The “path” leads to complex JSON data when all you want is one element. So you have to use jinja template to extract the data of interets.
Hi!
now I’m trying to set the Em_OperatingMode to manual. I can do it with this curl command:
curl -X PUT -d EM_OperatingMode=1 --header 'Auth-Token: TOKEN' http://sonnen:80/api/v2/configurations
And I get the appropriate response:
{"EM_OperatingMode":"1"}
I would like to have it as a switch though:
switch:
- name: Sonnen battery manual mode
platform: rest
resource: http://sonnen:80/api/v2/configurations
method: put
headers:
Auth-Token: !secret sonnen_api_token
body_on: "EM_OperatingMode=1"
body_off: "EM_OperatingMode=2"
is_on_template: '{{ value_json["EM_OperatingMode"] == "1" }}'
But it doesn’t work. In the logs I only get:
ERROR (MainThread) [homeassistant.components.rest.switch] Can't turn on http://sonnen:80/api/v2/configurations. Is resource/endpoint offline?
Any clues?
I think the problem lies in how you’re specifying the body_on and body_off parameters.
In your curl command, you’re using -d EM_OperatingMode=1, which sends a JSON payload to the API. However, in your Home Assistant configuration, you’ve specified body_on: "EM_OperatingMode=1" and body_off: "EM_OperatingMode=2", without any indication that these should be treated as JSON payloads.
When you send a request with these values, it’s likely being interpreted as a query string (e.g. http://sonnen:80/api/v2/configurations?EM_OperatingMode=1) instead of a JSON payload. This is why the API is not receiving the expected data and returning an error.
To fix this, you should use the following configuration:
switch:
platform: rest
method: put
headers:
body_on: '{"EM_OperatingMode": "1"}'
body_off: '{"EM_OperatingMode": "2"}'
By surrounding the values with double quotes and curly braces, you’re telling Home Assistant to treat them as JSON payloads.
Hi!
thanks for the answer, but unfortunately it didn’t work. I get the same log output and nothing happens in the battery. I also got this working in HTTPie (GUI) and I had to specify that the payload is Form data:
PUT /api/v2/configurations HTTP/1.1
Auth-Token: TOKEN
Content-Length: 18
Content-Type: application/x-www-form-urlencoded
Host: sonnen
User-Agent: HTTPie
EM_OperatingMode=2
So I guess we need to tell HA somehow to send the payload as form data, which, turns out you can do with a header:
switch:
platform: rest
method: put
headers:
This worked for me.
Thanks for the hint!!
Hi again,
I have been using this config to monitor and control the status of my Sonnen battery. Thought I’d just share this here for anyone interested.
I took most of it from other sources that now I can’t find again, so huge thanks to everybody who somehow contributed.
rest:
- resource: http://IP_of_Battery:80/api/v2/status
headers:
scan_interval: 15
- name: Sonnen Apparent_output
unique_id: sonnen_status_Apparent_output
value_template: '{{ value_json.Apparent_output | int(None) }}'
unit_of_measurement: VA
device_class: apparent_power
state_class: measurement
- name: Sonnen BackupBuffer
unique_id: sonnen_status_BackupBuffer
value_template: '{{ value_json.BackupBuffer | int(None) }}'
unit_of_measurement: '%'
- name: Sonnen Consumption_Avg
unique_id: sonnen_status_Consumption_Avg
value_template: '{{ value_json.Consumption_Avg | int(None) }}'
unit_of_measurement: W
device_class: power
- name: Sonnen Consumption_W
unique_id: sonnen_status_Consumption_W
value_template: '{{ value_json.Consumption_W | int(None) }}'
device_class: power
- name: Sonnen Fac
unique_id: sonnen_status_Fac
value_template: '{{ value_json.Fac | int(None) }}'
unit_of_measurement: Hz
device_class: frequency
- name: Sonnen GridFeedIn_W
unique_id: sonnen_status_GridFeedIn_W
value_template: '{{ value_json.GridFeedIn_W | int(None) }}'
device_class: power
- name: Sonnen OperatingMode
unique_id: sonnen_status_OperatingMode
value_template: >
{% if value_json.OperatingMode == "1" %}
Manual charging or discharging via API
{% elif value_json.OperatingMode == "2" %}
Automatic Self Consumption
{% else %}
{{ None }}
{% endif %}
device_class: enum
- name: Sonnen Pac_total_W
unique_id: sonnen_status_Pac_total_W
value_template: '{{ value_json.Pac_total_W | int(None) }}'
device_class: power
- name: Sonnen Production_W
unique_id: sonnen_status_Production_W
value_template: '{{ value_json.Production_W | int(None) }}'
device_class: power
- name: Sonnen RSOC
unique_id: sonnen_status_RSOC
value_template: '{{ value_json.RSOC | int(None) }}'
device_class: battery
- name: Sonnen RemainingCapacity_Wh
unique_id: sonnen_status_RemainingCapacity_Wh
value_template: '{{ value_json.RemainingCapacity_Wh | int(None) }}'
unit_of_measurement: Wh
device_class: energy_storage
- name: Sonnen Sac1
unique_id: sonnen_status_Sac1
value_template: '{{ value_json.Sac1 | int(None) }}'
- name: Sonnen SystemStatus
unique_id: sonnen_status_SystemStatus
value_template: '{{ value_json.SystemStatus }}'
device_class: enum
- name: Sonnen Timestamp
unique_id: sonnen_status_Timestamp
value_template: '{{ strptime(value_json.Timestamp, "%Y-%m-%d %H:%M:%S") | as_local }}'
device_class: timestamp
- name: Sonnen USOC
unique_id: sonnen_status_USOC
value_template: '{{ value_json.USOC | int(None) }}'
- name: Sonnen Uac
unique_id: sonnen_status_Uac
value_template: '{{ value_json.Uac | int(None) }}'
device_class: voltage
- name: Sonnen Ubat
unique_id: sonnen_status_Ubat
value_template: '{{ value_json.Ubat | int(None) }}'
binary_sensor:
- name: Sonnen BatteryCharging
unique_id: sonnen_status_BatteryCharging
value_template: '{{ value_json.BatteryCharging }}'
device_class: battery_charging
- name: Sonnen BatteryDischarging
unique_id: sonnen_status_BatteryDischarging
value_template: '{{ value_json.BatteryDischarging }}'
device_class: power
- name: Sonnen FlowConsumptionBattery
unique_id: sonnen_status_FlowConsumptionBattery
value_template: '{{ value_json.FlowConsumptionBattery }}'
device_class: power
- name: Sonnen FlowConsumptionGrid
unique_id: sonnen_status_FlowConsumptionGrid
value_template: '{{ value_json.FlowConsumptionGrid }}'
device_class: power
- name: Sonnen FlowConsumptionProduction
unique_id: sonnen_status_FlowConsumptionProduction
value_template: '{{ value_json.FlowConsumptionProduction }}'
device_class: power
- name: Sonnen FlowGridBattery
unique_id: sonnen_status_FlowGridBattery
value_template: '{{ value_json.FlowGridBattery }}'
device_class: power
- name: Sonnen FlowProductionBattery
unique_id: sonnen_status_FlowProductionBattery
value_template: '{{ value_json.FlowProductionBattery }}'
- name: Sonnen FlowProductionGrid
unique_id: sonnen_status_FlowProductionGrid
value_template: '{{ value_json.FlowProductionGrid }}'
device_class: power
- name: Sonnen IsSystemInstalled
unique_id: sonnen_status_IsSystemInstalled
value_template: '{{ value_json.IsSystemInstalled }}'
- name: Sonnen dischargeNotAllowed
unique_id: sonnen_status_dischargeNotAllowed
value_template: '{{ value_json.dischargeNotAllowed }}'
- name: Sonnen generator_autostart
unique_id: sonnen_status_generator_autostart
value_template: '{{ value_json.generator_autostart }}'
- resource: http://IP_of_Battery/api/v2/powermeter
headers:
scan_interval: 15
- name: Sonnen solar production Wh
unique_id: sonnen_powermeter_solar_production
# json_attributes_path: "$[0]"
value_template: '{{ value_json[0].kwh_imported }}'
- name: Sonnen house consumption Wh
unique_id: sonnen_powermeter_house_consumption
# json_attributes_path: "$[1]"
value_template: '{{ value_json[1].kwh_imported }}'
- resource: http://IP_of_Battery:80/api/v2/battery
headers:
scan_interval: 15
- name: Sonnen chargecurrentlimit
unique_id: sonnen_battery_chargecurrentlimit
value_template: '{{ value_json.chargecurrentlimit }}'
unit_of_measurement: A
device_class: current
- name: Sonnen cyclecount
unique_id: sonnen_battery_cyclecount
value_template: '{{ value_json.cyclecount | int(None) }}'
- name: Sonnen dischargecurrentlimit
unique_id: sonnen_battery_dischargecurrentlimit
value_template: '{{ value_json.dischargecurrentlimit }}'
- name: Sonnen fullchargecapacity
unique_id: sonnen_battery_fullchargecapacity
value_template: '{{ value_json.fullchargecapacity }}'
unit_of_measurement: Ah
- name: Sonnen fullchargecapacitywh
unique_id: sonnen_battery_fullchargecapacitywh
value_template: '{{ value_json.fullchargecapacitywh }}'
- name: Sonnen maximumcelltemperature
unique_id: sonnen_battery_maximumcelltemperature
value_template: '{{ value_json.maximumcelltemperature }}'
unit_of_measurement: '°C'
device_class: temperature
- name: Sonnen maximumcellvoltage
unique_id: sonnen_battery_maximumcellvoltage
value_template: '{{ value_json.maximumcellvoltage }}'
- name: Sonnen maximumcellvoltagenum
unique_id: sonnen_battery_maximumcellvoltagenum
value_template: '{{ value_json.maximumcellvoltagenum }}'
device_class: enum
- name: Sonnen maximummodulecurrent
unique_id: sonnen_battery_maximummodulecurrent
value_template: '{{ value_json.maximummodulecurrent }}'
- name: Sonnen maximummoduledcvoltage
unique_id: sonnen_battery_maximummoduledcvoltage
value_template: '{{ value_json.maximummoduledcvoltage }}'
- name: Sonnen maximummoduletemperature
unique_id: sonnen_battery_maximummoduletemperature
value_template: '{{ value_json.maximummoduletemperature }}'
- name: Sonnen minimumcelltemperature
unique_id: sonnen_battery_minimumcelltemperature
value_template: '{{ value_json.minimumcelltemperature }}'
- name: Sonnen minimumcellvoltage
unique_id: sonnen_battery_minimumcellvoltage
value_template: '{{ value_json.minimumcellvoltage }}'
- name: Sonnen minimumcellvoltagenum
unique_id: sonnen_battery_minimumcellvoltagenum
value_template: '{{ value_json.minimumcellvoltagenum }}'
device_class: enum
- name: Sonnen minimummodulecurrent
unique_id: sonnen_battery_minimummodulecurrent
value_template: '{{ value_json.minimummodulecurrent }}'
- name: Sonnen minimummoduledcvoltage
unique_id: sonnen_battery_minimummoduledcvoltage
value_template: '{{ value_json.minimummoduledcvoltage }}'
- name: Sonnen minimummoduletemperature
unique_id: sonnen_battery_minimummoduletemperature
value_template: '{{ value_json.minimummoduletemperature }}'
- name: Sonnen nominalmoduledcvoltage
unique_id: sonnen_battery_nominalmoduledcvoltage
value_template: '{{ value_json.nominalmoduledcvoltage }}'
- name: Sonnen relativestateofcharge
unique_id: sonnen_battery_relativestateofcharge
value_template: '{{ value_json.relativestateofcharge }}'
- name: Sonnen remainingcapacity
unique_id: sonnen_battery_remainingcapacity
value_template: '{{ value_json.remainingcapacity }}'
- name: Sonnen systemaveragecurrent
unique_id: sonnen_battery_systemaveragecurrent
value_template: '{{ value_json.systemaveragecurrent }}'
- name: Sonnen systemcurrent
unique_id: sonnen_battery_systemcurrent
value_template: '{{ value_json.systemcurrent }}'
- name: Sonnen systemdcvoltage
unique_id: sonnen_battery_systemdcvoltage
value_template: '{{ value_json.systemdcvoltage }}'
- name: Sonnen systemstatus
unique_id: sonnen_battery_systemstatus
value_template: '{{ value_json.systemstatus | int(None) }}'
- name: Sonnen usableremainingcapacity
unique_id: sonnen_battery_usableremainingcapacity
value_template: '{{ value_json.usableremainingcapacity }}'
binary_sensor:
- name: Sonnen balancechargerequest
unique_id: sonnen_battery_balancechargerequest
value_template: '{{ value_json.balancechargerequest }}'
- name: Sonnen systemalarm
unique_id: sonnen_battery_systemalarm
value_template: '{{ value_json.systemalarm }}'
device_class: problem
- name: Sonnen systemtime
unique_id: sonnen_battery_systemtime
value_template: '{{ value_json.systemtime }}'
- name: Sonnen systemwarning
unique_id: sonnen_battery_systemwarning
value_template: '{{ value_json.systemwarning }}'
template:
- sensor:
- name: Sonnen discharge power
unique_id: sonnen_discharge_power
device_class: power
state: '{{ [0, states.sensor.sonnen_pac_total_w.state | int] | max }}'
- name: Sonnen charge power
unique_id: sonnen_charge_power
device_class: power
state: '{{ [0, states.sensor.sonnen_pac_total_w.state | int] | min | abs}}'
# For https://github.com/reptilex/tesla-style-solar-power-card#complete-example-with-all-details
- name: "Flow Solar to House"
unique_id: flow_solar_to_house
device_class: power
unit_of_measurement: "W"
# Assumption: all produced power is used first for the house.
state: '{{ [states.sensor.sonnen_consumption_w.state | int, states.sensor.sonnen_production_w.state | int] | min }}'
- name: "Flow Solar to Battery"
unique_id: flow_solar_to_battery
device_class: power
# Assumption: all produced power is used first for the house, so what remains can be used for charging (but might not be used for it).
state: '{{ [0, [states.sensor.sonnen_charge_power.state | int, states.sensor.sonnen_production_w.state | int - states.sensor.sonnen_consumption_w.state | int] | min ] | max }}'
- name: "Flow Solar to Grid"
unique_id: flow_solar_to_grid
device_class: power
# Assumption: all produced power is used first for the house, then the battery. What remains is feed to the grid.
state: '{{ [0, states.sensor.sonnen_production_w.state | int - states.sensor.sonnen_consumption_w.state | int - states.sensor.sonnen_charge_power.state | int] | max }}'
- name: "Flow Grid to Battery"
unique_id: flow_grid_to_battery
device_class: power
# Assumption: The missing enery for charging the battery must come from the grid.
state: '{{ [0, states.sensor.sonnen_charge_power.state | int - states.sensor.flow_solar_to_battery.state | int] | max }}'
- name: "Flow Grid to House"
unique_id: flow_grid_to_house
device_class: power
# Assumption: The missing enery for the house must come first from the battery.
state: '{{ [0, states.sensor.sonnen_consumption_w.state | int - states.sensor.sonnen_production_w.state | int - states.sensor.sonnen_discharge_power.state | int] | max }}'
- name: "Flow Battery to House"
unique_id: flow_battery_to_house
device_class: power
# Assumption: The remaining missing enery for the house must come from the grid.
state: '{{ [0, states.sensor.sonnen_consumption_w.state | int - states.sensor.sonnen_production_w.state | int - states.sensor.flow_grid_to_house.state | int] | max }}'
- name: "Flow Battery to Grid"
unique_id: flow_battery_to_grid
device_class: power
# Assumption: any unused battery power must go to the grid.
state: '{{ [0, states.sensor.sonnen_discharge_power.state | int - states.sensor.flow_battery_to_house.state | int] | max }}'
- name: Sonnen discharge energy
unique_id: sonnen_discharge_energy
platform: integration
source: sensor.sonnen_discharge_power
unit_prefix: k
method: left
- name: Sonnen charge energy
unique_id: sonnen_charge_energy
source: sensor.sonnen_charge_power
unit_prefix: k
method: left
binary_sensor:
- name: Sonnen power flow directions
unique_id: sonnen_power_flow_direction_booleans
platform: group
entities:
- binary_sensor.sonnen_flowconsumptionbattery
- binary_sensor.sonnen_flowconsumptiongrid
- binary_sensor.sonnen_flowconsumptionproduction
- binary_sensor.sonnen_flowgridbattery
- binary_sensor.sonnen_flowproductionbattery
- binary_sensor.sonnen_flowproductiongrid
switch:
platform: rest
resource: http://IP_of_Battery:80/api/v2/configurations
method: put
headers:
input_number:
sonnen_charge_setpoint:
name: Sonnen battery charge setpoint
min: -4000
initial: 0
max: 4000
step: 250
mode: slider
icon: mdi:power-plug-battery-outline
rest_command:
sonnen_battery_set_manual_power:
url: >
{% if states.input_number.sonnen_charge_setpoint.state | int >= 0 -%}
http://IP_of_Battery/api/v2/setpoint/charge/{{states.input_number.sonnen_charge_setpoint.state | int | abs}}
{%- else -%}
http://IP_of_Battery/api/v2/setpoint/discharge/{{states.input_number.sonnen_charge_setpoint.state | int | abs}}
{%- endif %}
method: post
headers:
automation:
- alias: "Update charge config on input change"
mode: single
triggers:
- entity_id:
- input_number.sonnen_charge_setpoint
trigger: state
- trigger: state
entity_id:
- switch.sonnen_battery_manual_mode
to: "on"
conditions:
- condition: state
entity_id: switch.sonnen_battery_manual_mode
state: "on"
actions:
- action: rest_command.sonnen_battery_set_manual_power
metadata: {}
data: {}
Hi!
I’m having some issues with the sonnen webhook API. I am successfully sending data with a webhook from the sonnen batterie 10 to node red. The problem is that I get “GridFeedIn_W”:0" from the webhook when it is clearly exporting to the grid. The same time I get GridFeedIn_W: 8130 from the JSON API.
The webhook is correctly sending data for SOC and for example “Consumption_W”:804.
Anyone else have this problem? Am I doing anything wrong?
Complete response from the webhook: https://bin.sibe.nu/GSnrn0PrCLf
Complete response fron json api: https://bin.sibe.nu/n5AMErqqJpa
Sonnen Software: 1.18.4, Release-Channel: stable
Hi all,
I’ve been working with my Sonnen system using the v2 local API to try to force battery discharge.
What I’m trying to do:
• Switch to Manual mode (EM_OperatingMode=1)
• Use POST /api/v2/setpoint/discharge/3300 to force approx 3.3 kW discharge
What I observe instead:
• When solar + battery total ≈3.3 kW, battery only supplies the “rest” (so solar + battery = ~3.3 kW)
• If solar > 0, the battery contribution is reduced. The system seems to treat the setpoint as total inverter output (Pac_total_W) rather than absolute battery discharge.
• I’ve verified that Manual mode is active, no ToU schedule is overriding, and still this behaviour appears.
What I’d like to know:
• Has anyone gotten true “battery only” discharge (battery → house/grid) via this endpoint on a similar firmware/hardware?
• Did you have to use a different endpoint, modbus register write, or installer-enabled firmware flag to get battery current control?
• Are there any hidden flags like dischargeNotAllowed / chargeNotAllowed that I should check?
• Any suggestions on how to force the battery to discharge regardless of solar contribution?
I can share detailed status logs, token behaviour, and what I’ve tried. Appreciate any pointers from those who have cracked this. Thanks in advance!
Yes I manage the charge and discharge rate of my battery in manual mode all the time. I use Node-Red to manage this and the EMS I use is EMHASS which is an add-on to HA that uses machine learning (MPC) to calculate bat charging and discharging and things like EV charging and pool pump operation.
But the battery API part is all Node-red and should be easily transcribed into HA rest_command YAML.
My docs are here
My shell commands:
set_operating_mode_sonnen_battery: curl -X PUT -d EM_OperatingMode={{ operating_mode }} --header 'Auth-Token{{':'}} {{ token }}' {{ api_endpoint }}
dis_charge_sonnen_battery: curl -d -H -X POST --header 'Auth-Token{{':'}} {{ token }}' {{ api_endpoint }}/{{dis_charge_command}}/{{ dis_charge_value }}
Automation examples:
- id: 'sonnen_8_manual_charge'
alias: "Sonnen 8 manual charge"
triggers: []
conditions: []
actions:
- action: shell_command.dis_charge_sonnen_battery
token: !secret sonnen_8_api_token
api_endpoint: !secret sonnen_8_setpoint_api_endpoint
dis_charge_command: charge
dis_charge_value: 0
mode: single
- id: 'sonnen_8_manual_operating_mode'
alias: "Sonnen 8 manual operating mode"
triggers: []
conditions: []
actions:
- action: shell_command.set_operating_mode_sonnen_battery
operating_mode: 1
api_endpoint: !secret sonnen_8_configurations_api_endpoint
mode: single
- id: 'sonnen_8_automatic_operating_mode'
alias: "Sonnen 8 automatic operating mode"
triggers: []
conditions: []
actions:
operating_mode: 2
mode: single
I've been dabbling with controlling my Sonnen battery (eco 8.2), using the many examples and approaches documented in this excellent thread (BIG THANKS to all the contributors).
One thing that I noticed is that when I send a setpoint discharge command to the battery with a value of 1500W or more, it reboots the inverter, taking the battery off-grid and unable to charge or discharge for about 3 minutes, until everything has reinitialised and recovered.
Has anyone noticed similar issues in your automations, and have you found a way around it?
I contacted Sonnen Support about this but haven't received an acknowledgement or support for this issue yet.
If I let the Sonnen battery do its own thing (i.e. self-consumption or time-of-use mode), it has no problems discharging at higher rates, up to 2300W (which is the maximum output the inverter can provide for my system). That makes me wonder if there is a threshold setting somewhere in the API that I might have missed.
My battery is running Firmware Version 1.31.10.4176380, Release Channel stable, Software Version 1.31.10.
I had issues with my eco 8.2 for several months. I also have a "Frankenstein" setup, in combination with a Sonnen 10 and Sonnen has been unresponsive, even following the letters of my lawyer.
What I can say is that with software v. 1.31.10, firmware v. 1.31.10.4176380, the problem with charge/discharge API commands seem to have been solved (not sure how much it was related to the software itself or the interaction with Sonnen 10 - which is was the result of my investigation). BTW I managed to disable automatic updates with my installer.
