@florian.drevet
Hi
I progressed and was able to fix my issue by configuring the correct credential
The proxy seems to connect and try to retrieve the data, but I have a lot of warning. See below
Itâs related to DM, but I donât know whatâs that element.
Note : Iâm also french, so same configuration as you I guess
Note : When I log to http://localhost:8093 I get below message as expected :
{âversionâ:â1.0.0â,âdescriptionâ:ââ}
I then installed your Gateway, configured it and seems dtat are sent to my Broker
Itâs looks so really promising. I will check now what I get under HA and will let you know.
Warning message that I got whn started th proxy:
Blockquote
warn: SomfyProtexialIO.Implementations.API.SomfyProtexialClientWebScrapping[0]
A known error occured when fetching element with code â285104â (name âSalonâ)
Element label âDMâ is not handled yet, handled ones are : âTr TĂ©lâ, âCl lcdâ, âTC 4â, âSir extâ, âSir intâ, âDM imageâ, âDOâ, âDO vitreâ, âBadgeâ, âTC 2â, âTahomaâ
A known error occured when fetching element with code â285121â (name âChambreâ)
A known error occured when fetching element with code â219935â (name âBureau Isaâ)
A known error occured when fetching element with code â219936â (name âHall Entreeâ)
A known error occured when fetching element with code â286016â (name âGarageâ)
A known error occured when fetching element with code â289531â (name âCouloirâ)
info: SomfyProtexialIO.StateCache.Jobs.AlarmStateCacheUpdateJob[0]
12 elements successfully fetched because at least one door / window is opened
Fetching elements because at least one door / window is openedâŠ
