circular slider for target temperature
https://youtu.be/KqFpyDbmm_E
ok circular slider is finished, goes from 0-28 C. all code is on GitHub, Iâve included the svg images too incase anyone wants a different background.
the code for the variable given for target temperature is in a timer within the hmi.
What is a yalm?
Or do you mean yaml?
Iâm sure itâs a typo and should be yaml
While it looks really cool, I could never understand circular sliders on the flat-screen. Itâs got to be the most user-unfriendly way of controlling the temperature, since itâs really hard to move your finger in a circle while seeing if you are actually doing something under that finger. It works wonderfully on nest, but thatâs because itâs not a touch-screen and control is outside of the area that displays progress.
Hello @jobraun,
thanks for sharing. I tried it following the instructions in your repo and ended up being stuck in the âwaiting for content, this is taking longer than usualâ screen. I have already double and triple checked my configuration files but cannot see where I made an error.
This is my appdaemon.yaml:
secrets: /config/secrets.yaml
appdaemon:
latitude: 52.0
longitude: 4.0
elevation: 2
time_zone: Europe/Berlin
plugins:
HASS:
type: hass
MQTT:
type: mqtt
namespace: mqtt
client_id: "appdaemon"
client_host: 192.168.0.39
client_port: 1883
client_user: !secret mqtt_user
client_password: !secret mqtt_password
client_topics: NONE
http:
url: http://127.0.0.1:5050
admin:
api:
hadashboard:
and my apps.yaml:
nspanel-1:
module: nspanel-lovelace-ui
class: NsPanelLovelaceUIManager
config:
panelRecvTopic: "tele/tasmota_nspanel/RESULT"
panelSendTopic: "cmnd/tasmota_nspanel/CustomSend"
updateMode: "auto-notify"
timeoutScreensaver: 20
#brightnessScreensaver: 10
- time: "7:00:00"
value: 10
- time: "23:00:00"
value: 0
locale: "de_DE" # only used if babel python package is installed
dateFormatBabel: "full" # only used if babel python package is installed
# formatting options on https://babel.pocoo.org/en/latest/dates.html?highlight=name%20of%20day#date-fields
timeFormat: "%H:%M"
dateFormat: "%A, %d. %B %Y" # ignored if babel python package is installed
weather: weather.home
pages:
- type: cardEntities
heading: Example Page 1
items:
- cover.rollo_wohnzimmer
- light.wohnzimmer_decke
- binary_sensor.bewegungsmelder_kuche
- sensor.bewegungsmelder_kuche
- switch.steckdose_flurregal
And hereâs what the information tab in tasmota says:
Can you or anybody else see what I made wrong? The nspanel is found in HA and all switches and sensors are working. HA receives messages on topic tasmota_nspanel that I send via my analyzer app and vice versa. Messages published on the topic in HA, can be received in the analyzer.
I seem to have a problem that I canât get some kind of info from Home Assistant to my NSPanels.
I removed everything and tried Christopher Mastos intro Youtube video (Flashing the Sonoff NSPanel with ESPHome - how to get a custom UI for Home Assistant! - YouTube)
But I canât get the temp on the screen, it just say nan F.
Could I have missed some configuration thing in Home Assistant or Nextion that should already been done?
This is now how my yaml look like, âsensor.temperature_158d000156d8c5â is my own Aqara Zigbee sensor
# Grab current temperature from Home Assistant
- platform: homeassistant
entity_id: sensor.temperature_158d000156d8c5
attribute: temperature
on_value:
# Push it to the display
then:
- lambda: 'id(disp1).set_component_text_printf("temp", "%.1f ""\xb0""c", x);'
all help I can get is appreciated
Problem solved! Spent hours researching until I came up with the idea of restarting AppDaemon, which helped. Thatâs just great, @jobraun! But even though I have multiple pages in my apps.yaml, scrolling through them is not possible. I keep getting stuck on the first page in the Tasmota console even though the console says that the button are being pressed.
13:53:28.484 MQT: tele/tasmota_nspanel/RESULT = {âCustomRecvâ:âevent,buttonPress2,cardEntities,bNextâ}
13:53:32.390 MQT: tele/tasmota_nspanel/RESULT = {âCustomRecvâ:âevent,buttonPress2,cardEntities,bPrevâ}
@Zahnweh Most likely youâve mixed up the development version of the display firmware with the current release in HACS.
Download the current main branch in HACS (Touching doesn't open cards. ¡ Issue #71 ¡ joBr99/nspanel-lovelace-ui ¡ GitHub) or flash the display firmware mentioned in the release notes of v1.7.3.
Just update in HACS to v1.8.3 and restart AppDaemon, just released v1.8.3
This did the trick! Thanks a lot! Also thanks for your great work!
entity_id: sensor.water_temp
on_value:
then:
- wait_until:
switch.is_on: nextion_init
- lambda: id(disp1).set_component_text_printf("Thermostat.hwtemp_txt", "%.0f", id(hotwater_temperature).state);
try this format @DariBer
Thermostat is the page name & hwtemp_text the text field.
Hi, can you please share your code? I use domoticz and I want to control
nspanel over the MQTT. Greetings
Is sensor.water_temp sensor of a temp sensor in your Home Assistant?
yes it is, use your entity id and obviously your page name and text field id
thank you @lovejoy777 for your help.
got it to work now, both the temp and status for my lamps and spotlights.
I didnât understand page_name.name_of_object in Nextion. When you described that, then I had a eureka moment
Do you know how this thing (bellow) works, it feels little random if the picture in the panel updates or not,
The status in my Home Assistant changes quickly for the lamp/light entity. I have right pic (int symbol) as it changes the picture, not all the time and feels randomly if it changes or not. has it something to do how often it getâs the updates from Home Assistant?
I have only done this config (and the nextion_init), do I need to change anything else
## LIGHTS ##
# Light window bedroom
entity_id: light.window_bedroom
on_value:
then:
- wait_until:
- lambda: |-
int symbol = 2;
if (id(first).state == "on") {
symbol=3;
id(disp1).send_command_printf("home.p_bed_window.pic=%i", symbol);
your config entry looks good do you have the on_press and on_release boxes ticked in the nextion editor? (highlight the button or hotspot, then in the bottom pane there should be the press/release command boxes, each has a checkbox).
edit: the update happens on state change with the code you posted so it canât be an update problemâŚ
Iâm out today but if you still have problems later you could upload your yaml and hmi file and i could take a look for you.
@DariBer
I have uploaded my him, yaml and also the tft file to GitHub
https://github.com/DariBer/NSPanel
Have a @lovejoy777 look and see if you can see any problems.
Thank in advance
like i mentioned, Iâm out for the next 7 hours so i will look for you then.
i am trying to flash esphome on this thing:
i have connected everything according to the âmanualâ, 3.3V, GND, TX and RX to 3.3V, GND RX and TX.
GPIO0 to GND.
But it is not entering bootloader. No connection in ESP home flasher. When i disconnect GPIO0 from GND, it starts correctly, as i can ping the ip adres of the device.
I completely removed the board from the nspanel, so the serial connection is not touching the metal
Anyone know what i am doing wrong?
