Hi, how I can change the button order, because if I press button up the shutter go down and vice versa if I click down.
But if I select one position, then the shutter goes up or down ok.
Another question is how I can create an automation that at the morning the shutter goes up to X position and in the evening the shutter goes down to X position.
Hi, after shutdown and restart Hassio, all is OK!
Switch wires on your relays
Hi all,
I updated to 6.4.0 and now the buttons don’t work.
In the docs there are no info on such changes.
Does anyone can support me to make them work again?
Hi Laptoc
I’m also trying to use stefanbode tasmota fork on the Sonoff Dual
Have you been able to put a slider on the cover so that the position can be set/viewed without having to click on the cover icon to open a slider window
(Note - I’m very new to HA)
Cover setup below
cover:
- platform: mqtt
availability_topic: “house/shutter1/tele/LWT”
payload_available: “Online”
payload_not_available: “Offline”
position_topic: house/shutter1/stat/SHUTTER1
position_open: 100
position_closed: 0
set_position_topic: “house/shutter1/cmnd/backlog/shutterposition”
command_topic: “house/shutter1/cmnd/backlog”
payload_open: “SHUTTEROPEN”
payload_close: “SHUTTERCLOSE”
payload_stop: “SHUTTERSTOP”
retain: false
optimistic: false
qos: 1
Leigh
By default it’s not possible. You have to use some custom UI element. The easiest way to use custom card for lovelace (it going to be default UI staring next release) from @thomasloven
Hi all,
sorry but can someone help me?
This is my config:
- platform: mqtt
# availability_topic: "tele/TapparellaStudio/LWT"
# payload_available: "Online"
# payload_not_available: "Offline"
position_topic: stat/TapparellaStudio/SHUTTER1
position_open: 100
position_closed: 0
set_position_topic: "cmnd/TapparellaStudio/shutterposition"
command_topic: "cmnd/TapparellaStudio/backlog"
payload_open: "SHUTTEROPEN"
payload_close: "SHUTTERCLOSE"
payload_stop: "SHUTTERSTOP"
retain: false
optimistic: false
qos: 1
I had to comment availabitly because makes the shutter unavailable.
Moreover I do not see any slider to set position within HA .
This is a direct paste from stefanbode’s information I doubt you have the same setup.
Have a look at the cover: that I posted above and see where I’ve changed the settings due to my topic (shutter1) and the arrangement of the full topic (house/%topic%/%prefix%) - Checking the LWT sets payload if its available or not.
To get a slider click on the cover Icon or text and you should see the slider with stats.
It took me hours to work out what was going on as the last example in stefanbodes does not have the cover: at the beginning
check with the tasmota wiki for various options/stats/info as stefanbode is based on it, just has a few extras.
Going to look into Lovelace to set up a better looking control page.
Leigh
Jokerigno - Which Tasmota are you using - std or stefans - if stefans you can’t update, as it will overwrite stefans with the std tasmota. (I think anyway)
I do have Stefan Bode fork.
And this was my current setup.
Hi, first of all thanks to the OP for this
But I have a proble, ever time I press the button Up/Down it does nothing don’t know why.
Is there a way to see log’s or something to try to see where is the problem ?!
Using the code that the OP put here at Oct 17, '18
Thanks for the help
New version of Home-Asssitant 0.86.1 breaks the automations.
You need to do a change on the automations
- 411 (Window - Position UP)
- 412 (Window - Position Down).
Change the platform: time to platform: time_pattern on both of these automations and you are ready to go.
You are awesome! Thank you!
I was getting mad after updating to 0.86.1
Have you done cover with sonoff?
Can you give me automation to chek where I have done mistake???
Hello, congratulations on your project. A question, how can I integrate the comand:
availability_topic command: “tele / sonoff / LWT”
so that when the sonoff does not receive power, on the home assistant server the commands are not available?
Thank’s!
H, first of all, thanks for your awesome work!
I tried to modify your code @bkbilly, but using a double wall mounted Aqara wall switch.
Cover seems to work, but positioner doesn’t.
Here I post the code I used:
configuration.yaml
timer:
window_up:
duration: '00:00:18'
window_down:
input_number:
window_position:
initial: 5
min: 0
max: 18
window_set_position:
initial: 5
min: 0
max: 100
cover:
covers:
window_cover:
friendly_name: "Salón"
position_template: "{{ (((states.input_number.window_position.state | int) * 100)/18 | int) }}"
open_cover:
- service: switch.turn_off
entity_id: switch.wall_switch_right_158d00014axxxx
- service: switch.turn_on
entity_id: switch.wall_switch_left_158d00014axxxx
close_cover:
stop_cover:
automations.yaml
- id: '301'
alias: Window - MQTT Button1 OFF (up)
- platform: state
to: 'off'
- service: timer.cancel
entity_id: timer.window_up
- id: '302'
alias: Window - MQTT Button2 OFF (down)
- platform: state
to: 'off'
entity_id: timer.window_down
- id: '303'
alias: Window - Timer stopped
- platform: event
event_type: timer.finished
event_data:
- platform: event
event_data:
- service: cover.stop_cover
entity_id: cover.window_cover
- id: '311'
alias: Window - MQTT Button1 ON (up)
- platform: state
to: 'on'
condition:
condition: template
value_template: '{{ as_timestamp(now()) - as_timestamp(states.input_number.window_set_position.last_updated) > 3 }}'
- service: timer.start
duration: 00:00:18
- id: '312'
alias: Window - MQTT Button2 ON (down)
- platform: state
to: 'on'
condition:
condition: template
duration: 00:00:18
- id: '411'
alias: Window - Position UP
seconds: '/1'
condition:
condition: state
entity_id: 'timer.window_up'
state: 'active'
- service: input_number.set_value
data_template:
entity_id: input_number.window_position
value: "{{ (states.input_number.window_position.state | int) + 1 }}"
- id: '412'
alias: Window - Position Down
seconds: '/1'
condition:
condition: state
entity_id: 'timer.window_down'
state: 'active'
data_template:
value: "{{ (states.input_number.window_position.state | int) - 1 }}"
- id: '511'
alias: Window - Set Position Down
platform: state
entity_id: input_number.window_set_position
condition:
condition: template
value_template: "{{ (states.input_number.window_position.state | int) > ((((states.input_number.window_set_position.state | int ) * 18 )/100) | int) }}"
data_template:
duration: "{{ '00:00:%02d' | format( ((states.input_number.window_position.state | int) - ((((states.input_number.window_set_position.state | int ) * 18 )/100) | int) ) | abs ) }}"
- service: cover.close_cover
- id: '512'
alias: Window - Set Position UP
platform: state
condition:
condition: template
value_template: "{{ (states.input_number.window_position.state | int) < ((((states.input_number.window_set_position.state | int ) * 18 )/100) | int) }}"
data_template:
- service: cover.open_cover
groups.yaml
window_cover:
entities:
- cover.window_cover
- input_number.window_set_position
- input_number.window_position
- timer.window_up
- timer.window_down
I checked code, but I can’t find what it’s wrong.
Would it be possible to use aqara double wall socket instead of sonoff dual ?
Thanks for sharing!
Hi Pierre, a question for you:
I would like that when a dual sonoff is off, the cover appears (not available).
I would like to insert the following command:
availability_topic: “tele / sonoff / LWT”.
In which sector of .yaml can I insert it?
Thank’s!
I guess it should go in the cover definition:
Thank’s for your answer.
I inserted availability_topic in the cover, without result. Its positioning is right?
He doesn’t work!
Just realised.
MQTT Cover has availability. Template cover does not
