That sorted me out, thanks!!!
Hello
just for sharing.
I have a problem with influxdb on NUC with hassio. add-on is correctly installed, but no measurement available with folliwing config on configuration.yaml
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: homeassistant
password: password
max_retries: 3
default_measurement: state
This config work well anyway on ODROID-C2.
To solve my problem on NUC, I just replace “host:” with its real ip address, and all measurements appear
Hope this help someome.
cheers
JVU
I have the same issue. Influxdb is not receiving data anymore. It did receive them after the initial setup though, and I don’t didn’t change anything. No issue in either HA nor influxdb logs. Reinstall didn’t fix, SSL is enabled (saw this being discussed as the culprit).
