NigelHA
January 12, 2022, 7:19pm
21
@devjklein : Here is a modified version that when the fan is off, will start the fan on high for 5 seconds then switch to the target speed. I also modified the relay sequence to speed 1 is relay 1 only, speed 2 is relay 2 only and speed 3 is relay 3 only.
yaml
substitutions:
device_description: Sonoff iFan04-L
friendly_name: Living Room Fan/Light
globals:
- id: target_fan_speed
type: int
- id: start_time_offset
type: int
esphome:
comment: ${device_description}
platform: ESP8266
board: esp01_1m
on_boot:
priority: 225
# turn off the light as early as possible
then:
- light.turn_off: fan_light
on_loop:
lambda: |-
if (id(start_time_offset) && (millis() > id(start_time_offset))) {
ESP_LOGD("IFAN04", "Delayed wakeup to select final target speed: %d", id(target_fan_speed));
auto call = id(the_fan).turn_on();
call.set_speed(id(target_fan_speed));
call.perform();
id(start_time_offset) = 0;
# Disable logging on serial as it is used by the remote
logger:
baud_rate: 0
# Enable Home Assistant API
api:
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
fast_connect: on
web_server:
port: 80
auth:
username: !secret web_server_username
password: !secret web_server_password
external_components:
- source: github://ssieb/custom_components
components: [ ifan04 ]
time:
- platform: homeassistant
on_time_sync:
- component.update: sensor_uptime_timestamp
uart:
tx_pin: GPIO01
rx_pin: GPIO03
baud_rate: 9600
# debug:
# sequence:
# - lambda: UARTDebug::log_hex(direction, bytes, ',');
ifan04:
on_fan:
- lambda: |-
if (speed) {
if (!id(target_fan_speed)) {
ESP_LOGD("IFAN04", "Fan currently off, starting on max reducing to %d in 5 seconds", speed);
id(target_fan_speed) = speed;
speed = 3;
id(start_time_offset) = millis() + 5000;
} else {
ESP_LOGD("IFAN04", "Fan already running, current speed (%d) new speed: (%d)", id(target_fan_speed), speed);
call.set_speed(speed);
call.perform();
if (id(buzzer_dummy).state) {
switch(id(target_fan_speed)) {
case 3:
id(buzzer_pin).turn_on();
delay(50);
id(buzzer_pin).turn_off();
delay(50);
case 2:
delay(50);
delay(50);
case 1:
delay(50);
} else {
id(target_fan_speed) = 0;
auto call = id(the_fan).turn_off();
call.perform();
on_light:
- light.toggle: fan_light
on_buzzer:
- switch.toggle: buzzer_dummy
- platform: uptime
device_class: "timestamp"
accuracy_decimals: 0
update_interval: never
lambda: |-
static float timestamp = (
id(time_homeassistant).utcnow().timestamp - id(sensor_uptime).state
return timestamp;
- platform: wifi_signal
update_interval: 60s
binary_sensor:
- platform: gpio
pin: GPIO0
on_press:
then:
interval:
- interval: 500ms
then:
- if:
condition:
not:
wifi.connected:
then:
- light.turn_on:
brightness: 100%
transition_length: 0s
- delay: 250ms
- light.turn_off:
transition_length: 250ms
output:
type: float
write_action:
- if:
condition:
lambda: return (state < 0.3);
then:
# OFF
- switch.turn_off: fan_relay1
- switch.turn_off: fan_relay2
- switch.turn_off: fan_relay3
else:
if:
condition:
lambda: return (state < 0.6);
then:
# low speed
- switch.turn_on: fan_relay1
else:
if:
condition:
lambda: return (state < 0.9);
then:
# medium speed
- switch.turn_on: fan_relay2
else:
# high speed
- switch.turn_on: fan_relay3
- platform: gpio
pin: GPIO9
inverted: true
- platform: gpio
pin: GPIO10
inverted: true
- platform: esp8266_pwm
pin: GPIO13
inverted: true
light:
- platform: binary
output: light_relay
- platform: monochromatic
output: led_pin
default_transition_length: 0s
restore_mode: always off
switch:
- platform: restart
optimistic: True
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO12
- platform: gpio
pin: GPIO15
fan:
- platform: speed
output: fanoutput
speed_count: 3
wow thanks for this!
I got mine all installed, it works, great⦠I just now realized the light is on/off and not a dimmer - crud.
joe2
(joe)
January 15, 2022, 8:01pm
23
fwiw - iām up and running now too. I had a difficult time getting the device to burn properly. After initially not even being able to connect, my second issue was esphome would write the firmware, but itād never start and connect to my wifi.
I found that starting with tasmotta, i was able to write the firmware and get on the wifi immidiately⦠tasmotta has an extra option that āerasesā the device during firmware write. This seems to have resolved by issues.
I had a small secondary issue with not enough space to upload my esphome firmeware to the tasmotta burned device⦠until i backed down tasmotta to the āliteā / āminimalā version first⦠then i could swap over to my esp image no problem.
devjklein
(Devjklein)
January 25, 2022, 3:30pm
24
Just got around to uploading your code to my fan. It works great! I modified the start delay from 5 to 3 seconds, so it wouldnāt reach such a high speed on startup (fan is directly over seating, so max speed can be overwhelming )
NigelHA
January 25, 2022, 4:10pm
25
I guess your fan starts spinning a lot faster than mine . Glad I could help, you provided the motivation to do something to improve the longevity of the iFan04-L device and the fan in this type of installation.
devjklein
(Devjklein)
January 25, 2022, 6:06pm
26
I did just notice an issue, if I start the fan from a stop with the remote, it operates as expected and toggles all relays on for a few seconds. However, if I set the fan speed in homeassistant, it appears the fan module bypasses the speed logic and goes directly to toggling on a single relay. Any thoughts on this?
NigelHA
January 25, 2022, 7:30pm
27
The logic that is currently in the on_fan lambda needs to move to the output template. The on_fan handler is only used by the remote. I will think about how that needs to be reworked over the next few days.
NigelHA
January 26, 2022, 3:47am
28
@devjklein : Reworked so that the use of Home-Assistant utilizes the boost at startup as well when using the remote. I think there is a bug in the HA front-end, in that if you slide the fan speed to where you want and release it sends one set speed command and works perfectly, but if you tap the speed bar at a new speed level when the unit is off it will send the speed command twice as it powers the device on defeating the speed boost at startup.
yaml
substitutions:
globals:
type: int
type: int
esphome:
platform: ESP8266
board: esp01_1m
on_boot:
priority: 225
then:
on_loop:
lambda: |-
ESP_LOGD("IFAN04", "Setting target speed: %d", id(target_fan_speed));
call.perform();
logger:
baud_rate: 0
api:
ota:
wifi:
fast_connect: on
web_server:
port: 80
auth:
time:
on_time_sync:
uart:
tx_pin: GPIO01
rx_pin: GPIO03
baud_rate: 9600
# debug:
# sequence:
ifan04:
on_fan:
- lambda: |-
if (speed) {
call.perform();
case 3:
delay(50);
delay(50);
case 2:
delay(50);
delay(50);
case 1:
delay(50);
} else {
call.perform();
on_light:
on_buzzer:
- platform: uptime
lambda: |-
return timestamp;
binary_sensor:
- platform: gpio
pin: GPIO0
on_press:
then:
interval:
- interval: 500ms
then:
- if:
condition:
not:
wifi.connected:
then:
- light.turn_on:
brightness: 100%
- delay: 250ms
- light.turn_off:
output:
type: float
write_action:
- lambda: |-
if (state) {
int speed = int(state / 0.33);
if (!id(target_fan_speed) && (speed < 3)) {
ESP_LOGD("IFAN04", "Fan currently off, boosting speed");
state = 1.0;
id(start_time_offset) = millis() + 5000; // 5 second delay
} else {
if (state < 0.3) {
// OFF
id(fan_relay1).turn_off();
id(fan_relay2).turn_off();
id(fan_relay3).turn_off();
} else if (state < 0.6) {
// low speed
id(fan_relay1).turn_on();
} else if (state < 0.9) {
// medium speed
id(fan_relay2).turn_on();
} else {
// high speed
id(fan_relay3).turn_on();
- platform: gpio
pin: GPIO9
inverted: true
- platform: gpio
pin: GPIO10
inverted: true
pin: GPIO13
inverted: true
light:
- platform: binary
output: light_relay
output: led_pin
switch:
- platform: restart
optimistic: True
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO12
- platform: gpio
pin: GPIO15
fan:
- platform: speed
output: fanoutput
speed_count: 3
CarlosS
(Carlos Santiago)
April 23, 2022, 8:09pm
29
@NigelHA Thank you for your work on this. I installed four ifan04 devices yesterday and they are working great in HA. My fans old remote control modules had a feature that I would like to check if it is possible to implement on the ifan04. When power to the fans is removed by using a wall switch or because of a power outage, the fans would remember and go back to their previous state when the power is restored. For example if a fan was running on medium when it lost power, it will start back at medium speed when the power is restored. Can that be done with the ifan04 and ESPHome?
cpyarger
(Christopher P. Yarger)
April 24, 2022, 7:44am
30
I have been working on an external component for the ifan04, that puts all of the c++ code where it belongs rather than in lambdas.
If anyone is interested
- source: github://cpyarger/custom_components
if you want to check the code, it is in components/ifan
The next steps are to integrate ssiebās ifan04, so that itās all handled within the component code.
CarlosS
(Carlos Santiago)
April 24, 2022, 7:11pm
31
I canāt wait to try your code. Everything is working almost perfectly now, but I just noticed that my fan low and medium speeds are the same, so only low and high are really working.
cpyarger
April 24, 2022, 10:56pm
32
Ill push my latest updates.
if you set your external components as such;
- source: github://cpyarger/custom_components@master
refresh: 0s
Then whenever I push an update, you should get the latest on a fresh install.
I think the default refresh is 1 day
If you have any issues, or suggestions, please let me know
Saving state is controlled through the use of restore_from_flash in the esphome section. You should also read about flash_write_interval .
I intentionally used lambdas to keep all the code together in the yaml file for easy manipulation, especially as the fan speed part of the configuration has been a point of contention for many on both the ifan03 and 04. But if you are going to submit this has an official component with speed issues addressed that would be great.
CarlosS
(Carlos Santiago)
April 25, 2022, 1:49pm
35
Thanks, I will look that up. I found that my fans require relays 1 and 2 on for medium speed to work.
cpyarger
April 25, 2022, 4:57pm
36
Yeah the plan is eventually to allow for you to choose between the various models.
cpyarger
July 6, 2022, 5:55pm
37
Here is my working yaml code for my ifan04, including my custom component.
substitutions:
friendly_name: Dining Room
refresh: 0s
esphome:
comment: Sonoff iFan04-L
# This will allow for (future) project identification,
# configuration and updates.
project:
version: "1.0"
esp8266:
board: esp01_1m
logger:
baud_rate: 0
api:
services:
- service: fan_cycle
then:
- fan.cycle_speed: the_fan
ota:
uart:
tx_pin: GPIO01
rx_pin: GPIO03
baud_rate: 9600
dashboard_import:
package_import_url: github://cpyarger/esphome-templates/sonoff-ifan04-l.yaml@main
captive_portal:
binary_sensor:
- platform: gpio
pin: GPIO0
on_press:
then:
output:
pin: GPIO13
inverted: true
light:
- platform: ifan
output: led_pin
button:
name: ${friendly_name} Cycle Fan
on_press:
then:
fan:
- platform: ifan
remote_enable: false
ifan04:
on_fan:
- lambda: |-
auto call = speed ? id (the_fan).turn_on() : id (the_fan).turn_off();
call.perform();
on_light:
wifi:
#use_address: sonoff-ifan04-l-77cdd8.local
web_server:
ditheo
(Dimosthenis Theocharidis)
July 8, 2022, 6:09am
38
@cpyarger
I have installed your code on my ifan04-H wich is working great so far!
I have 3 questions
What cycle fan does , I didnāt find something change on my fan ?
Can we disable the buzzer?
On your github repo you have 2 fan components wich one should i use?
Thank you
cpyarger
July 10, 2022, 5:22am
39
I have one fan component, the ifan component, the ifan04 component, as stated in the readme of the repo, is for the remote control.
if i remember correctly
fan:
- platform: ifan
buzzer_enable: false
should disable the buzzer
Cycle fan, cycles through the fan speeds, I had the number of speeds set to 100, so cycle was broken, but i fixed that a couple days ago
thanks it works perfectly
made a few adjustments to the backup wifi and remote web
