John-H
(John Hansen)
November 11, 2023, 12:53pm
21
Yes i can connect with MQTT Explore
when i do a
sudo netstat -tuln | grep 1883
[sudo] password for nuc:
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN
tcp6 0 0 :::1883 :::* LISTEN
I have a Intel Nuc with ubuntu on on this i installed Docker + Docker-Compose + Portainer
My mosquitto.conf file is
persistence true
persistence_location /mosquitto/data/
log_dest file /mosquitto/log/mosquitto.log
listener 1883
log_timestamp_format %Y-%m-%dT%H:%M:%S
connection_messages true
log_type subscribe
log_type unsubscribe
log_type websockets
log_type error
log_type warning
log_type notice
log_type information
## Authentication ##
allow_anonymous true
password_file /mosquitto/config/password.txt
But i used to be
persistence true
listener 1883
allow_anonymous false
But i set it to allow anonymous true just to rule out the user and password
docker container port 4d0a9d742a3c
1883/tcp -> 0.0.0.0:1883
1883/tcp -> [::]:1883
9001/tcp -> 0.0.0.0:9001
9001/tcp -> [::]:9001
and my zigbee2mqtt.conf file looks like this
# Home Assistant integration (MQTT discovery)
homeassistant: true
# allow new devices to join
permit_join: true
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: zigbee2mqtt
# MQTT server URL
server: 'mqtt://192.168.50.131:1883'
# MQTT server authentication, uncomment if required:
user: mqttuser
password: *********
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: /dev/ttyACM0
John-H
(John Hansen)
November 11, 2023, 1:04pm
22
Here is what MQTT Explore looks like
malosaa
(Hector)
November 11, 2023, 1:05pm
23
What happens if u go into terminal, using the add-on from home assistant and then ping the ip of the mqtt server.
malosaa
(Hector)
November 11, 2023, 1:09pm
24
I found your issue
change this:
to this
server: http://192.168.50.131
this is my yaml, using Z2M addon in home-assistant
external_converters:
- ext_converter.js
devices:
- devices.yaml
groups:
- groups.yaml
homeassistant: true
permit_join: true
mqtt:
server: http://10.10.11.12
user: ''
password: ''
serial:
port: /dev/ttyUSB0
advanced:
log_level: info
pan_id: 704
channel: 20
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
homeassistant_legacy_entity_attributes: false
legacy_api: false
legacy_availability_payload: false
log_syslog:
app_name: Zigbee2MQTT
eol: /n
host: localhost
localhost: localhost
path: /dev/log
pid: process.pid
port: 123
protocol: tcp4
type: '5424'
transmit_power: 20
device_options:
legacy: false
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
availability:
active:
timeout: 10
passive:
timeout: 1500
John-H
(John Hansen)
November 11, 2023, 1:19pm
25
I changed
to
But i still get this
MQTT error: connect ECONNREFUSED 127.0.0.1:1883
I will spend some time to try to understand your yaml file and what Z2M is
Tnx for helping me out
John-H
(John Hansen)
November 11, 2023, 1:41pm
26
When i connect with MQTT explore i connect to
and MQTT look at
I will figure out how to ping in home ass ( i am new to this )
malosaa
(Hector)
November 11, 2023, 2:27pm
28
Thats a bit weird, why would it say
instead of
MQTT error: connect ECONNREFUSED 192.168.50.131:1883
Are you using the correct configuration file from Zigbee2Mqtt ?
its located here if u use the file editor add-on
no worries, i’m glad i can help out.
Lets try to solve your problem
John-H
(John Hansen)
November 11, 2023, 3:14pm
29
the zigbee2mqtt file is located
nuc@nucbox:/opt/zigbee2mqtt/data/data$ ls
configuration.yaml
and i docker-compose
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
restart: unless-stopped
volumes:
- /opt/zigbee2mqtt/data/data:/app/data
- /run/udev:/run/udev:ro
ports:
# Frontend port
- 8080:8080
environment:
- TZ=Europe/Copenhagen
devices:
- /dev/ttyACM0:/dev/ttyACM0
malosaa
(Hector)
November 11, 2023, 3:30pm
30
According to Zigbee2Mqtt it stores the data here:
* `-v $(pwd)/data:/app/data`: Directory where Zigbee2MQTT stores it configuration (pwd maps to the current working directory)
i’m not 100% sure if it can work in n other location, but try to see if there is an configuration.yaml in that directory.
because whatever IP u enter it still gives the same error, that’s why its odd it gives this error:
John-H
(John Hansen)
November 11, 2023, 3:50pm
31
Ok now u got me
Can u tell me how to find that dir ?
Here is where i got all dir
John-H
(John Hansen)
November 11, 2023, 3:55pm
32
And 100 % agree don’t understand why i look for
instead of
but worse where to edit it
malosaa
(Hector)
November 11, 2023, 5:17pm
33
haha no worries,
well i’m not a linux or docker specialist but i think its located in the container itself.
when checking in the container of zigbee2mqtt and look for the folder app/data it should be in there.
The configuration.yaml
file for Zigbee2MQTT would typically be located in the ./data
directory on your host machine, based on this volume mount.
and i’m 100% sure if u edit the file in there it would work.
but i also found this article, check the top part.
https://www.libe.net/en-zigbee2mqtt#start-docker-container-with-zigbee2mqtt
malosaa
(Hector)
November 11, 2023, 5:28pm
34
this is the correct url, it won’t let me edit my post…
half way trough u see this:
Running Zigbee2Mqtt As A Docker Container.
correct url:
John-H
(John Hansen)
November 11, 2023, 7:31pm
35
A cording to the guide you linked to. Where is ./data located ?
volumes:
- ./data:/app/data
In the guide he says :
For this create the a data
folder in the same directory where your docker-compose.yaml
file is present and then create a configuration.yaml
file inside the data
folder with the following content
This gets me confused does the data folder need to bee in the /opt
folder like docker-compose.yaml
mine is currently in
John-H
(John Hansen)
November 11, 2023, 8:05pm
36
I tried with the configuration.yaml
from the guide
permit_join: true
mqtt:
server: mqtt://192.168.50.131:1883
serial:
port: /dev/ttyACM0
frontend: true
advanced:
legacy_api: false
device_options:
legacy: false
devices: {}
homeassistant:
legacy_entity_attributes: true
legacy_triggers: true
and i still get
malosaa
(Hector)
November 12, 2023, 11:14am
37
Thats relly weird, i think that guide from that youtuber has an actual step-by-step video.
Maybe it can help you a bit better.
I really don’t know why it doesnt work, but i’m 100% use you are editing the wrong config file.
Let me see if i find some more info.
malosaa
(Hector)
November 12, 2023, 11:16am
38
For some weird reasons i can’t edit my posts.
here is the video, its from last month so UpToDate.
never seen this guy before but the tutorial is good.
here it is
malosaa
(Hector)
November 12, 2023, 12:01pm
39
Ok, i was thinking something crazy.
What if u gonna test it with the Z2M add-on store in home assistant itself ?
If it works than its 100% an issue with editing the wrong config / or setting Z2M up wrong in docker.
Go to Addons → click addons store > 3 dots
Add this repository
https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
And download the first one not Proxy and EDGE = beta
John-H
(John Hansen)
November 12, 2023, 1:31pm
40
I solved it or got it working i guess is the properly term
I nuked the box installed proxmox and now its all working all happy days
Thank you for your time and effort to try to resolve this
