Solaredge Modbus Configuration for Single Inverter and Battery
For those experiencing issues with their inverters resetting at random intervals, and thus reverting any changes to the default settings, may I suggest my solution of adding a ‘watchdog’ automation to protect against these events.
Essentially, you want to add changes, to your desired setting(s), as triggers for your automation and then assess their state. If their state is not what you want it to be at that time/under those conditions, then reset it to what it should be. What will happen, in case of a reset, is that your setting will become ‘unavailable’, your watchdog automation will try to reset it, and fail. Then, when the inverter comes back to life, the state will change again, to the default values. Your watchdog will trigger again, and this time it will be successful at setting your desired values. This should only cost you a second or two of default operation, before your settings are restored.
As an example, this is my watchdog to ensure that my battery remains in grid charge mode throughout the cheap overnight period of my tariff.
alias: Battery Go Watchdog
description: ""
  - platform: state
    entity_id:
      - select.solaredge_i1_storage_command_mode
  - condition: and
    conditions:
      - condition: time
        after: "00:30:00"
        before: "04:29:00"
      - condition: not
        conditions:
          - condition: state
            entity_id: select.solaredge_i1_storage_command_mode
            state: Charge from Solar Power and Grid
  - device_id: ************************
    domain: select
    entity_id: ************************
    type: select_option
    option: Charge from Solar Power and Grid
It is also possible to roll this functionality into the main automation, by adding changes of the desired setting as an additional trigger, and using the trigger ID functionality to discern which path to take.
