I think you meant to reply to Vendo232’s post, not mine. All I offered was the possibility of using the Counter integration.
Good luck!
Good luck!
so far, trying to incorporate the simple cycle count and run the announcement when 20 counts are reached and OFF state for 5 min is present. Will have to figure out how to Reset the counter once the Dryer Complete automation runs.
- alias: Counting Dryer
- platform: state
entity_id: sensor.dryer
to: 'on'
service: counter.increment
entity_id: counter.dryer_counter
- alias: Dryer Complete
- platform: numeric_state
above: 20
condition: state
state: 'OFF'
for: '00:05:00'
- service: notify.alexa_media
type: tts
- media_player.echo_show
message: " Dryer is complete "
and here it is, not an Programmer`s choice but working solution for simple guy like me.
- platform: state
to: 'ON'
above: 20
condition: state
state: 'OFF'
for: '00:05:00'
type: tts
- alias: Counting Reset
- platform: state
to: 'OFF'
for: '00:06:00'
service: counter.reset
The “Dryer Complete” automation may not work the way you expect.
It triggers when dryer_counter exceeds 20. This trigger will occur when the count changes from 20 to 21 It will not trigger when it changes from 21 to 22, or 22 to 23, etc (it triggers when the threshold value is crossed). So when the count is 21, it will check if dryer has been off for at least 5 minutes. If it has not the automation’s action is not executed … and the automation will not be triggered again (because the count has to drop below 20 and then rise above 20 to trigger the automation again).
you are correct , this part of automation is not working yet
I will try to swap condition and trigger.
this is the working Solution ! thank you all for your inputs. The sensor + D1mini was ~4$
- platform: state
to: 'ON'
- platform: state
to: 'OFF'
for: '00:03:00'
- condition: numeric_state
above: 20
type: tts
- platform: state
to: 'OFF'
for: '00:05:00'
Why not use the “Dryer Complete” automation to reset the counter? What’s the need to wait another 2 minutes before resetting it?
When “Dryer Complete” executes its action, the counter has served its purpose so you may as well reset it there as opposed to using a separate automation.
platform: state
to: 'ON'
platform: state
to: 'OFF'
for: '00:03:00'
condition: template
value_template: "{{states('counter.dryer_counter')|int > 20}}"
- service: counter.reset
type: tts
of course! makes perfect sense.
I`m afraid I could reduce tons of lines in my code if we work together more often
cheers
I have tried both: Xiaomi vibration sensor and power measurement and found power management far superior in terms of reliability.
You could even use the temporary additional power usage of crease protection (or anti-creasing, if your dryer has that feature) for a repeating reminder.
Interesting, never heard about 230V sockets in the U.S. My washing machine and dryer both consume 2300 Watts peak, so in Europe this translates to 10 Ampere. So there is no difference in the electrical plug.
You could use a current sensor, like https://esphome.io/components/sensor/pzemac.html or https://esphome.io/components/sensor/ct_clamp.html
You could also attach a $0.95 photo-resistor on top off a LED/light of the dryer that indicates if it is running or not.
Kinda late to the discussion but I just installed a temp/humidity sensor on mine over the weekend and made a YouTube video about it. Just incase it helps someone else.
Make a Dumb Dryer Smart in Home Assistant!!
I decided monitoring the moisture was a better approach for my situation since my dryer time seems pretty inconsistent and either leaves clothes damp or cooks them. I think this method should save me some electricity also.
Good luck with your projects!!!
Jake Bauer
Jake, I like you take on this: measure what you really want to know, i.e. are the clothes dry? I think I have all the parts here in my boxes, I think I have a new weekend project!
It is a great idea.
I can imagine that the Humidity could be used as secondary information to the current measurement or motion monitoring to indicate something like
I will try to add the DHT22 to my existing sw-420 to extend the automation logic.
Ive also got the TPlink energy plug reader/sensor. I had my config setup like this (im a newb!)
But im getting random notifcations at odd times of the day when the dryer isnt running and I cant figure out why. I was hoping to tighten up my code and make it more strict.
Only problem is the dryer drops to 2.6W momentarily during its cycle to change its rotation of spin but sits at 1800W normally.
I have it currently send a notification simply once its been under 1.0W for 10 seconds but was thinking of maybe adding an IF statement somewhere to say if its been over 1000W for 10 seconds and then goes under 1.0W for 10 seconds THEN fire off a notification? Just got no idea how to write that
- alias: "Notify when dryer is done"
entity_id: sensor.my_tp_switch_watts
below: 1.0
for: 00:00:10
service: notify.PUSHOVER
title: "Dryer done"
message: "Grab the clothes!"
Hi, I have just picked up two vibration sensors, one for dryer and one for washing machine. Can you share your code with me please so I can tweak it to suit my application?
For those struggling with this like I was, I found a related post that solved my issues! Between the blue print and the idea to attach the sensor to the dryer drum it totally works now.
Thank you @rod_poplarchick !!
good job figuring this out, seems like it will work great
I went down a similar path, using the SW-420. Thought I’d share photos of a slight “upgrade” - it’s now a $5 sensor including the housing . ESP-01, carrier board, SW-420, Tic-Tac container, small piece of foam to hold the boards in place.
Going to mount to the side of my dryer with velcro tape.
