Thank you for your time, Christopher.
I am not sure I understang what you mean by the external components. Do you mean the tag external_components refering to pr#2956? I am not sure how this works, but I guess it has to do with the Protocol Reparse Mode change of the Nextion TFT? The tag is in the code.
Here is the code below (I started copying your code, then I tried out this one which is added lately in your git page).
substitutions:
device_name: nspanel-dev
# Example config.yaml
esphome:
comment: $device_name
esp32:
board: esp32dev
wifi:
ssid: fha2
password: '32323245'
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: /1
then:
- lambda: id(disp1).set_component_text_printf("Home.time", "%02i:%02i", id(homeassistant_time).now().hour, id(homeassistant_time).now().minute);
- lambda: id(disp1).set_component_text_printf("Home.date", "%i-%02i-%02i", id(homeassistant_time).now().year, id(homeassistant_time).now().month, id(homeassistant_time).now().day_of_month);
- lambda: id(disp1).set_component_text_printf("Home.temp", "%.1f", id(current_temperature).state);
- lambda: id(disp1).set_component_text_printf("Home.tempfl", "%.1f", id(temp_feelslike).state);
api:
services:
# Service to play a song
- service: play_rtttl
variables:
song_str: string
then:
- rtttl.play:
rtttl: !lambda 'return song_str;'
- service: upload_tft
then:
- lambda: 'id(disp1)->upload_tft();'
logger:
baud_rate: 0
level: DEBUG
ota:
uart:
tx_pin: 16
rx_pin: 17
baud_rate: 115200
# debug:
# direction: BOTH
# dummy_receiver: false
# after:
# delimiter: "\n"
# sequence:
# - lambda: UARTDebug::log_string(direction, bytes);
external_components:
- source: github://pr#2956
components: [nextion]
refresh: 1h
# A reboot button is always useful
button:
- platform: restart
binary_sensor:
- platform: gpio
name: $device_name Left Button
pin:
number: 14
inverted: true
on_click:
- switch.toggle: relay_1
- platform: gpio
name: $device_name Right Button
pin:
number: 27
inverted: true
on_click:
- switch.toggle: relay_2
- platform: nextion
name: $device_name Music previous
page_id: 1
component_id: 1
- platform: nextion
name: $device_name Music play pause
page_id: 1
component_id: 2
- platform: nextion
name: $device_name Music next
page_id: 1
component_id: 3
- platform: nextion
name: $device_name Music cast
page_id: 1
component_id: 4
- platform: nextion
name: $device_name Music voldown
page_id: 1
component_id: 9
- platform: nextion
name: $device_name Music volup
page_id: 1
component_id: 10
- platform: nextion
name: $device_name Playlist cocktail
page_id: 1
component_id: 11
- platform: nextion
name: $device_name Playlist food
page_id: 1
component_id: 12
- platform: nextion
name: $device_name Playlist dance
page_id: 1
component_id: 13
- platform: nextion
name: $device_name Playlist note
page_id: 1
component_id: 14
output:
- platform: ledc
pin:
number: 21
switch:
- platform: gpio
name: $device_name Relay 1
pin:
number: 22
- platform: gpio
name: $device_name Relay 2
pin:
number: 19
- platform: gpio
name: $device_name Screen Power
entity_category: config
pin:
number: 4
inverted: true
restore_mode: ALWAYS_ON
name: $device_name Energy Saving Mode
restore_state: true
optimistic: true
rtttl:
output: buzzer_out
- platform: adc
pin: 38
update_interval: 10s
attenuation: 11db
- platform: resistance
sensor: ntc_source
configuration: DOWNSTREAM
resistor: 11.2kOhm
- platform: ntc
sensor: resistance_sensor
calibration:
b_constant: 3950
reference_temperature: 25°C
reference_resistance: 10kOhm
name: $device_name Temperature
- platform: uptime
name: $device_name Uptime Sensor
update_interval: 60s
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
- platform: wifi_signal
name: $device_name WiFi Signal Sensor
- platform: nextion
variable_name: dp
entity_id: weather.home
attribute: temperature
on_value:
# Push it to the display
then:
entity_id: sensor.home_temperature_feels_like
on_value:
then:
text_sensor:
name: $device_name Uptime Human Readable
icon: mdi:clock-start
- platform: version
name: $device_name ESPHome Version
entity_id: media_player.sonos_vardagsrum
attribute: media_artist
on_value:
then:
- lambda: id(disp1).set_component_text_printf("Music.music_sn", "%s", id(music_artist).state.c_str());
attribute: media_title
on_value:
then:
- lambda: id(disp1).set_component_text_printf("Music.music_an", "%s", id(music_title).state.c_str());
entity_id: sun.sun
on_value:
then:
- lambda: |-
int symbol=5; // 5 is a empty box.
if (id(weather_symbol).state == "clear-night") {
symbol=6;
} else if (id(weather_symbol).state == "cloudy") {
symbol=7;
if (id(sun_sun).state == "below_horizon") {
symbol=8;
} else if (id(weather_symbol).state == "fog") {
symbol=9;
} else if (id(weather_symbol).state == "hail" || id(weather_symbol).state == "snowy-rainy") {
symbol=10;
} else if (id(weather_symbol).state == "lightning") {
symbol=11;
} else if (id(weather_symbol).state == "lightning-rainy" || id(weather_symbol).state == "exceptional") {
symbol=12;
symbol=13;
} else if (id(weather_symbol).state == "partlycloudy") {
symbol=14;
symbol=8;
} else if (id(weather_symbol).state == "pouring") {
symbol=15;
} else if (id(weather_symbol).state == "rainy") {
symbol=16;
} else if (id(weather_symbol).state == "snowy") {
symbol=17;
} else if (id(weather_symbol).state == "sunny") {
symbol=18;
} else if (id(weather_symbol).state == "windy" || id(weather_symbol).state == "windy-variant") {
symbol=19;
id(disp1).send_command_printf("Home.weather_symbol.pic=%i", symbol);
number:
platform: template
name: $device_name Brightness
unit_of_measurement: '%'
min_value: 0
max_value: 100
step: 1
initial_value: 30
set_action:
then:
- lambda: 'id(disp1).set_backlight_brightness(x/100);'
# Configure the screen itself
display:
- platform: nextion
uart_id: tf_uart
tft_url: 'http://10.0.0.120:8123/local/hmi.tft'
# A little fun...
on_setup:
then:
- number.set:
value: 30
# - rtttl.play: "twobits:d=4,o=5,b=220:c6,8g,8g,a,g,p,b,c6"
Do you spot any obvious error?
Best regards,
Felix
