Thank you very much.
@andersonshatch I got it working, thank you! Just wondering do you run it on startup? If my raspberry pi restarts Iād like somactrl to start again. Thanks!
At the moment I just have it running in a while true loop that I leave running in a screen session via SSH.
Itās far from ideal, but I havenāt yet found anything good to make startup scripts for macOS and *nix for node apps ā not that Iāve spent much time looking ā but my server is not restarted that often for it to be very inconvenient
If anyone has any suggestions for something like that, Iām all ears!
Just released version 1.1.0 which adds support for device registry data, so in Configuration -> Integrations -> MQTT you should see something like this:
ā¦Youāll need at least version 0.81 of HASS for this to be supported.
Additionally, the unique_id parameter is now passed along with the discovery data, so you can rename and change the entity_id from within HASS.
Iāve installed on a rpi3b+ successfully, but i canāt get it to detect the blinds, what am I doing wrong?
any help appreciated.
Hmmā¦ have you used Bluetooth on the pi with anything else?
Iām not sure if my tool can turn on Bluetooth if itās not yet been enabled by something (possibly just you running a command with something installed by bluez I guess ā still havenāt tried it myself on a pi so am not 100% sure)
What output do you get when running with DEBUG=noble at the front of your command?
E.g.:
DEBUG=noble somactrl -l 3000
hey, thanks, heres the output:
pi@raspberrypi:~ $ sudo DEBUG=noble somactrl -l 3000
soma* No device names supplied, will stop scanning after 30 seconds +0ms
soma* scanning for as many devices until timeout +8ms
noble addressChange b8:27:eb:4e:8b:5f +0ms
noble stateChange poweredOn +3ms
noble scanStart +5ms
soma* stopping scan after timeout +31s
soma* No devices found, exiting +2ms
Looks ok, at least the bluetooth adapter power was on.
Have you setup the blind devices in the iOS / Android app first?
Could range be an issue?
yeah i have, pi is literally sitting beside the soma.
should i try old pi? or older debian distro?
these are also brand new, hopefully its not new firmware or somethingā¦
Okā¦ one last thing to checkā¦ was the soma app on your smart phone closed when you were trying to use the tool on your pi?
If it was still open, it can maintain a connection and that means the device will not be advertising itself for other connections.
Otherwise, I think we should move this to a GitHub issue, maybe you can export the logs from the soma app for me to examine. You can do that by pressing on the header a few times where the group name is displayed, and then a log window opens allowing you to copy the text out.
Just released v1.1.1 which includes a fix to the discovery data that will be needed for 0.82.0 of hass
If you upgrade to 0.82.0 and the soma devices no longer show up and cause errors, please update to v1.1.1 of soma-ctrl
Hey, if soma have changed the ble device idās, will detection fail?
From what I can tell, the idās of my blinds are f023c6wu and f023c6faā¦
Yeah, if they are not using RISE_nnn_ anymore, then they will not be discovered, and right now you can only manually specify IDs with RISE_nnn_ format as well.
Open a GitHub issue with some more details, maybe the log from the smartphone app and I can have a think about how to adjust to this.
Does this project still work? How about the Soma itself? Good product? Looking at getting one as an Xmas present
Still works for me at least, and Iām happy with the devices themselves, itās nice to have automatic control of the blinds; open at sunrise, close around sunset, keep the sun out of your eyes when itās bright.
Awesome! Thanks for the info. I think Iāll pull the trigger
got it working in a docker node-red but canāt connect any device as the host nomes have apperently changedā¦
BLE Scan provides the following info:
[NEW] Device E2:E4:81:69:E8:05 S
[NEW] Device FD:BD:B4:7F:4F:7A S
Anyway this can be fixed in the somactrl?
Hello, could someone provide the dockerfile used to make it works ?
Hey
I have the standard node red docker running. My docker-compose:
nodered:
container_name: node-red
restart: unless-stopped
image: nodered/node-red-docker:v8
user: ārootā
volumes:
- /srv/docker/node-red:/data
- /etc/localtime:/etc/localtime:ro
ports:
- ā1880:1880ā
network_mode: host
within this I have installed the soma-ctrl and start it at command line for testing purposes
The problem Iām having with this setup (running Hass & node red on the same host) is that the somactrl takes posession of the ble stack and HASS cannot reach any devices ā¦ so that is a no go for me
If anybody has a solution to this I would be very happyā¦ now Iām planning to dig out one of my raspiās and install it on thereā¦
Just published v1.3.0 with (hopefully!) a few stability improvements https://github.com/andersonshatch/soma-ctrl/releases/tag/v1.3.0
Time to npm update -g soma-ctrl
