sure here is the mqtt message after changing speed to 2
here is the tele/state lines
{"Time":"2019-09-20T20:13:38","Uptime":"0T08:39:50","UptimeSec":31190,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER1":"ON","FanSpeed":2,"Wifi":{"AP":1,"SSId":"HA","BSSId":"E4:F4:C6:02:01:BA","Channel":6,"RSSI":100,"LinkCount":1,"Downtime":"0T00:00:04"}}
I had an improvement I got it to register the fan speed changes but it puts everything as med or off here is the yaml turns out it was the quoted mqtt topics i had in it
fan:
- platform: mqtt
name: "Kitchen Ceiling Fan 2"
command_topic: KCF2/cmnd/FanSpeed
speed_command_topic: KCF2/cmnd/FanSpeed
state_topic: KCF2/stat/RESULT
speed_state_topic: KCF2/tele/STATE
state_value_template: >
{% if value_json.FanSpeed is defined %}
{% if value_json.FanSpeed == 0 -%}0{%- elif value_json.FanSpeed > 0 -%}4{%- endif %}
{% else %}
{% if states.fan.Kitchen_Ceiling_Fan_2 == 'off' -%}0{%- elif states.fan.Kitchen_Ceiling_Fan_2.state == 'on' -%}4{%- endif %}
{% endif %}
speed_value_template: "{{ value_json.FanSpeed }}"
availability_topic: KCF2/tele/LWT
payload_off: "0"
payload_on: "4"
payload_low_speed: "1"
payload_medium_speed: "2"
payload_high_speed: "3"
payload_available: Online
payload_not_available: Offline
speeds:
- off
- low
- medium
- high
The quotation marks shouldn’t make any difference. My config has the quotation marks and it works fine.
However I did find a couple of mistakes in your code.
Where did you get the code above? Did you copy it from somwhere other than the Tasmota website or any of the threads/posts I’ve made?
Here are the incorrect lines:
{% else %}
{% endif %}
they should be:
speed_state_topic: KCF2/stat/RESULT
{% else %}
{% if states.fan.kitchen_ceiling_fan_2.state == 'off' -%}0{%- elif states.fan.kitchen_ceiling_fan_2.state == 'on' -%}4{%- endif %}
{% endif %}
the state topic is wrong and the {% else %} {% if %}… portion is wrong.
Entity_id’s are never going to contain uppercase characters. and you missed “…state” at the end of the line.
I think I got it directly from one of your posts but i would have to go fine to tell you for sure
I don’t think so.
but if you find it please let me know where it is so I can correct it.
Is it working now?
Yes that did the trick thank you
