurement: kW
name: ${friendly_name} Energy produkcja time total
address: 0x0427
# address: 0x0428
# unit_of_measurement: "h"
unit_of_measurement: "min"
icon: "mdi:timeline-clock"
value_type: U_DWORD
name: ${friendly_name} Energia dzisiaj
address: 0x0685
#address: 0x0426
value_type: U_WORD
filters:
- multiply: 0.01
name: ${friendly_name} Energy generation time today
address: 0x0426
value_type: U_WORD
name: ${friendly_name} Temprature module
# address: 0x001B
address: 0x041A
unit_of_measurement: "°C"
device_class: "temperature"
icon: "mdi:temperature-celsius"
value_type: U_WORD
name: ${friendly_name} Temprature inverter
# address: 0x001C
address: 0x0418
value_type: U_WORD
name: ${friendly_name} Bus voltage
address: 0x06CC
value_type: U_WORD
filters:
- multiply: 0.1
name: ${friendly_name} PV- isolation resistance
address: 0x042B #***************************
unit_of_measurement: "Ohm"
icon: "mdi:omega"
value_type: U_WORD
name: ${friendly_name} AC Current (total)
lambda: |-
return (id(inverter_ac_c1).state + id(inverter_ac_c2).state + id(inverter_ac_c3).state);
unit_of_measurement: A
update_interval: 5s
name: ${friendly_name} DC Current (total)
lambda: |-
return (id(inverter_dc_c1).state + id(inverter_dc_c2).state);
update_interval: 5s
name: ${friendly_name} DC Power (total)
lambda: |-
return (id(inverter_dc_power2).state + id(inverter_dc_power1).state);
unit_of_measurement: W
accuracy_decimals: 0
update_interval: 5s
- platform: uptime
update_interval: 5s
internal: true
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
unit_of_measurement: "%"
name: "ESP-Sofar WiFi Signal (human readable)"
update_interval: 30s
device_class: "signal_strength"
icon: "mdi:wifi"
lambda: return (-0.0134 * (id(inverter_wifi_signal).state * id(inverter_wifi_signal).state ) ) + (-0.2228 * id(inverter_wifi_signal).state) + 100.2;
switch:
- platform: restart
binary_sensor:
- platform: status
jak na razie wszystko działa.
tu adresy na podstawie których uzyskałem konfigurację ten plik został przygotowany przez kogoś innego ale jest aktualny
Witajcie, czy macie pomysł jak zintegrować falownik Corab Encore FALOWNIK CORAB ENCOR HYBRID 8K+MODUŁ KOMUNIKACYJNY WIFI ?
