Unfortunately, this whole Wireshark and conversion is new to me and that’s what I’m stuck on. I see that some is sent to the inverter and also comes back again.
I have seen two potential payloads and tried to get the data into Home assistant.
Ok, I found it out myself. The payload of solarmax3000s was already correct, but as long as the software MaxTalk is running, the sensor gets no values. Why? No idea
Now I finally have my values in Home assistant. One question can you possibly still read out the total fed current or tell me which sensor I need for this?
No worries. Yes, I got it working a short time later. The error was that I still had MaxTalk open and somehow it “grabs” the data as long as it is active and Home Assistant does not get it. In the meantime everything arrives cleanly.
I have one last question. Do you happen to have an idea how to read the total number of kWh fed? Quasi solarmax “total generated energy”.
I have also noticed if MaxTalk is running then HA can not access the data. I haven’t got that particular metric out of mine yet , I will take a look tomorrow as it should be just another call that we can capture and work out.
Hmm… I don’t get it where you guys got the payload from.
I can see a lot of my two inverter’s (SolarMax 3000s and SolarmMax 2000s) TCP data packages on Wireshark on port 12345, and I’ve looked through a lot of packages now, but there is no similiar payload to yours.
You just double clicked the packages and looked deeper into them, right?
Just for anyone looking for the same for the more recent Solarmax / Solarmax Ultimate inverters: Those can be easily integrated via ModBus. Solarmax has been posting the relevant information at their homepage (https://www.solarmax.com/download), and from there it is easy getting this into HA.
Hi David,
thanks a lot for your investigation regarding SolarMax. I will also reduce the equipment (RPi running Solaranzeige and Volkszähler) and integrate SolarMax directly into HA (as long as the inverters keep running …). Unfortunally I get bad info from config check…
Do you, or anyone else here, have any idea
Dieter
Sure, here it is. I struggled also hugely until I learnt that you need to add the “input_type: input” so HA knows which register “family” to do the lookup in. Just add your IP address below, and all should work.
Hello, I’m following your post carefully, but I can’t get a good result.
Can someone help me because I don’t see where I made the mistake.
thank you very much
Hello, I follow your post carefully, but I can’t get a good result. Can someone help me ? thank you very much
I get it managed that I could connect via Modbus to my Solarmax 13SMT inverter. My biggest issue for now is to find the right Modbus addresses for the inverter. Every help is welcome. I’m not sure if all values are right. THX in advance.
