Cool. Curious as to why you don’t use base_url in http component. Can you elaborate?
I was able to get it working by adding port forwarding 8123 > 8123
I had it commented out from over a year ago when I first setup HA and everything worked without it, not even sure what it does exactly, glad you got it working
I had the same issue. I had recently uncommented the base_url. Once I commented it out again, my TTS started working once more. I am using a Docker container.
I recently got this problem after adding home assistant behind an nginx reversed proxy. Fixed it by adding base_url in the tts section
HI, can you give me more information about configuration of nginx? wich home assistant version do you have?
I have Home Assistant Core 0.116.2 and when try to launch tts service i receive the error:
2020-10-18 18:43:39 ERROR (Thread-10) [homeassistant.components.cast.media_player] Failed to cast media http://<internal_IP>:8123/api/tts_proxy/6279886fde090b3038f267098bcca771a6efa946_en-us_a9c18110b0_cloud.mp3 from internal_url (http://<>internal_IP:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Here is my configuration. I’m running always the latest HA. I run this on Debian.
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
# Update this line to be your domain
listen 443;
server_name homeassistant.yourdomain.something;
# Ensure these lines point to your SSL certificate and key
ssl_certificate /etc/letsencrypt/live/homeassistant......../fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/homeassistant......./privkey.pem;
# Ensure this line points to your dhparams file
ssl_dhparam /etc/nginx/ssl/dhparams.pem;
# These shouldn't need to be changed
# listen [::]:443 default_server ipv6only=off; # if your nginx version is >= 1.9.5 you can also add the "http2" flag here
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers "EECDH,.................. More stuff.......RT:!DES:!MD5:!PSK:!RC4";
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
proxy_buffering off;
location / {
proxy_pass http://127.0.0.1:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
It does not matter. I use mine to get encryption and my own certificates. Also to use cnames.
