Difficult to troubleshoot.
Can you ping your wifi stick and login to the web interface using a normal browser.
Try this updated flow. After a certain Node-Red update (while ago, can’t remember) the ping node stopped working.
[{"id":"a6c69280.aefa","type":"tab","label":"Solis","disabled":false,"info":""},{"id":"8d3fd5ff.a575d8","type":"mqtt out","z":"a6c69280.aefa","name":"Publish MQTT Message","topic":"","qos":"","retain":"true","broker":"36d42be1.7a03e4","x":1150,"y":500,"wires":[]},{"id":"6315810.eba6a8","type":"ping","z":"a6c69280.aefa","mode":"timed","name":"Ping Solis Convertor","host":"192.168.2.25","timer":"60","inputs":0,"x":110,"y":280,"wires":[[]]},{"id":"9977c825.5888d8","type":"switch","z":"a6c69280.aefa","name":"Check if convertor is online","property":"payload","propertyType":"msg","rules":[{"t":"false"},{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":400,"wires":[["71244c20.72e364","b51741e5.39a3d"],["5af351cf.e8d92"]]},{"id":"24252177.a3d88e","type":"function","z":"a6c69280.aefa","name":"Grab current power value","func":"var parts = msg.payload.match(/webdata_now_p\\s=\\s\"(\\d+)\"/);\nmsg.payload = {\n value: parts[1],\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":470,"y":480,"wires":[["e7aaad99.13a0c"]]},{"id":"5af351cf.e8d92","type":"exec","z":"a6c69280.aefa","command":"curl 'http://username:[email protected]/status.html'","addpay":true,"append":"","useSpawn":"false","timer":"10","oldrc":false,"name":"Scrape web interface","x":180,"y":480,"wires":[["24252177.a3d88e","35f76747.bda408","10bd3393.9a038c"],[],[]]},{"id":"71244c20.72e364","type":"change","z":"a6c69280.aefa","name":"Prepare message","rules":[{"t":"set","p":"topic","pt":"msg","to":"Solis_Power_Current","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":340,"wires":[["8d3fd5ff.a575d8"]]},{"id":"e7aaad99.13a0c","type":"change","z":"a6c69280.aefa","name":"Prepare message","rules":[{"t":"set","p":"topic","pt":"msg","to":"Solis_Power_Current","tot":"str"},{"t":"move","p":"payload.value","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"rc","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":480,"wires":[["a54e4318.609bb"]]},{"id":"35f76747.bda408","type":"function","z":"a6c69280.aefa","name":"Grab total power today value","func":"var parts = msg.payload.match(/webdata_today_e\\s=\\s\"(\\S+)\"/);\nmsg.payload = {\n value: parts[1],\n};\nreturn msg;","outputs":1,"noerr":0,"x":480,"y":520,"wires":[["ec1f587c.99d7a8"]]},{"id":"ec1f587c.99d7a8","type":"change","z":"a6c69280.aefa","name":"Prepare message","rules":[{"t":"set","p":"topic","pt":"msg","to":"Solis_Power_Today","tot":"str"},{"t":"move","p":"payload.value","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"rc","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":520,"wires":[["8d3fd5ff.a575d8"]]},{"id":"10bd3393.9a038c","type":"function","z":"a6c69280.aefa","name":"Grab total power value","func":"var parts = msg.payload.match(/webdata_total_e\\s=\\s\"(\\S+)\"/);\nmsg.payload = {\n value: parts[1],\n};\nreturn msg;","outputs":1,"noerr":0,"x":460,"y":560,"wires":[["8a30c6ed.9b75d8"]]},{"id":"8a30c6ed.9b75d8","type":"change","z":"a6c69280.aefa","name":"Prepare message","rules":[{"t":"set","p":"topic","pt":"msg","to":"Solis_Power_Total","tot":"str"},{"t":"move","p":"payload.value","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"rc","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":560,"wires":[["8d3fd5ff.a575d8"]]},{"id":"b51741e5.39a3d","type":"timecheck","z":"a6c69280.aefa","name":"Midnight","time":"23:58","x":500,"y":400,"wires":[["4869bc6c.1cf2c4"],[]]},{"id":"4869bc6c.1cf2c4","type":"change","z":"a6c69280.aefa","name":"Prepare message","rules":[{"t":"set","p":"topic","pt":"msg","to":"Solis_Power_Today","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":380,"wires":[["8d3fd5ff.a575d8"]]},{"id":"a54e4318.609bb","type":"function","z":"a6c69280.aefa","name":"to kW","func":"msg.payload = Number(msg.payload);\nmsg.payload = (msg.payload)/1000;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":890,"y":480,"wires":[["8d3fd5ff.a575d8"]]},{"id":"d3756928.2025d8","type":"ping","z":"a6c69280.aefa","mode":"triggered","name":"Ping Solis Convertor","host":"","timer":"20","inputs":1,"x":190,"y":240,"wires":[["9977c825.5888d8"]]},{"id":"2311af6d.9be32","type":"inject","z":"a6c69280.aefa","name":"Ping trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"60","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"host\":\"192.168.2.25\",\"timeout\":15000}]","payloadType":"json","x":130,"y":160,"wires":[["d3756928.2025d8"]]},{"id":"36d42be1.7a03e4","type":"mqtt-broker","name":"mqtt_broker","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
- If ping works again, please post output of the scrape node. maybe your web interface (and output) is slightly different. You can try regex101.com and paste your output in the text box, then tru the regex to see how it works.
