Sorry for probably a stupid question but just to confirm - all custom elements installed from HACS/Frontend require lovelace to be in “yaml” mode?
They can’t be added if lovelace is in “normal” mode - is this correct?
I was having this exact problem with another repo installed via HACS. I discovered that the resource for LoveLace was installed with the URL starting at the /hacsfiles/ directory, and had a bunch of extra gobbiltygook in the path at the end, including a hacstag. I added a new resource that simply started with /local/ and that seemed to make the error go away.
Now its saying the configured entity can’t be found. Don’t entities get installed with the repo? I’m so confused.
