If anyone is interested I have started to add in Solis registers into my custom_component there are only 33 sensors at the moment, but once it’s confirm it’s working I can add in the rest.
So far it will only recognise the Hybrid 5G version, assuming it works correctly.
Let me add, that Will also made Solis RHI-3P10K-HVES-5G working quite well already by adding your model. I use a Serial to RTH adapter. This is going to be good!
I have a Solis Hybrid which i am able to control the “charge from grid” register to remotely turn on grid charging.
I also have a configuration.yaml code that figures out the cheapest 2/3/4/5 hour time slots from my Agile rates card. This returns a date/time formatted like this: “2022-11-21T22:30:00Z”
Can anyone help with a way to run a script when current time is within that 2/3/4/5 time slot?
I’m running on a different track reading the Solis modbus registers using an Arduino which sends MQTT to my HA (GitHub - PhillyGilly/SolarisS6ArduinoMqtt: Solaris S6 RS485 modbus to Arduino to MQTT) and I am disappointed at the precision of the returned data e.g. active power returned to the nearest 20W. Are you getting better precision with your implementation?
I have tried to do exactly this but could successfully get the setup.sh to install. I kept complaining it could find requirements.txt. I copy/pasted all the commands straight from GitHub.
I did this on a Raspberry Pi Zero W with the latest OS Lite flashed with Raspi Imager. Can I ask what version of the OS you used? As I’d like to get this nailed!
pysolarmanv5 is based on SolarmanV5 protocol which is something like Modbus RTU rather than Modbus TCP; however, it is supported by DLS-W datalogger, which I also have.
How do you get the wrapper feed into HA? Did you build anything to show on the dashboard?
Here is my setup after many attempts to connect multiple devices. It is still to be tuned, but the initial work is done. Happy to share more information if needed
Hi Craig. Probably. No idea about cost or timescale yet, but happy to investigate. Can you contact me though eBay? If so, we can take this further. Phil
Here you’ll find an ready-to-use ESPhome ModBus register map and config files for ESP8266 and EMW3080 (the MCU used in the S3 WiFi stick). As a bonus, the inverter’s clock will be synchronized via NTP.
Any chance you could provide more images or a wiring diagram? Planning to do exactly this but can’t really make out all the details from your image, looks like you are powering the Pi from the inverters COM-port?
I guess there is some RS485 board under the Pi on the image? Since it looks like the red and yellow wires are going there.
I also see a purple and blue wire, can’t really tell where those are going.
This forum has been amazing for getting me very quickly up and running with my Solis RAI-3K inverter. I have all but 3 fields i would like to read; on the inverter LCD there’s readings for:
PV-CT Voltage
PV-CT Current
PV-CT Power
These read as i would expect (for voltage it takes the RAI voltage as theres not a remote voltage measurement input) and for current there is a CT. In the settings this CT can be configured for the house load or PV and in my case i am using it for PV power from the solar inverter.
Has anybody found MODBUS registers for these values?
I could hook upto the PV inverter, its also SOLIS but given this is the last info i need for now, i had hoped to get it with the other data. I did note on another forum post last year somebody was looking for this info, but unclear if they ever received it.
