I’d just try with sensor.unifi_gateway_wan.attributes.gw_system-stats.mem
It’s just json…
I just happened to have this on my screen when I came across this post looking for something else.
{{ state_attr('sensor.unifi_gateway_wan', 'gw_system-stats') ['mem'] }}
Here’s my whole template too if you want it.
sensors:
usg_mem:
unit_of_measurement: "%"
icon_template: "mdi:timer"
friendly_name: Unifi Gateway Memory Usage
value_template: >
{{ state_attr('sensor.unifi_gateway_wan', 'gw_system-stats') ["mem"] }}
Edit: …also, here’s my template for the ‘Up-time’ if you want it. It took me a while to figure out the math and syntax so maybe this will save you some trouble if you have a use for it:
sensors:
usg_estimated_runtime:
entity_id: sensor.time
friendly_name: Unifi Gateway Estimated Runtime
value_template: >
{% set day = (state_attr('sensor.unifi_gateway_wan', 'gw_system-stats') ["uptime"] | int // 86400) | round() %}
{% set hr = (state_attr('sensor.unifi_gateway_wan', 'gw_system-stats') ["uptime"] | int % 86400) // 3600 %}
{% set min = (state_attr('sensor.unifi_gateway_wan', 'gw_system-stats') ["uptime"] | int % 3600) // 60 %}
{% if day <= 0 %}
{% else %}
{{ day }}{{ ' day' if day == 1 }}{{ ' days' if day > 1 }}{{ ', ' if day and hr and min > 0 }}{{ ' & ' if day and hr > 0 and min < 1 or day and min > 0 and hr < 1 }}
{%- endif -%}
{% if hr <= 0 %}
{%- else -%}
{{ hr }}{{ ' hour' if hr == 1 }}{{ ' hours' if hr > 1 }}{{ ' & ' if min > 0 }}
{%- endif -%}
{% if min <= 0 %}
{%- else -%}
{{ min }}{{ ' minute' if min == 1 }}{{ ' minutes' if min > 1 }}
{% endif %}
Hi Jason, thank you so very much. Funny I was still poking around trying to get this figured out and your email came in. Really appreciate it and it worked perfectly as you had listed.
Great to hear!
I guess I was just in the right place at the right time.
