Sounds great. I will purchase one end of month One question. I think the Climate part will of course also be MQTT as I need this for my setup.I have a dumb AC which I control with a Xiaomi IR blaster . For the moment I have a custom flashed Controller Which also communicates with MQTT ā¦
This maybe a silly question, and Iāmsorry if it is.
Isnāt this just a Nextion display in there? Is there no way you can use the Nextion editor to create custom screen and then access those? Obviously way outside the scope of Tasmota, but if Tasmota can give you the frame work to intetact with the panel and you may be able to change the screens it opens up way more scope to play with it.
It should be possible. In esphome there is even a method to flash a new firmware on a nextion display. The problem at the moment is, that esphome will not connect to nextion displays that are in reparse mode.
I have not got my hands on a NSPanel yet, but I definitely plan to customize the display firmware and use it with esphome as soon as it arrives.
Itead = Nextion You are supposed to be able to use Nextion Editor to design your layout and then upload in screen (is possible with Tasmosta, not yet possible as far as I know with ESPhome) and then ESPHome interacts with panel to refresh display, switch pages, etcā¦ Have to play a little with NSPanel I have in hand to confirm you !
This Sonoff NS Panel seems awesome, although there seems to be some issues, especially with the feeling/feedback and size of the buttons.
I would have done it differently even though I understand that Sonoff wanted it to be squared 86x86mm (EU version) as regular switches.
I would have made those modifications like on this picture I have modified on paint
A. I would have chosen bigger buttons (40x32mm at least) and without borders, only to make them more easily accessible. The original buttons look like buttons of a laptopās touch pad, they are too tiny.
Quality switches with real feedback would be nice.
B. I would have used a cheap LED to indicate the state of the relay instead of using precious surface on the screen. The behavior of the LEDs should be adjustable over software of course.
And as said in some reviews, a distance or even a gesture sensor would be nice too.
I hope there will be an improved version in a year from Sonoff.
No beta anymore! Just use external_components: as described in the PR (see the example code provided). It will download the code and compile the firmware.
Just received my NSPanel and flashed it with the custom firmware from @blakadder - super simple process! - but now Iām at a loss how to update the buttons and sensors on it - is there a simple guide somewhere that I can use? - I was looking through Blakadderās Github, but I really donāt know where to start!
Should be the same you should get some switch circuits created for that in HA once linked with it, same for the two relays, temperature sensorā¦ After all config has to be done in HA for automations/actions/management of display !
So Iāve got it added into Home Assistant - but I canāt see any way to update the screens from Home Assistant itself - I can see from Blakadderās pages that you can fire commands at it - but they look like JSON rather than MQTT
