[solved] MQTT with SSL/TLS not working with Home Assistant
Step 0. Install openssl
I believe it’s installed by default on raspbian
Sudo apt install openssl
Ofc you’ll need root privileges and terminal. Not sure if you can access either of those on HA OS
I Have ring-mqtt with the Mosquitto Broker and would like to make it Secure with SSL but not exactly sure how ??
I Have ring-mqtt with the Mosquitto Broker and would like to make it Secure with SSL but not exactly sure how ?? Does anyone know ? I am running Homeassistant OS on Rasberry PI 4 - I know files need to be copied to the SSL folder in HA
Hi @lordratner
Have you get it to work,?
I m struggling with the same problem
Do you have a sample config for your setup?
Br Dave
This was specifically causing me issues. Replacing these commands made mine work finally after 2 days scratching my head! thanks lol.
