Solaredge Modbus Configuration for Single Inverter and Battery
I am trying to setup PV / Solar Excess Optimizer Blueprint and wondering if I am missing something with the Modbus integration.
Is there a dedicated Export, Load and Combined Import/Export Power sensor? I can see some of these in the standard SolarEdge integration but they only update every 15 minutes. I have setup the last one using a template sensor based off the sensor.solaredge_m1_ac_power entity but not sure about the others.
The blueprint states:
  • Export Power: Sensor which contains your current export power to the grid in watts. Must not be negative! For best results, this sensor should be updated at least every minute.
  • Load Power: Sensor which contains your current load power (combined household appliance consumption without home battery charging consumption ) in watts. Must not be negative! For best results, this sensor should be updated at least every minute.
  • Combined Import/Export Power: Sensor which contains both , your current import power from the grid (positive values) and your current export power to the grid in watts (negative values). For best results, this sensor should be updated at least every minute.
Edit - sorted the Export Power sensor, just no idea how to get the load power as circled below
