Some help needed in combining multiple window cover automations based on azimuth into one single automation
It’s right if you want it to behave differently from the original version (because your version produces different results).
Copy-paste this into the Template Editor and experiment with it:
{% set a = 230 %} {{ a }}
The original version:
{% if a < 80 -%} 0
{% elif a >= 80 and a < 170 -%} 100
{% elif a >= 170 and a < 220 -%} {{ (((-2*a+440)/10)|int)*10 }}
{% elif a >= 220 and a <= 250 -%} 0
{% elif a > 250 and a <= 300 -%} {{ (((2*a-500)/10)|int)*10 }}
{% else -%} 100
Revised version:
{%- set values = { 80: 0,
                  170: 100,
                  220: (((-2*a+440)/10)|int(0))*10,
                  251: 0,
                  301: (((2*a-500)/10)|int(0))*10 } %}
{{ values.get(values.keys() | select('>', a) | first, 100) }}
Your version:
{%- set values = { 0: 0,
                  79: 100,
                  170: (((-2*a+440)/10)|int(0))*10,
                  220: 0,
                  250: (((2*a-500)/10)|int(0))*10,
                  301: 100 } %}
