I just created my sensors and incorporated them into the Energy Management config.
Whilst the sensor entities are showing data, they aren’t showing any data in the energy dashboard yet so I’m not sure if there’s still a problem with my sensors or if I just have to wait for Energy Management to “catch up”
sa_energy_grid_import:
unique_id: "sa_energy_grid_import"
friendly_name: Energy Imported From Grid
unit_of_measurement: "Wh"
value_template: >
{% set energy = namespace(imported=0) %}
{% for sensor_data in states.sensor.sa_minute.attributes.data | rejectattr('energy_consumed', 'equalto', None) if sensor_data.energy_consumed > sensor_data.energy_generated %}
{% set energy.imported = energy.imported + sensor_data.energy_consumed - sensor_data.energy_generated %}
{% endfor %}
{{ energy.imported }}
icon_template: mdi:transmission-tower-export
device_class: energy
attribute_templates:
state_class: total_increasing
sa_energy_grid_export:
unique_id: "sa_energy_grid_export"
friendly_name: Energy Exported To Grid
value_template: >
{% set energy = namespace(exported=0) %}
{% for sensor_data in states.sensor.sa_hour.attributes.data | rejectattr('energy_generated', 'equalto', None) if sensor_data.energy_generated > sensor_data.energy_consumed %}
{% set energy.exported = energy.exported + sensor_data.energy_generated - sensor_data.energy_consumed %}
{% endfor %}
{{ energy.exported }}
icon_template: mdi:transmission-tower-import
Here’s some of the data to date. It looks a little strange as 99% of what would have been exported energy is going into our EV. A normal full day’s data will look better - especially for the bar charts (not shown).
One of the chief drivers of my fumbling efforts with HA has been the recent arrival of an EV. I’m about to get a sparkie to put one of my SA clamps on the relevant power outlet and was thinking I could use my solar more intelligently than I have been. Also have Fronius solar hot water diversion (but that’s off topic)
But I’ve been distracted by how well I can control my lights and various other devices/sensors… So I haven’t even looked at the HA Tesla integration - and now I find that the Charge HQ app, currently in Beta is very promising for EV charging using PV.
Had given up on SA integration until you two came along. But now I’m hoping I can use it as a means of automating my aircon more effectively.
Hi @ddwdiot - you’re again welcome. I hope this whole thread has made sense to you. I’m just watching my HA Energy module data over the next 24 hours to see that it’s all working as expected. I’ll then publish the final configuration.html code that will incorporate Glen’s optimisations as the likely final solution for this thread.
We have a Tesla M3 too and are using the Zappi v1 charger. It’s import/export aware and can maximise the charging from your own solar PV (see SA image below - you will note Melbourne had two heavy downpours this afternoon). If you only have single phase power (we have single phase max 60Amps) and you get close to your max current draw sometimes, the Zappi will also limit how much power it draws up to the max supply current so you don’t trigger the mains fuse protection. We sold our Tesla Wall Charger that came with our car for $500 and spent extra to get the Zappi. The only downside is that the Zappi doesn’t have a button on the charge handle to open/close the charge-port on the Tesla. I’ve separately mentioned to Glen, my focus with HA is on the energy mangement and a key part of that is my ability to enable/disable charging on our EV in response to variable 1/2 hour wholesale pricing offered by Amber. Sometimes Amber’s energy prices are negative (e.g. in the middle of the day) and I hope to get paid to charge my car (this also involves HA auto turning down the power output on my PV inverter so I don’t get charged to export).
So we’re following similar paths (Model 3 and getting started with HA with initial interest in energy management). But I’m a bit behind in implementation and technical nous.
I’ve chosen not to get a Zappi - or Tesla equivalent… or wait on the Fronius Wattpilot. Was aware that it takes a long time to pay off and thinking I already have solar monitoring - the Tesla is smart and maybe software could help me with the rest. I needed another project to save me from watching rubbish TV at night anyway.
No Amber in Northern NSW at the moment… but I do have a Lifx bulb tracking the NEM price using nemy and IFTTT. Just for interest.
Looking forward to giving the latest yaml a good workout on the weekend.
Everything seems to be working as expected and the numbers match what is in the Solar Analytics web-app. Here’s a screen shot of the HA Energy Management output. The low PV output reflects the presence of heavy clouds in Melbourne this morning.
I will shortly post the final code (so @ddwdiot can get it going) as the solution, and will provide some instructions for those that find this thread in the future. As a version 1 I think this is a good minimum viable product. I have some further ideas for a next round of development, but I think it would be best to start a second discussion for version 2. I’ll also publish it on github for wider public access.
I have a couple of ideas for small improvements/simplifications to your config but maybe I’ll wait until you post your github repo and create some pull requests there instead.
Instructions are very easy to follow - simple enough for someone with little experience in HA or yaml to get going.
I think I get most of how the yaml works… can now fall back on annoying a software engineer relative for some support if needed - will be aiming to get readings for 3 additional clamps I have in my SA setup… one will be for my EV charging outlet charger and another for my aircon which I aim to automate.
Not sure if it’s a result of something else in my HA setup but thought I’d let you know that I have a warning when viewing in the HA Studio Code Server addon “String does not match the pattern of “Deprecated^”” in each of the entity ID lines in the following part of the yaml.
While the warning message is a bit obscure, I think the forum posting you gave is fairly self explanatory… entity_id is deprecated.
Have you tried removing the entity_id from your sensor to see if it avoids the warning?
Thanks @TheOtherGlen… I didn’t want to remove it on the assumption that it was part of the suggested code. Also that everything was working so well. But I thought it might worry others like me in the future.
Have now commented the relevant lines out and restarted and all is still good. Will delete the offending lines when I understand the entity_id deprecation issue better. Have been reading lots about YAML and HA but still at the stage where I have to continually revise.
I’ve commented out all the “entity_id” lines of code - representing legacy efforts to get the Energy function working. Doesn’t seem to have had any impact on the workings of the data and results.
