I worked on the Sonoff Dual that I installed the firmware Sonoff-Tasmota. I’ve integrated it with Home-Assistant using MQTT commands.
You can set a Window Cover position from the Window Set Position
which is converted from 0-100 to 0-16. I’ve set the timer 2 seconds more (18 sec) in order to go fully down or up.
The Window Position
is the current position of the Window Cover that is changed with the MQTT Commands (ON/OFF). If all automations are working correctly, you don’t have to change this bar.
This is the result:
To make it work I had to count the time it takes my window cover to go up/down. For me, it was 18 seconds, so this is the configuration on Home Assistant:
Basic Config
configuration.yaml
timer:
window_1_up:
duration: '00:00:18'
window_1_down:
input_number:
window_1_position:
name: "Window Position"
min: 0
max: 100
window_1_set_position:
name: "Window Set Position"
min: 0
max: 100
cover:
covers:
window_1_cover:
friendly_name: "Window 1 Cover"
position_template: "{{ (states.input_number.window_1_position.state | int) }}"
open_cover:
- service: mqtt.publish
topic: 'cmnd/window_1/power2'
payload: 'OFF'
topic: 'cmnd/window_1/power1'
payload: 'ON'
close_cover:
payload: 'OFF'
payload: 'ON'
stop_cover:
payload: 'OFF'
payload: 'OFF'
automations.yaml
- id: '301'
alias: window_1 - MQTT Button1 OFF (up)
- payload: 'OFF'
platform: mqtt
topic: stat/window_1/POWER1
- service: timer.cancel
entity_id: timer.window_1_up
data_template:
entity_id: input_number.window_1_set_position
value: >-
{{ states.input_number.window_1_position.state }}
- id: '302'
alias: window_1 - MQTT Button2 OFF (down)
- payload: 'OFF'
platform: mqtt
topic: stat/window_1/POWER2
entity_id: timer.window_1_down
data_template:
value: >-
- id: '303'
alias: window_1 - Timer stopped
- platform: event
event_type: timer.finished
event_data:
- platform: event
event_data:
- service: cover.stop_cover
entity_id: cover.window_1_cover
- id: '311'
alias: window_1 - MQTT Button1 ON (up)
- payload: 'ON'
platform: mqtt
condition: template
value_template: '{{ as_timestamp(now()) - as_timestamp(states.input_number.window_1_set_position.last_updated) > 3 }}'
- service: timer.start
duration: 00:00:16
- id: '312'
alias: window_1 - MQTT Button2 ON (down)
- payload: 'ON'
platform: mqtt
condition: template
duration: 00:00:16
- id: '411'
alias: window_1 - Position UP
platform: time_pattern
seconds: '/1'
condition: state
state: active
data_template:
entity_id: input_number.window_1_position
value: >-
{% set step=100/16 %}
{% if (states.input_number.window_1_position.state | float + step) < 100 %}
{{ states.input_number.window_1_position.state | float + step | int }}
100
- id: '412'
alias: window_1 - Position Down
seconds: '/1'
condition: state
state: active
data_template:
value: >-
{% if (states.input_number.window_1_position.state | float - step) > 0 %}
{{ states.input_number.window_1_position.state | float - step | int}}
0
- id: '511'
alias: window_1 - Set Position Down
platform: state
condition: template
value_template: >-
{{ (states.input_number.window_1_position.state | int) >
(states.input_number.window_1_set_position.state | int) }}
data_template:
duration: >-
{{ '00:00:%02d' | format(((
(states.input_number.window_1_position.state | int) -
) * 16 /100) | int | abs )
- service: cover.close_cover
- id: '512'
alias: Window_1 - Set Position UP
platform: state
condition: template
value_template: >-
{{ (states.input_number.window_1_position.state | int) <
data_template:
duration: >-
- service: cover.open_cover
UI Config
lovlace.yaml
entities:
- entity: cover.window_cover
- entity: input_number.window_set_position
- entity: input_number.window_position
show_header_toggle: false
title: Window Cover
type: entities
groups.yaml
window_cover:
entities:
- cover.window_cover
- input_number.window_set_position
- input_number.window_position
- timer.window_up
- timer.window_down
API Call
Set position:
http://[home-assistant-url]:8123/api/services/input_number/set_value?api_password=password
{ "entity_id": "input_number.window_set_position", "value": 50 }
IFTTT
Home Asssistant Automations:
- id: ifttt_window_set
alias: IFTTT Window Set
platform: event
event_type: ifttt_webhook_received
event_data:
action: window_set
service_template: '{{ trigger.event.data.service }}'
data_template:
entity_id: '{{ trigger.event.data.entity_id }}'
- id: ifttt_window_position
alias: IFTTT Window Position
platform: event
event_data:
action: window_position
data_template:
value: '{{ trigger.event.data.value }}'
IFTT WebHook POST Reqest for close:
{"action": "window_set", "service": "cover.close_cover", "entity_id": "cover.window_cover" }
IFTT WebHook POST Reqest for set position:
{"action": "window_position", "service": "input_number.set_value", "entity_id": "input_number.window_set_position", "value": "{{NumberField}}"}
Alternative option
If you are using ESPHome, then this can be used instead, which automatically integrates with home-assistant.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: 'myssid'
password: 'mypass'
api:
logger:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO09
mode: INPUT_PULLUP
inverted: True
on_press:
- cover.open: my_cover
on_release:
- cover.stop: my_cover
- platform: gpio
pin:
number: GPIO00
mode: INPUT_PULLUP
inverted: True
on_press:
- cover.close: my_cover
on_release:
switch:
- platform: gpio
pin: GPIO12
interlock: &interlock [open_cover, close_cover]
- platform: gpio
pin: GPIO5
interlock: *interlock
cover:
- platform: time_based
open_action:
- switch.turn_on: open_cover
open_duration: 18s
close_action:
- switch.turn_on: close_cover
close_duration: 18s
stop_action:
- switch.turn_off: open_cover
- switch.turn_off: close_cover
FAQ
- Use record on configuration.conf to save the state of the cover and sliders after a restart.
- On Sonoff Tashoma Firmware there is the SetOption14 to interlock the 2 relays, though I haven’t tested it. It could help have fewer automations.
- Physical switch connection diagram: here
- Physical switch Sonoff configuration (GPIO0 - 09 switch 1, GPIO9 - 10 switch 2)
- Allow Cover arrows to be always enabled: On configuration.yaml on cover section set “optimistic: true”
- Save the automation on a separate file. Add this line on configuration.yaml: automation old: !include_dir_merge_list automation/
- Easily add another window sensor by changing all the window_1 to something else.
- Split configuration: Instead of writing the whole configuration on configuration.yaml, you could create a package.yaml file by following the official doc about packages here.
I hope it helps!
