Solarman Integration by Stephan Joubert
I pull data directly from the Inverter via the RS485 port. I followed this build instruction to make the Modbus board.
Which provides directly from the inverter to MQTT and HA:
  • running_state
  • grid_voltage
  • grid_current
  • grid_freq
  • battery_power
  • battery_voltage
  • battery_current
  • batterySOC
  • battery_temp
  • battery_cycles
  • grid_power
  • consumption
  • solarPV
  • today_generation
  • today_exported
  • today_purchase
  • today_consumption
  • inverter_temp
  • inverterHS_temp
  • solarPVAmps
With the inverter in Passive Mode, send MQTT messages to:
  • sofar2mqtt/set/standby - send value “true
  • sofar2mqtt/set/auto - send value “true” or “battery_save
  • sofar2mqtt/set/charge - send values in the range 0-3000 (or higher if your inverter goes above 3000 watts)
  • sofar2mqtt/set/discharge - send values in the range 0-3000 (or higher if your inverter goes above 3000 watts)
