Sonoff NSPanel by ITead - Smart Scene Wall Switch based on ESP32 and custom Nextion Touch Screen Panel Display (non-Pro variant)
Thx a lot for your fast response/ I will give it a try this evening. I let you know the results asap
Donā€™t expect it to be easy :slight_smile:
Hi, @jobraun i am almost there.
i get this on the nspanel:
Waiting for contentā€¦
This is taking longer than usualā€¦
what have i missed?
check your appdaemon log, could be a wrong mqtt config in appdaemon, on tasmota or wrong mqtt topics in the apps.yaml
i get this on appdamon log:
2022-04-29 09:07:45.576366 INFO AppDaemon: Loading Plugin MQTT using class MqttPlugin from module mqttplugin
2022-04-29 09:07:45.587722 INFO MQTT: MQTT Plugin Initializing
2022-04-29 09:07:45.588089 INFO MQTT: Using ā€˜appdaemon/statusā€™ as Will Topic
2022-04-29 09:07:45.588336 INFO MQTT: Using ā€˜appdaemon/statusā€™ as Birth Topic
2022-04-29 09:07:45.589190 INFO AppDaemon: Initializing HTTP
2022-04-29 09:07:45.589910 INFO AppDaemon: Using ā€˜wsā€™ for event stream
2022-04-29 09:07:45.595882 INFO AppDaemon: Starting API
2022-04-29 09:07:45.601076 INFO AppDaemon: Starting Admin Interface
2022-04-29 09:07:45.601634 INFO AppDaemon: Starting Dashboards
2022-04-29 09:07:45.674097 INFO HASS: Connected to Home Assistant 2022.4.7
2022-04-29 09:07:45.737400 INFO MQTT: Connected to Broker at URL 192.168.101.109:1883
2022-04-29 09:07:45.773476 INFO AppDaemon: Got initial state from namespace mqtt
2022-04-29 09:07:45.775216 INFO MQTT: MQTT Plugin initialization complete
2022-04-29 09:07:45.777885 INFO AppDaemon: App ā€˜nspanel-1ā€™ added
2022-04-29 09:07:45.780709 INFO AppDaemon: Found 1 total apps
2022-04-29 09:07:45.782027 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2022-04-29 09:07:45.783918 INFO AppDaemon: Running on port 5050
2022-04-29 09:07:45.873932 INFO HASS: Evaluating startup conditions
2022-04-29 09:07:45.888349 INFO HASS: Startup condition met: hass state=RUNNING
2022-04-29 09:07:45.888929 INFO HASS: All startup conditions met
2022-04-29 09:07:45.986567 INFO AppDaemon: Got initial state from namespace default
2022-04-29 09:07:46.243988 INFO AppDaemon: New client Admin Client connected
2022-04-29 09:07:46.462905 INFO AppDaemon: New client Admin Client connected
2022-04-29 09:07:47.796679 INFO AppDaemon: Scheduler running in realtime
2022-04-29 09:07:47.823118 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2022-04-29 09:07:47.824290 INFO AppDaemon: Adding /config/appdaemon/apps/nspanel-lovelace-ui to module import path
2022-04-29 09:07:47.825232 INFO AppDaemon: Adding /config/appdaemon/apps/nspanel-lovelace-ui/luibackend to module import path
2022-04-29 09:07:47.851626 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hello.py - ignoring
2022-04-29 09:07:47.854688 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/nspanel-lovelace-ui.py - ignoring
2022-04-29 09:07:47.858892 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/pages.py - ignoring
2022-04-29 09:07:47.862255 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/controller.py - ignoring
2022-04-29 09:07:47.866408 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/helper.py - ignoring
2022-04-29 09:07:47.871676 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/config.py - ignoring
2022-04-29 09:07:47.875724 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/mqttListener.py - ignoring
2022-04-29 09:07:47.879126 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/localization.py - ignoring
2022-04-29 09:07:47.883338 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/icon_mapping.py - ignoring
2022-04-29 09:07:47.886366 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/updater.py - ignoring
2022-04-29 09:07:47.889725 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/nspanel-lovelace-ui/luibackend/icons.py - ignoring
2022-04-29 09:07:47.894031 INFO AppDaemon: App initialization complete
2022-04-29 09:07:50.239518 INFO AppDaemon: New client Admin Client connected
2022-04-29 09:08:55.922922 INFO AppDaemon: New client Admin Client connected
2022-04-29 09:17:11.433928 INFO AppDaemon: Client disconnection from Admin Client
2022-04-29 09:42:55.344274 INFO AppDaemon: New client Admin Client connected
2022-04-29 09:42:56.822032 INFO AppDaemon: Client disconnection from Admin Client
2022-04-29 09:44:18.699601 INFO AppDaemon: Reading config
2022-04-29 09:44:18.724514 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2022-04-29 09:44:18.725266 INFO AppDaemon: App ā€˜nspanel-1ā€™ changed
2022-04-29 09:44:18.728958 INFO AppDaemon: Found 1 total apps
2022-04-29 09:44:18.765362 INFO AppDaemon: Terminating nspanel-1
2022-04-29 09:44:18.771035 INFO AppDaemon: Initializing app nspanel-1 using class NsPanelLovelaceUIManager from module nspanel-406
2022-04-29 09:44:18.772333 WARNING AppDaemon: Unable to find module module nspanel-406 - ā€˜nspanel-1ā€™ is not initialized
mqtt initialisation looks fine, please add your apps.yaml and the mqtt config page from tasmota
nspanel-1:
  module: nspanel-406
  class: NsPanelLovelaceUIManager
  config:
    panelRecvTopic: "tele/NS-Panel-406/RESULT"
    panelSendTopic: "cmnd/NS-Panel-406/CustomSend"
    updateMode: "auto-notify"
    sleepTimeout: 20
    #sleepBrightness: 10
    sleepBrightness:
      - time: "7:00:00"
        value: 10
      - time: "23:00:00"
        value: 0
    locale: "en_GB" # used for translations in translations.py and for localized date if babel python package is installed
    screensaver:
      entity: weather.openweathermap
    cards:
      - type: cardEntities
        entities:
          - entity: switch.phota_salas
            icon: lightbulb
          - entity: light.led_bar
I have all flashed but the display keeps waiting for content. any idea what goes wrong? @jobraun
Here is de appdaemon.log
2022-04-30 19:38:36.266143 INFO HASS: HASS Plugin initialization complete
2022-04-30 19:38:36.267472 INFO AppDaemon: Loading Plugin MQTT using class MqttPlugin from module mqttplugin
2022-04-30 19:38:36.303008 INFO MQTT: MQTT Plugin Initializing
2022-04-30 19:38:36.304137 INFO MQTT: Using 'appdaemon/status' as Will Topic
2022-04-30 19:38:36.305097 INFO MQTT: Using 'appdaemon/status' as Birth Topic
2022-04-30 19:38:36.308075 INFO AppDaemon: Initializing HTTP
2022-04-30 19:38:36.310172 INFO AppDaemon: Using 'ws' for event stream
2022-04-30 19:38:36.329024 INFO AppDaemon: Starting API
2022-04-30 19:38:36.347118 INFO AppDaemon: Starting Admin Interface
2022-04-30 19:38:36.349238 INFO AppDaemon: Starting Dashboards
2022-04-30 19:38:36.403609 INFO HASS: Connected to Home Assistant 2022.4.7
2022-04-30 19:38:36.422168 INFO MQTT: Connected to Broker at URL 192.168.180.5:1883
2022-04-30 19:38:36.475944 INFO AppDaemon: Got initial state from namespace mqtt
2022-04-30 19:38:36.477788 INFO MQTT: MQTT Plugin initialization complete
2022-04-30 19:38:36.486646 INFO AppDaemon: App 'nspanel-1' added
2022-04-30 19:38:36.490644 INFO AppDaemon: Found 1 total apps
2022-04-30 19:38:36.493011 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2022-04-30 19:38:36.496851 INFO AppDaemon: Running on port 5050
2022-04-30 19:38:36.758376 INFO HASS: Evaluating startup conditions
2022-04-30 19:38:36.798804 INFO HASS: Startup condition met: hass state=RUNNING
2022-04-30 19:38:36.800786 INFO HASS: All startup conditions met
2022-04-30 19:38:36.956952 INFO AppDaemon: Got initial state from namespace default
2022-04-30 19:38:38.515300 INFO AppDaemon: Scheduler running in realtime
2022-04-30 19:38:38.524972 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2022-04-30 19:38:38.530528 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/hello.py - ignoring
2022-04-30 19:38:38.534108 INFO AppDaemon: App initialization complete
2022-04-30 19:38:40.549188 INFO AppDaemon: New client Admin Client connected
2022-04-30 19:51:29.412537 INFO AppDaemon: Reading config
2022-04-30 19:51:29.451226 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2022-04-30 19:51:29.452605 INFO AppDaemon: App 'nspanel-1' changed
2022-04-30 19:51:29.457049 INFO AppDaemon: Found 1 total apps
2022-04-30 19:51:29.470555 INFO AppDaemon: Terminating nspanel-1
2022-04-30 19:51:29.474557 INFO AppDaemon: Initializing app nspanel-1 using class NsPanelLovelaceUIManager from module nspanel-lovelace-ui
2022-04-30 19:51:29.476065 WARNING AppDaemon: Unable to find module module nspanel-lovelace-ui - 'nspanel-1' is not initialized
2022-04-30 19:51:29.479063 WARNING AppDaemon: Unable to find module nspanel-1 - initialize() skipped
apps.yaml
nspanel-1:
  module: nspanel-lovelace-ui
  config:
    panelRecvTopic: "tele/nspanel/RESULT"
    panelSendTopic: "cmnd/nspanel/CustomSend"
    sleepTimeout: 20
    sleepBrightness:
      - time: "7:00:00"
        value: 10
      - time: "23:00:00"
        value: 0
    locale: "nl_NL" # used for translations in translations.py and for localized date if babel python package is installed
    screensaver:
      entity: weather.weerstation
    cards:
        entities:
          - entity: switch.buitenlamp
            icon: lightbulb
          - entity: switch.woonkamerlamp
appdeamon.yaml
secrets: /config/secrets.yaml
appdaemon:
latitude: 52.379189
longitude: 4.899431
elevation: 2
time_zone: Europe/Amsterdam
plugins:
HASS:
type: hass
MQTT:
type: mqtt
namespace: mqtt
client_id: ā€œappdaemonā€
client_host: 192.168.180.5
client_port: 1883
client_user: ā€œtasmotaā€
client_password: ā€œsecretā€
client_topics: NONE
http:
url: http://127.0.0.1:5050
admin:
api:
hadashboard:
Found it. also have copy also the nspanel-lovelace-ui folder form github to apps folder
that a restart and worked
is it looking like this:?
yep, and the files in there.
i think i have the same settings but is not workingā€¦
@papakigr donā€™t change the module it has to be
Installing the app via hacs is exactly doing that, you can just install ist with hacs, no need to upload the files manually
That did the job!
Rhoots, I am very curious what you did/how you got your screen to upload. I have been trying for almost 4 days now but always get the same problem with the timouts and then available 1ā€¦18 returning 0x00. Iā€™d love to know how you fixed it!
Thanks!
@jobraun it rocks!!!
Works fluently!
I have an nspanel and have flashed esphome to it but havenā€™t really done anything else with it. I was wondering would it run on 12v? I have a place I could mount it but would only have a 12v power supply available.
Craig
@jobraun amazing work - your UI looks and works well thank you. Just a quick question, does your method support multiple nspanels? Would they all have the same UI or can I specify different layouts for different panels?
yes, just create multiple panels in apps.yaml
nspanel-1:
  config:
    panelRecvTopic: "tele/recvtopic1/RESULT"
nspanel-2:
  config:
    panelRecvTopic: "tele/recvtopic2/RESULT"
