Using GPT-4o-Mini-Search-Preview with Voice Assist PE – Easy Workaround
This is a game changer for me. I found a very simple and effective way to integrate gpt-4o-mini-search-preview with my Voice Assist PE.
What can I do with it?
Voice Assist PE can now answer ANY question using web search. Pretty cool!
Examples:
- “How did Bayern play today?”
- “Is the cocktail bar Mojito open today?”
- “What’s the weather tomorrow?” (Location can be handed over via API request)
To trigger gpt-4o-mini-search-preview, you just need to use a specific trigger word or sentence.
How it works:
The core idea is simple: I set up a separate gpt-4o-mini-search-preview flow outside the normal assist pipeline.
- Define a trigger phrase, e.g.:
- “I have a question: How did Bayern play today?”
- “Question: How did Bayern play today?”
- Voice command with trigger phrase triggers an automation
- Automation saves the prompt to a text sensor
- Node-RED reads the prompt and sends an OpenAI API request
- Model: gpt-4o-mini-search-preview
- Location (if needed) is defined in the request
- Node-RED saves the response to a text sensor
- Automation detects the updated response and continues
- Voice Assist PE announces the response using
assist_satellite.announce
via TTS
alias: "Voice: Web Search"
description: ""
triggers:
- trigger: conversation
command:
- I have a question {websearch_prompt}
- Question {websearch_prompt}
conditions: []
actions:
- action: input_text.set_value
metadata: {}
value: "{{ trigger.slots.websearch_prompt }}"
entity_id: input_text.voice_web_search_prompt
- wait_for_trigger:
- trigger: state
entity_id:
- input_text.voice_web_search_prompt_response
- action: assist_satellite.announce
metadata: {}
message: "{{ states('input_text.voice_web_search_prompt_response') }}"
entity_id: assist_satellite.home_assistant_voice_xxxx_assist_satellit
NodeRed flow:
