Solis Inverter Modbus integration
Sorry for the slow response but I have been on holiday.
Update is every 30 seconds.
I’ll commit the code to git hub and add some instructions. Really need to create a HACS package but don’t have the time right now.
Interesting, have you got any source how to configure the “onboard wifi”?
I ran the Solis TechView apk in an Android emulator and monitored the network traffic with Wireshark.
Basically reads/writes registers in a similar way to modbus. I don’t really know modbus but the registers appear to be the same as in this document.
The code and discussion can be found here. It’s the zip file to download. Not the best use of github but it works.
I have not tested or tried setting at registers. This may or may not work.
The APK will ONLY WORK is directly connect to the WiFi access point. The default password for the direct connect is admin, admin.
On the web interface setup up the Network Setting->Network Connection 2 Setting to:
Protocol: TCP Server
Local Port: 8000 ← this is what is used by the integration.
Passwords for APK:
advanced user: solis123456
installer: solis123
My source code would include the reading of most of the relevant values because I have used that document to write my source code.
I don’t really understand how to turn on the wifi though.
I’m also not entirely sure if my inverter is 100% the same…
@Schorseg I would validate that you can connect with the APK first. If this works then your inverter, Solis RAI-3K-48ES-5G, supports WiFi without an WiFi addon.
I also assume, you can locally log into your inverter.
Does anyone know what combination of settings might give me the following 2 behaviours?
Charge from solar: charge the battery from any excess solar but don’t discharge it to cover loads
Discharge for loads only: cover loads with the battery but don’t charge it from any excess solar
Usual Self Use mode:
Solar → load, battery, grid
Load ← solar, battery, grid
The Backup Mode (hybrid inverter) with Grid Charge off, and Backup SOC > battery SOC will do some of this, but all solar will go to the battery and all load will come from the grid.
Load will only be supported by the battery if not enough solar and battery SOC > Backup SOC thus charging the battery has priority.
Solar → battery, load, grid
Load ← grid, solar, battery
I think Solis docs say this is
Load ← solar, grid, battery
but my experience is otherwise.
Feed In Mode, with a charged battery should do this. Note that in Feed In mode, the battery is only charged when solar exceeds both the load and grid export capacity, hence you will need to charge it in another mode first.
Solar → load, grid, battery
Load ← battery, solar, grid
I’ve been trying to integrate Solis Modbus on HA. When adding the integration, I’m asked for the IP and TCP port for my inverter. I’ve tried adding the IP address for my Solis datalogger (attached to my Solis RAI-3K-48ES-5G) with no luck. I used the default TCP port 502. Is there something I’m missing? Sorry, just getting into this so likely a stupid question.
If you are using a data logger I cannot help as I don’t use a data logger.
If you are connecting directly I would recommend using the app first to ensure no network issues.
Hi, I need some help identifying the Solis inverter model name. I’m targeting register 33000 (Model No) and have obtained the hexadecimal value, but I need to map it to the corresponding Solis inverter model. For example, hex 0x0143 might represent the Solis RAI-3K-48ES-5G model. I searched online but couldn’t find a document with this mapping. I would be grateful if you could guide me in this regard. Thanks.
you might need to go near the inverter and scan for the network solis-xxxxxxxx(xxx being the serial n7mber). i only noticed that ours had when the app said to reboot and i noticed a wifi dongle port next to the data logger installed by the installers. got an antenna for it and is now able to connect directly to the inverter.
Anyone update to the new version 3?
My TOU control seems to have gone - i think its still there but not sure how to set up the card again…
any ideas?
Everything worked fine via wifi Solis modbus. I switched to Waveshare so I could see it in the cloud. The picture is only what I see now. There are more than 400 entities, but I only see a few numbers - I provide a photo, More than one sensor does not show anything. How to fix this to get all the data.
Why do u have 2 waveshare rs485 modules how did u wire this?
Guide to Waveshare setup here: GitHub - alienatedsec/solis-ha-modbus-cloud: This repo is a workaround for Solis inverters to connect Solis Cloud and the local Home Assistant regardless of the model of your Solis datalogger
I never liked connecting to Solis Cloud, so I’ve been using a custom HA integration that I implemented in 2022 as a “machine in the middle” for the Solis Wi-Fi datalogger. It creates a server that mimics the Solis servers response so my data does not leave my LAN.
I hadn’t seen this thread until now. I didn’t know so many people were interested in it. I thought it might be useful to others, so I’ve published it on GitHub and it’s available for installation in HACS: GitHub - Rapsssito/local-solis-ginglong-inverter: Local Solis/Ginglong Inverter logger via LAN for Home Assistant
I can’t seem to find this in HACS?
Final committed my code to github for connecting directly to a Solis RAI-3K-48ES-5G inverter over WiFi without dongle. These inverters have onboard WiFi.
The code can be found here.
In this repository I have placed the original Solis TechView apk which was used to reverse engineer the packers to the inverter.
These are also some useful yaml scripts for setting things on the inverter.
Getting a heat pump and switching the a variable tariff was the motivation I needed to update the code.
Hello everyone, I’ve been trying for several months now to get my 6 kW Solis CO2 Zero inverter to communicate with Home Assistant. Thanks to the integration, I’ve managed to read the data from the cloud, but as you well know, updates come in every 5 minutes, and this prevents me from setting up targeted automations. I’m trying to make sense of all your posts here, but I’m struggling to understand if there’s a solution that doesn’t involve going through the cloud and reading data in real time. Can anyone help me or point me in the right direction so I can figure out how to do this? I’m currently trying, without success, to exchange data using an EBYTE RS485-to-Ethernet device connected in parallel to my home meter and the RS485 output of my inverter. Thank you very much, and well done on all the work you’re doing in the community.
