All the attributes below that are shown for cover.shutter_278
current_position: 50
current_power_w: 0
current_energy_kwh: 204.57
Vera Device Id: 278
friendly_name: Rullgardin
supported_features: 15
current_power_w: 0
Vera Device Id: 278
Ok, and the service is cover.set_cover_position, so this should work:
rullgardin_set_cover_position:
alias: Öppna rullgardin
sequence:
- condition: and
conditions:
- condition: state
entity_id: sensor.lilla_balkongen_dorr
state: 'Stängd'
- condition: template
value_template: "{{ is_state('cover.shutter_278', 'closed') }}"
- service: cover.set_cover_position
data_template:
entity_id: cover.shutter_278
position: "{{ position }}"
cover:
covers:
sovrummet_rullgardin:
friendly_name: "Rullgardin"
position_template: "{{ state_attr('cover.shutter_278', 'current_position') }}"
set_cover_position:
service: script.rullgardin_set_cover_position
data_template:
open_cover:
service: script.oppna_rullgardin
close_cover:
service: script.stang_rullgardin
stop_cover:
service: script.stoppa_rullgardin
Then it must be something else, because it doesn’t work.
Also it complains when having both position- and value templates, as we established before.
yeah because i copied my last code. Try it again without the value_template.
Just to be clear, you’re placing the scripts in the scripts section and the cover template in the cover section?
Yes I have, they’re in the right places.
I’ve included my scripts…but cover is directly in configuration.yaml
script: !include_dir_merge_named scripts
Other scripts work, open, close and stop, but not the one we are struggling with now.
So the script doesn’t work? I don’t have this hardware so I can’t test anything
Are there any errors in the logs when you move the slider?
Scripts work, just not the one below…but the other ones do work!
alias: Sätt rullgardin till X%
sequence:
- condition: and
conditions:
- condition: state
state: 'Stängd'
- service: cover.set_position
data_template:
Yes, I updated it but you didn’t.
Hah, that was a sneaky one…I’ll try right away!
Didn’t make any difference…the slider still won’t work…
are there errors in your logs?
No errors…and it validates fine.
No when you move the slider. There has to be errors if it’s not changing your other cover.
Solved it!
I removed the condition below and now it works as expected!
# - condition: template
# value_template: "{{ is_state('cover.shutter_278', 'closed') }}"
#rullgardin_set_cover_position:
# alias: Sätt rullgardin till X%
# sequence:
# - condition: and
# conditions:
# - condition: state
# entity_id: sensor.lilla_balkongen_dorr
# state: 'Stängd'
# - service: cover.set_cover_position
# data_template:
# entity_id: cover.shutter_278
# position: "{{ position }}"
sequence:
- condition: state
state: 'Stängd'
data_template:
Ah ok, I thought you wanted that in your script. Sorry! Anyways, it seems to be working all around now?
Yes, it works as expected now, I’ve tried every scenario I can think of, and the the most important is working, that it doesn’t close when the door is open
Thanks for all your help, sent you a coffee
Oh thank you!
You’re welcome
