I am using Home Assistant, Node Red, and ESPHOME to control an ESP32 with a relay attached that is used to open and close my garage door.
To function, Node Red triggers the ESP32 to toggle the relay to close and open a circuit within about half a second (which effectively pushes the button on a garage door remote to open/close the garage door).
This works fine most of the time, except when the ESP32 is restarted - most notably if there is an update to the ESP32 driven by a ESPHOME updated, or when the power goes out and comes back on in our neighbourhood. When the ESP32 is restarted, it somehow causes the ESP32’s relay to toggle and the garage door opens.
Here is the ESPHOME card in Home Assistant:
esphome:
esp32:
board: esp32doit-devkit-v1
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
password: "redacted"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Garage-Door"
captive_portal:
globals:
# Set the threshold distance
# if the reading is greater than the threshold distance the garage door is considered closed otherwise it will be considered open
- id: threshold_distance
type: float
initial_value: '0.25'
# This is the physical sensor, not published to Home Assistant
- platform: ultrasonic
trigger_pin: 2
echo_pin: 5
update_interval: 3s
filters:
- filter_out: nan
internal: true
binary_sensor:
name: "Garage Door Sensor"
lambda: |-
return (id(ultrasonic_sensor).state > id(threshold_distance));
switch:
- platform: gpio
pin: 21
name: "Garage Door Relay"
name: "Garage Door Button"
turn_on_action:
- switch.turn_on: garage_door_relay
- delay: 500ms
- switch.turn_off: garage_door_relay
turn_off_action:
- delay: 500ms
The reference to an “Ultrasonic Sensor” in the above is just something that the Node Red code uses to ensure it doesn’t open the garage door when it is already open, or close the garage door when it is already closed.
Is there any safeguard that can be coded in above to ensure the relay doesn’t get toggle within say the first 30 seconds of the ESP32 being restarted?
