Gosh, I restarted HA, started again and it’s up!
Great thread. Got me over the line!
Thank you so much!
Thank you so much!
yeah HA sometimes refuses to download stuff
well done!
I believe you need another docker container with NUT with your battery backup connected. You will then use the ip& port of that docker container to set it up in HA.
Thanks after struggling with this. This was the one thing I over looked.
If it helps anyone:
In add-ons: Install Network UPS Tools
Configuration below:
devices:
- name: apcups
driver: usbhid-ups
port: auto
config:
- vendorid = 051d
mode: netserver
shutdown_host: 'false'
users:
- actions: []
instcmds:
- all
password: pasword
username: apc
Put port 3493 under network
then in Devices & Services install NUT
Hi!
I’ve been able to install APC BR900G-GR Back-UPS PRO and get sensors such us battery charge, load or status, but all diagnostic sensors were unavailable until I went to “Entities” and manually enabled all of them.
Just in case this helps anyone.
Hi jjvelar, sorry if i bother you after almost 2 years…
I’m trying to install the same model but i can’t configure correctly the addon, could you please paste your configuration?
Thanks!
