I thought I was suppose to power inject at every strip? But your idea with taking out the Black seems nice(less cable management).
Edit: And yes autocorrect made that sentence weird. I mean t terminal power distribution block.
I promise! The least I can do to give back to the community.
You can do it at every strip, but you donât have to (I thought I said that before? If not, sorry! lol). Typically, the suggestion is to power inject every 5m of strip, but that is entirely dependent on the project. Iâm trying to think about what would be cleanest and also the least amount of work and (imho) that would be running power at every strip. That way, you get all the soldering done at once, mount the strips, attach the wires and youâre done. If you choose to serpentine all 3 wires, you can do it that way too (for easier cable management), but then youâd want to inject somewhere in the middle of the steps.
âthat would be running power at every stripâ you mean directly from the power supply/terminal birsge thingy? So I solder on two cables for each strip that are to be connected to the two terminal (power and ground respectively). Then solder on datacables between each strip and finnaly mount the cables to the terminal (also connecting the termina blockl to the power supply and the ground block to the controller)
Yup! You got it! So, youâll have 1 power wire and 1 ground wire going to the terminal blocks from your power supply. From there, you run power and ground to each strip (and donât forget a ground wire from the ground terminal block to the NodeMCU. THIS IS IMPORTANT without it, your lights wonât work).
In total, youâll have 11 power wires leaving the power terminal block and 12 ground wires leaving the ground terminal block. The nice thing about this setup is that you can have a long run of wire from wherever you want to place the power supply and mount the power and ground terminal blocks somewhere close to the stairs. For instance, for my lights, I have my power supplies up in my attic mounted in a electrical box. Then, I just run cables from that down to my yard, living room, etc. Then I run power and ground to the lights from the terminals. It looks a lot better than dozens of cables running all over the place.
SK6812 has the tinyest size led that is SK6805-EC15,the size just is 1.5*1.5mm.Does anyone have some experience for it?
It is almost finished, I have some bugs to fix and it has been put on hold. But I can give you some pointers.
Shopping list and some explanation (I have included the long names so you can search on amazon):
TF-LIGHTING RGBW RGB+Warm White SK6812 60 led/m .
Ok so this is pretty self-explanatory but I went for the SK6812 for adressability. The 60led/m as you want them pretty close together (especially if you dont put it in a rails/cover) but I would advise from even denser as the power requirement goes up significantly.
BTF-LIGHTING 3Pin WS2812B WS2811 SK6812 Connector 10mm Wide Dual End with 15cm Cable LED Strip Solderless DIY LED Flexible Strip 10PCS .
Ok so this one you dont really need. My problem with these was that I still had to cut them and solder the wires together. More on that later. But you could just as well solder directly on the SK6812
BTF-LIGHTING DC5V 60A 300W Aluminum Power Supply for WS2812B APA102 LED8806 WS2801 SK6812 LED
Ok, power power power!. 300w seemed like overkill but damn these draw a lot of power. I donât have the calculation exactly in my head but I think it SK6812 takes 40 mA / led. So 40mA * 60 * how many meters. In my case it was about 12m which is about 30A and you should probably be under 75% of maxload.
Microcontroller:
Any ESP8266 should do. I went with (I think, that or ESP32, should really work the same)
MakerHawk 3pcs ESP8266 NodeMCU LUA CP2102 ESP-12F WiFi Internet Development Board Serial Wireless Module for Arduino IDE/Micropython New Version
Level shifter(essential) 3 .3 to 5V. Ok so what is the problem? Your data channel from your microcontroller is 3.3v and that wounât be enough to control the lights, especially if you connect multiple together. You will get really weird errors where only some of the lights are controllable, after a few sections the lights become uncontrollable or unreliable. I got this one but there are many others. I will post a finished schematic and some well needed images of everything but am unable to do so this week.
ICQUANZX 10pcs 4 Channels IIC I2C Logic Level Converter Bi-Directional Module 3.3V to 5V Shifter
Some good resources for why level shifter and how to handle the sk6812 can be found here(i havent validated these as I didnât use exactly these when I built)
Again I will post more images and schematics but how do you put it all together? So some helpful tips.
Connect the power supply to at least very 2 segments in what is called âpower injectâ, these is because of the resistance found in the strips so you give the singal a âboostâ or you will get lost color spectrum / no light at all. Again this is very dependant on your exact setup. Also for the love of god, make sure(really sure) that you connect the led strips ground to ground and power to power, I can assure you they will burn otherwise(not that it happened to me âŠ).
Ok so after connected to strips together, you need to make sure that each 2 strips(or how many you have connected together before power inject) has the same ground as the rest, as well as your microcontroller!
Each strip(stair in my case) is also connected via the datacable, the middle one on the strip. All the way from the first to the last, and of cause connected from your microntroller so you can actually control your lights.
That is all for the hardware side. Letâs talk software!
here is the esp script for reference:
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "Your wifi ssid"
password: "cvjgsn"
ap:
ssid: "Trappan Ljuskontroller"
password: "apassword"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
light:
- platform: neopixelbus
type: GRBW
pin: GPIO3
num_leds: 551
variant: SK6812
- platform: partition
segments:
- id: light1
to: 45
segments:
- id: light1
to: 90
segments:
- id: light1
to: 136
segments:
- id: light1
to: 182
segments:
- id: light1
to: 228
segments:
- id: light1
to: 274
segments:
- id: light1
to: 320
segments:
- id: light1
to: 366
segments:
- id: light1
to: 412
segments:
- id: light1
to: 458
segments:
- id: light1
to: 504
segments:
- id: light1
to: 550
I almot forgot, we need some automtion thrown to this! For this I have 2 motion sensor, I guess you could just buy some off the shelf stuff for this. However, I wanted to make sure that the motion was just under the ceiling, so not for too much of the room. To build this:
Another esp8266 . Hook it up to a motion sensor like this:
3 HC-SR501 Human Body Sensor Module Pyroelectric Sensor Infrared PIR Motion Sensor Detector Module for Arduino Raspberry Pi or Arduino Projects
This one is very easy to connect. Just connect the power output/ground from your microcontroller to the 2 pip sensors (see their descriptions) as well as the data channel to two inputs (1 for each controller). Then we leveredge ESPHome again like this:
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: "yyourssid"
password: "pass"
ap:
ssid: "Trappan Rorelsekontroller"
password: "pass"
captive_portal:
# Enable logging
logger:
api:
password: "pass"
ota:
password: "pass"
binary_sensor:
- platform: gpio
pin: GPIO35
name: "kallare rorelse uppe"
device_class: motion
- platform: gpio
pin: GPIO34
name: "kallare rorelse nere"
I must say this was the easiest part to get up and running. You can probably find a lot of implementations about making your own motion sensor, anything that you can get events from works.
So lets tie it all together shall we. For this letâs go for Node-RED. Sorry itâs in swedish but you can probably use google transalte. Anyway for pseudo code it works like this.
On motion detected (depending of from top or from bottom). Start a counter and every 250ms send signal to light_#counterid# which will turn on a staircase step (a light_counterid defined a range of adressable LED idâs, defined in the ESPHome configuration). So every 250 a new step will light up. THen when all are done, turn of the lights. And you are done!!!
[{"id":"3cbabfe0.a058b","type":"tab","label":"Trappljus","disabled":false,"info":""},{"id":"821a76c2.5b1718","type":"inject","z":"3cbabfe0.a058b","name":"Rörelse uppifrĂ„n","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":220,"wires":[["78066bbf.65af84"]]},{"id":"d9bec921.9553a8","type":"api-call-service","z":"3cbabfe0.a058b","name":"","server":"3e9f1d25.42bab2","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"","data":"{\"brightness\":255,\"rgb_color\":[255,0,0]}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":890,"y":480,"wires":[["58171478.c863bc"]]},{"id":"78066bbf.65af84","type":"trigger","z":"3cbabfe0.a058b","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-500","extend":false,"units":"ms","reset":"","bytopic":"all","name":"Skicka signal varje 250 millisekunder","x":410,"y":380,"wires":[["9e4e763b.87ebe8"]]},{"id":"742f02f.5b778fc","type":"function","z":"3cbabfe0.a058b","name":"SĂ€tt identitetsid frĂ„n rĂ€knare","func":"msg.payload = {};\nmsg.payload.data = {};\nif(msg.reverse) {\n msg.payload.data.entity_id = \"light.trappljuset_\"+(13-msg.count);\n\n \n}\nelse {\nmsg.payload.data.entity_id = \"light.trappljuset_\"+msg.count;\n\n}\nreturn msg;","outputs":1,"noerr":0,"x":816.444465637207,"y":617.3333168029785,"wires":[["58171478.c863bc","d9bec921.9553a8"]]},{"id":"f4c40429.8aa548","type":"switch","z":"3cbabfe0.a058b","name":"Ăr rĂ€knareid mellan 1 och 12","property":"count","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"14","vt":"num"},{"t":"neq","v":"14","vt":"num"}],"checkall":"false","repair":false,"outputs":3,"x":496.44446563720703,"y":597.3333168029785,"wires":[[],["77eb4be9.d295e4","438a22e7.eeaebc"],["742f02f.5b778fc"]]},{"id":"77eb4be9.d295e4","type":"change","z":"3cbabfe0.a058b","name":"Ă„terstĂ€ll rĂ€knare och trigger","rules":[{"t":"set","p":"reset","pt":"msg","to":"0","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":636.444465637207,"y":297.3333168029785,"wires":[["9e4e763b.87ebe8","78066bbf.65af84"]]},{"id":"29db5d08.f440c2","type":"api-call-service","z":"3cbabfe0.a058b","name":"","server":"3e9f1d25.42bab2","version":1,"debugenabled":true,"service_domain":"light","service":"turn_off","entityId":"","data":"{\"entity_id\":[\"light.trappljuset_1\",\"light.trappljuset_2\",\"light.trappljuset_3\",\"light.trappljuset_4\",\"light.trappljuset_5\",\"light.trappljuset_6\",\"light.trappljuset_7\",\"light.trappljuset_8\",\"light.trappljuset_9\",\"light.trappljuset_10\",\"light.trappljuset_11\",\"light.trappljuset_12\"]}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1010,"y":340,"wires":[["504cdb7c.3834a4"]]},{"id":"9e4e763b.87ebe8","type":"counter","z":"3cbabfe0.a058b","name":"RĂ€kna frĂ„n 1 och upp","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":400,"y":500,"wires":[["f4c40429.8aa548"]]},{"id":"58171478.c863bc","type":"debug","z":"3cbabfe0.a058b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1126.444465637207,"y":477.3333168029785,"wires":[]},{"id":"504cdb7c.3834a4","type":"debug","z":"3cbabfe0.a058b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1086.444465637207,"y":217.33331680297852,"wires":[]},{"id":"438a22e7.eeaebc","type":"delay","z":"3cbabfe0.a058b","name":"VĂ€nta 3 sekunder","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":766.444465637207,"y":397.3333168029785,"wires":[["504cdb7c.3834a4","29db5d08.f440c2"]]},{"id":"af5d11c2.cf7ad","type":"inject","z":"3cbabfe0.a058b","name":"Rörelse nerifrĂ„n","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":136.44446563720703,"y":517.3333168029785,"wires":[["9abdf329.bba83"]]},{"id":"9abdf329.bba83","type":"function","z":"3cbabfe0.a058b","name":"","func":"msg.reverse = true;\nreturn msg;","outputs":1,"noerr":0,"x":106.44446563720703,"y":357.3333168029785,"wires":[["78066bbf.65af84"]]},{"id":"3e9f1d25.42bab2","type":"server","z":"","name":"Home Assistant"}]
2 images, one of the light controller and 1 image of the staircase (including what happens if led is not powered correctly/data doesnât work)
Ok, so I did a superduper quick movie some time ago, enjoy (music not included ):
https://streamable.com/02knwm
This isnât true. The first addressable chip takes 3.3v data in and buffers the signal (to 5v) on itâs data out line to the next chip.
That sure did not work for me. I got the same error as explained here
I remembered incorrectly. Thereâs a caveat. You have to drop the Vcc voltage of the first LED With a diode, like this:
Awesome write up of your project! Canât wait for the schematics and more pictures, although Iâm pretty sure how to wire it up.
One question though, how did you mount the PIR sensors?
Because you only want to light up the the stairs when you go up or down the stairs, not if you walk passed it.
I think it was this design on thingiverse https://www.thingiverse.com/thing:2489968 I modified it by adding a cylindrical/tube to decrease the field of view of the motion sensor. Only activated when you are directly under it. Works better than I expected. I can probably upload it to thingiverse later this week.
Ah, you put the sensor on the ceiling. I donât really want that as I have to pull cables over the ceiling. Underneath my stairs is accessible so I was thinking to put an IR sensor on the bottom and top steps. Just need to look which sensor is available for this.
I thought about the step approach. There are laser breakers, like burgler alarm stuff from movies. However they are quite expensive in comparison.
The PIR sensor I have used should work on the step approach but try to make it pointing towards the wall if possible as to not get accidental triggers.
Also, in a position so you donât accidently walk over it getting no trigger.
Yea I was thinking the same. I could do it with the PIR sensor, as the side of the steps are wood I could drill a hole so that only the dome of the PIR will fit, which should be surrounded by the wood so the field should be reduced by it. Otherwise adding a small cylindrical tube to decrease the field even more.
Very nice!
ButâŠ
Do you know what I think would be even nicer/cooler?
First step is LEDs 0-45.
Imagine you turn on LED 23 first. Then delay 10 ms and then turn on LEDs 22 and 24.
Then a new delay and the 21 and 25 and so on.
So when one stair is fully lit up the next middle LED will turn on (almost).
Wouldnât that be cool?
I know that will be so much work
If you want that approach you might as well do a continuous led lightup. There are built in functions for that, at least WLED has that. Then you only need basically 1 light group that includes all the lights.
I have no idea how to do what you describe however. Someone more fluent in ESPhome or WLED would have to answer that.
did you concider load cells? they are cheap and installing them could be less invasive.
