Sonoff NSPanel by ITead - Smart Scene Wall Switch based on ESP32 and custom Nextion Touch Screen Panel Display (non-Pro variant)
Just doing another room and checked again. Yep, it changes. I know what I did. I pushed the wake button to the bottom, got the IDs for the other buttons, added them to my YAML. Moved the wake button to the top, wrote my TFT file. Buttons all gone wrong. Went back to Nextion, moved the wake button to the bottom, checked the IDs. All looks right. Moved the wake button to the top again.
Tonight, I left the wake button at the top and selected the other buttons from the dropdown. Ta da!
Itā€™s been a long week
I wonder if thereā€™s a way of targeting the button based on its object name rather than the component ID?
Inside Nextion - yes. Outside - standard ā€œSend Component IDā€ option sends page ID and component ID over serial port.
This style is great!! Are you sharing the HMI file anywhere?
I hadnā€™t really thought it was good enough to share, to be honest, so thank you. Itā€™s not finished yetā€¦ I still have a few rooms to do. Iā€™d be happy to share what I have so far if youā€™re interested. I have Photoshop PSD files, a nice collection of icons from MDI and. of course, the HMI file.
I also like your design and wondered what application you were using to create the UI. I do wish that photoshop could take advantage of the MDI Font rather than downloading each icon as a png. But even better would be if the icon fonts could be imported directly into the Nextion Editor. That would solve for transparency.
Yes, these panels wonā€™t support transparency. Itā€™s not too bad. I just downloaded a whole bunch from the MDI site and then added a colour overlay in PS. Itā€™s a labour of love :slight_smile:
Iā€™m just doing everything in Photoshop.
This is all my stuff. Iā€™ve never used github before so Iā€™m hoping this works:
I did make a small video with the function of my panel.
In case anyone didnā€™t get it and is interested, an update email arrived from Kickstarter/Sonoff this morning:
Has anyone ran into a problem with Nextion editor where if you are adding a button, clicks on that button do not register in ESPHome? Any control that I add does no register clicks/action in ESPHome. However, when I upload @masto example, everything works correctly, and I can see touch events in the logs. More then that, if I open @masto HMI file, modify existing buttons and create new TFT, everything is also working fine. Iā€™ve already tried Nextion editor on multiple computers with exactly the same result.
You need to tick the box Touch press event and touch release event for the button then it will send a command to esphome
OMG! Thank you! I struggled with this for a long time
I completed my own integration extension of [marcfager (GitHub - marcfager/nspanel-mf: Custom HMI controlled by ESPHome for the Sonoff NSPanel. Includes media player card and home screen with weather data and clock. More to come.) contribution @marcfager .
Though it relies a lot of flows outside of Nexion, I am happy to share feedback on pain-points/leads I went through. Most of my advanced HA logic is supported by Node-red thru HA and only a little by automations.
Thanks a lot marcfager for your initial sharing !
Music menu extensions:
  1. Music screen reflects the common favorites playlists on top, as well as random spotify mixes.
  2. The various icons (couch, home, rabbit) allow to redirect the sound to matching home speakers. It relies on HA spotcast addon and supports the music interactions (vol/play/pause etc) regardless of the current output.
Light menu extensions:
  • Only three light are showed (first row), the second row are scenes. Each light button supports one-click or double click to turn the time-corresponding expected brightness, or the one ahead in time.
  • The schematic of a ā€œlampā€ at the very right of the screen allow to change scenes (clicking right/left on the lamp header). Sliding up/down on the light pole will perform increasing/decreasing the luminosity.
General extensions
  1. Main screen show In/OutFelt/Out temp.
  2. I do not use the relays in the nspanel device, I desactived them from the config - this avoid a clunky noise on click. The buttons remains active so I can catch event in HA.
  3. Upon screen button interactions, HA returns a buzzer instruction back to the nspanel. This is not as good as haptic feedback, but helps a better feeling of interacting with it. Volume canā€™t be set, so the minimalistic sound has been considered. {ā€œsong_strā€:ā€œtwobits:d=32,o=4,b=900:32g#ā€}
  4. Screen is dimmed if no usage after some time. Normal and dimmed brightness are adjusted whether this is full day/evening time/deep night. This helps not having another bright screen in the house, the screen is pretty discreet while showing day and temperature readable.
Getting slider value from screen to HA was painful to decrypt in the docs, see below the required code ā€œonreleaseā€
printh 91
prints "lightslider",0
printh 00
prints lightslider.val,0
printh FF FF FF
nspanel config:
  # Light slider
  - platform: nextion
    name: $device_name lightslider
    variable_name: lightslider
Very well done! I especially like your thoughts behind the light page. I am not fully satisfied with the one I made. I mean it works very well to turn lights on and off, but thanks to HA magic, we very seldom have to do so as the lights are controlled according to what part of day it is (time and darkness) and event in the home. Your setup with a dimmer slider that I assume controls the all lights in the room makes alot more sense as that is an adjustment one actually would like to control!
What for software did you use for the custom icons ? So I can it replace with my own light examples.
Icons are sourced from GitHub - marcfager/nspanel-mf: Custom HMI controlled by ESPHome for the Sonoff NSPanel. Includes media player card and home screen with weather data and clock. More to come. reference links with simple GIMP around them.
Hi
I am having the same issue and was wondering what you did to fixed it, I have added the PR inside of the external components but sadly the screen does not boot.
# Set some variables for convenience
substitutions:
  node_name: nspanel-demo
  device_name: Demo NSPanel
# Note: this may not be needed if the pull request has been merged.
# Check https://github.com/esphome/esphome/pull/2956 for current status.
external_components:
  - source: github://pr#2956
    components: [nextion]
    refresh: 0s
esphome:
  comment: $device_name
esp32:
  board: esp32dev
# Enable logging
logger:
# Enable wireless updates
ota:
# Enable Home Assistant API
api:
  services:
    # Service to play a song
    - service: play_rtttl
      variables:
        song_str: string
      then:
        - rtttl.play:
            rtttl: !lambda 'return song_str;'
    - service: upload_tft
      then:
        - lambda: 'id(disp1)->upload_tft();'
# A reboot button is always useful
button:
  - platform: restart
    name: Restart $device_name
# Define some inputs
binary_sensor:
  - platform: gpio
    name: $device_name Left Button
    pin:
      number: 14
      inverted: true
    on_click:
      - switch.toggle: relay_1
  - platform: gpio
    name: $device_name Right Button
    pin:
      number: 27
      inverted: true
    on_click:
      - switch.toggle: relay_2
  - platform: nextion
    name: $device_name Play Button
    page_id: 0
    component_id: 2
  - platform: nextion
    name: $device_name On Button
    page_id: 0
    component_id: 3
  - platform: nextion
    name: $device_name Off Button
    page_id: 0
    component_id: 4
  - platform: nextion
    name: $device_name Red Button
    page_id: 0
    component_id: 6
  - platform: wifi_signal
    name: $device_name WiFi Signal
    update_interval: 60s
  - platform: ntc
    sensor: resistance_sensor
    calibration:
      b_constant: 3950
      reference_temperature: 25Ā°C
      reference_resistance: 10kOhm
    name: $device_name Temperature
  - platform: resistance
    sensor: ntc_source
    configuration: DOWNSTREAM
    resistor: 11.2kOhm
  - platform: adc
    pin: 38
    update_interval: 10s
    attenuation: 11db
  # Grab current temperature from Home Assistant
  - platform: homeassistant
    entity_id: weather.home
    attribute: temperature
    on_value:
      # Push it to the display
      then:
        - lambda: 'id(disp1).set_component_text_printf("temp", "%.1f ""\xb0""F", x);'
# Define some outputs
switch:
  # The two relays
  - platform: gpio
    name: $device_name Relay 1
    pin:
      number: 22
  - platform: gpio
    name: $device_name Relay 2
    pin:
      number: 19
  # Pin 4 always needs to be on to power up the display
  - platform: gpio
    entity_category: config
    pin:
      number: 4
      inverted: true
    restore_mode: ALWAYS_ON
number:
  platform: template
  name: $device_name Brightness
  unit_of_measurement: '%'
  min_value: 0
  max_value: 100
  step: 1
  initial_value: 30
  set_action:
    then:
      - lambda: 'id(disp1).set_backlight_brightness(x/100);'
# Configure the internal bleeper
output:
  - platform: ledc
    pin:
      number: 21
# Enable ringtone music support
rtttl:
  output: buzzer_out
# Configure UART for communicating with the screen
uart:
  tx_pin: 16
  rx_pin: 17
  baud_rate: 115200
# Configure the screen itself
display:
  - platform: nextion
    uart_id: tf_uart
    tft_url: http://192.168.1.182:8123/local/nspanel_demo.tft
    # A little fun...
    on_setup:
      then:
        - number.set:
            value: 30
        - lambda: |-
              "temp", "%.1f ""\xb0""F", id(current_temperature).state
        - rtttl.play: "twobits:d=4,o=5,b=220:c6,8g,8g,a,g,p,b,c6"
I have removed the wifi config just for showing my file.
Ted
i like that !
Hi Edward, the error is tha the url file must be between double quotes. Then it works very easily. A stupid mistake that cost me a long time to find out.
All the best, Felix
