Now my problem is the same as many here ; I can see hci0 being up and working, but the home assistant integration I wanted (xiaomi BLE) says “No unconfigured Bluetooth adapters found”, my understanding from these discussions is that all integrations don’t work?
I’ve upgraded my NAS to 7.2 lately, i can confirm it is working fine, one thing that i did some time ago cause i had some issues with HASS it is that my container is running with network mode set to host.
Thanks for this. Are you able to share instructions on how to compile the modules or point me to links with resources on how to do it? Apart from bluetooth, I’m hoping I can also get my DVB-T USB tuners working.
Hi guys… I managed to get my bluetooth adapters to show up in home assistant following this thread. However, it comes up as “Failed setup, will retry”… when I check the logs it says:
" * Config entry ‘00:19:86:00:0B:79’ for bluetooth integration not ready yet: hci0 (00:19:86:00:0B:79): Failed to start Bluetooth: [org.freedesktop.DBus.Error.ServiceUnknown] The name org.bluez was not provided by any .service files; Retrying in background"
I used my DS1517+ to compile, inside an ubuntu docker container on DSM 7.1. I spent 2 days achieving this goal, but could not assemble the modules. Does anyone have AVOTON for DSM 7.2?
I assume that’s why I’m getting this error “Failed to start Bluetooth: [org.freedesktop.DBus.Error.ServiceUnknown] The name org.bluez was not provided by any .service files” ?
However, I’m still getting the same error "“Failed to start Bluetooth: [org.freedesktop.DBus.Error.ServiceUnknown] The name org.bluez was not provided by any .service files”
Unfortunately I am super noob with linux and cli. Are you guys installing BlueZ another way? Do I even need to install it?
Or does my issue have anything to do with the way I’m installing my Home Assistant? I’m using the following code:
