Using this information, I created a template that would take the voltage, find the correct 10% divide, and calculate the approximate percentage accordingly:
Compensation: I tuned the system resistance ($R_{total}$) to 0.008$\Omega$. This perfectly offsets the voltage rise seen at 60A (3kW) charging, keeping the SOC stable (e.g., accurate 75% instead of a fake 90%).
Curve: Custom mapping for EVE chemistry (50% SOC set at 3.28V/cell).
{% set v_raw = states('sensor.battery1_jk_bms_total_voltage') | float(0) %}
{% set power = states('sensor.battery1_jk_bms_power') | float(0) %}
{# --- FACTOR DE CORECȚIE RECALIBRAT --- #}
{# La 3300W (62A), scadem aprox 0.5V pentru a ajunge de la 90% la 75% #}
{% set r_system = 0.008 %}
{# Calcul curent (I = P / V). Verificam sa nu impartim la 0 #}
{% set current = power / v_raw if v_raw > 0 else 0 %}
{# Calcul Voltaj Corectat #}
{# Daca incarci (+), scadem voltajul fals. Daca descarci (-), adunam caderea. #}
{% set v_diff = current * r_system %}
{% set v = v_raw - v_diff %}
{# --- HARTA DE VOLTAJ (16S LiFePO4) --- #}
{% set points = [
[44.8, 0], [48.0, 5], [49.6, 10], [50.8, 15], [51.2, 20],
[51.68, 30], [52.16, 40], [52.48, 50], [52.80, 60],
[52.96, 70], [53.28, 80], [53.44, 90], [53.76, 95], [54.40, 100]
{# --- PLASĂ DE SIGURANȚĂ PENTRU ÎNCĂRCARE --- #}
{# Daca voltajul brut e sub 54.0V, nu lasa SOC-ul sa sara de 98% #}
{# Asta previne afisarea de 100% prematur cand incarci cu curent mare #}
{% if v_raw < 54.0 and v > 54.0 %}
{% set v = 53.9 %}
{% endif %}
{# Limite #}
{% if v > 54.5 %} {% set v = 54.5 %} {% endif %}
{% if v < 44.0 %} {% set v = 44.0 %} {% endif %}
{# Interpolare #}
{% if v >= points[-1][0] %}
100
{% elif v <= points[0][0] %}
0
{% else %}
{% set ns = namespace(found=false, result=0) %}
{% for i in range(points | length - 1) %}
{% if not ns.found and v >= points[i][0] and v < points[i+1][0] %}
{% set v1 = points[i][0] %}
{% set p1 = points[i][1] %}
{% set v2 = points[i+1][0] %}
{% set p2 = points[i+1][1] %}
{% set soc = p1 + (v - v1) * (p2 - p1) / (v2 - v1) %}
{% set ns.result = soc | round(1) %}
{% set ns.found = true %}
{% endif %}
{% endfor %}
{{ ns.result }}
{% endif %}
