Hello everyone,
I have a solution from an Austrian user. I have created a template folder. The folder must be linked. In the folder is a gas.yaml and a strom.yaml.
So I don’t need a WiFi connection to record the measured values.
CU-Martin
Hallo an Alle,
ich habe eine Lösung von einem Österreichischen User.Ich habe einen template Ordner angelegt.Der Ordner muß verlinkt werden.Im Ordner ist eine gas.yaml und eine strom.yaml.
So brauche ich keine WiFi Verbindung zur Erfassung der Messwerte.
CU-Martin
configuration.yaml
template: !include_dir_merge_named template
#USB-Sensor Weidmann--------------
- platform: edl21
serial_port: /dev/ttyUSB0
#Reedkontakt am Gaszaehler----------------
binary_sensor:
- platform: rpi_gpio
sensors:
- port: 18
unique_id: "gaszaehler_pin"
bouncetime: 80
pull_mode: "DOWN"
gas.yaml
- unique_id: gasverbrauch_m3
state: "{{ states ('counter.gaszahler') | float*0.01 }}"
icon: mdi:fire
unit_of_measurement: m³
device_class: gas
state_class: total_increasing
- unique_id: gasverbrauch_kWh
state: "{{ states ('counter.gaszahler') | float*0.1 }}"
icon: mdi:fire
unit_of_measurement: kWh
device_class: gas
strom.yaml
- sensor:
- name: Strombezug
state: >
{% set pwrin = states('sensor.stromzaehler_positive_active_energy_in_tariff_t1') | float %}
{{ pwrin / 1000 | round(3) }}
device_class: energy
#zusatz 27.09.2022
- name: Nettobezug
state: >
{% set pwrin = states('sensor.stromzaehler_sum_active_instantaneous_power') | float %}
