Assuming you tested that the switches work by triggering the automation from the HA GUI, you might be asking why your proximity trigger doesn’t fire? Looks like you should remove the quotes around ‘30’ and ‘900’ since numeric_state is comparing numbers, not strings. Best to start a new thread if the question is about triggers (although perhaps you thought there is something special about turning 4ch sonoff on/off - there isn’t). Here’s my automation:
- id: '1560392496406'
alias: Water zone 1
- at: 05:00:00
platform: time
condition:
- condition: time
weekday:
- sun
- tue
- fri
- condition: template
value_template: "{{ not (states('sensor.dark_sky_precip_probability')|float > 50 and states('sensor.dark_sky_precip_intensity')|float > 0.1) }}"
- data:
entity_id: switch.10004c1399_1
service: switch.turn_on
If your switches work outside of that automation, then you just need help getting the automation working. You might find more help in a new thread asking about automations specifically.
Have you got any answer by now? I have the same problem when upgrading to 0.95.1:
General Errors:
- Integration not found: sonoff
Went back to 0.94.4 where, in my case, the custom component workes just as it had before.
i find that this component is not really realiable. My automation sometimes would not run without any clear reason. but sometimes it run without a hitch.
really hope someone with the knowledge to carry on the torch. sadly, i am not savy enough to do so.
Your automation, does it turn on/off more then one sonoff device?
I had a similar problem and I created a script that the automation executes, in the script I have added a 1 sec delay between every sonoff device call… works rock solid for me!
i have done 3-4 times system reboot also HA , but the problem remains ! in the older version i hadn’t problem , with the same process my custom component folder worked correctly ! why during the validation it can’t find sonoff folder ?
We have the same preconditions ,the only difference is that I have installed HassOS (64-bit) . Is it wrong ? don’t ask me why ! i don’t know …i read it somewhere …
Yes i thing that my custom_component folder is correct , i have created it into config folder with name custom_components , then i have created another folder with name " sonoff " and inside this folder i have put 3 . py files ( init.py with 2 underscores left and right , switch.py ,sensor.py ) with relative source code in each file as mentioned here -> https://github.com/peterbuga/HASS-sonoff-ewelink , i can’t understand why after this process my validation fails !
do you see anything of above mentioned which is incorrect ? thanks !
