Hi Florian,
I am not sure if it is only me but it seems with update to the latest Home Assistant version the Add On is broken.
fail: SomfyProtexialIO.StateCache.Jobs.AlarmConnectionJob[0]
Exception in AlarmConnectionJob (Somfy Protexial IO Proxy REST API (server 192.168.178.123:8093))
One or more errors occurred. (No route to host)
info: SomfyProtexialIO.Gateway.PlugIns.HomeAssistant.Jobs.MqttPublisherJob[0]
Alarm never connected yet, cannot initialize plug-in...
info: SomfyProtexialIO.StateCache.Jobs.AlarmStateCacheUpdateJob[0]
Never connected via Somfy Protexial IO Proxy REST API (server 192.168.178.123:8093), waiting for connection to update cache
info: SomfyProtexialIO.Gateway.PlugIns.Jobs.MqttConnectionJob[0]
MQTT client not connected to MQTT broker '192.168.178.123:1883'
Trying to connect to MQTT broker '192.168.178.123:1883' as client '22c4084a-488e-4b6a-bbe6-0361b492da14'...
fail: SomfyProtexialIO.Gateway.PlugIns.Jobs.MqttConnectionJob[0]
Cannot connect to MQTT broker 192.168.178.123:1883
Exception connecting to the broker
at uPLibrary.Networking.M2Mqtt.MqttClient.Connect(String clientId, String username, String password, Boolean willRetain, Byte willQosLevel, Boolean willFlag, String willTopic, String willMessage, Boolean cleanSession, UInt16 keepAlivePeriod)
at Initia.Mqtt.M2Mqtt.M2MqttClient.Connect(String clientId, String username, String password)
at SomfyProtexialIO.Gateway.PlugIns.Jobs.MqttConnectionJob.Execute(IJobExecutionContext context)
