Looks like you have the development version on your panel and the release in hacs/Appdaemon.
Rerun the flashnextion command with the url for the release version:
https://docs.nspanel.pky.eu/prepare_nspanel/#upload-berry-driver-to-tasmota
Hallo, danke für deine Antwort.
I think I’ve done the flashnextion at least 3 times in the meantime.
unfortunately no change.
I actually did everything the same as with the first panel, it works there
What is the URL you’ve used with FlashNextion?
EU Version:
FlashNextion http://nspanel.pky.eu/lui-release.tft
And this is my version:
and this is my other panel:
Hey, can you try with this version?
FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.9.3.tft
Looks like there went something from development into the release version of the tft file …
Hello, yes with the version it works
Thanks so much
I still have a question.
I indicated location DE on the display.
But will the date and day of the week be displayed in English?
What else could that be?
nspanel-1:
module: nspanel-lovelace-ui
class: NsPanelLovelaceUIManager
config:
panelRecvTopic: "tele/nspan_1/RESULT"
panelSendTopic: "cmnd/nspan_1/CustomSend"
model: eu
locale: "de_DE"
sleepTimeout: 25
sleepBrightness:
- time: "7:00:00"
value: 50
- time: "19:00:00"
value: 10
- time: "22:00:00"
value: 0
screensaver:
theme:
date: [255, 255, 0]
entities:
- entity: weather.forecast_home
type: 0
Install babel
https://docs.nspanel.pky.eu/prepare_ha/#add-babel-package-to-appdaemon-container-optional
Thank you
this correct?
init_commands: []
python_packages:
- babel
system_packages: []
log_level: info
yeah looks fine
Eu, US portrait and US Landscape
can anybody post a example with type: screensaver2
i cannot find out, how to use it
Here is an example that I found
config:
panelRecvTopic: "tele/tasmota_debug/RESULT"
panelSendTopic: "cmnd/tasmota_debug/CustomSend"
sleepTimeout: 20
sleepBrightness: 40
screenBrightness: 100
dateFormat: "%A, %d.%m"
screensaver:
type: screensaver2
entities:
- entity: weather.demo_weather_north
- entity: sensor.outside_temperature
type: 1
type: 2
type: 3
- entity: sensor.total_gas_m3
- entity: sensor.carbon_dioxide
- entity: sensor.today_energy
- entity: light.bed_light
icon: mdi:bed
- entity: light.kitchen_lights
icon: mdi:fridge-outline
- entity: light.office_rgbw_lights
icon: mdi:office-building
- entity: switch.ac
icon: mdi:home-thermometer
- entity: fan.ceiling_fan
doubleTapToUnlock: True
statusIcon1:
entity: switch.decorative_lights
statusIcon2:
icon: "txt:test12345"
What I don’t know If I don/'t want an area filled in and want to go to the next one if that is possible?
found ```
- entity: delete
i have a couple of local stations that have an mp3 stream, that i want to be able to start playing on my google home through the nspanel. How do i add them?
in Lovelace i have this, but i want them also on the nspanel
type: custom:mini-media-player
entity: media_player.googlehome6691
icon: mdi:radio
artwork: cover
info: short
source: full
sound_mode: full
shortcuts:
columns: 4
buttons:
- type: music
etc
Yes, you can configure the entire bottom row with entities.
You can use this in combination with this:
Calling service directly as button
- type: cardMedia
title: Kitchen
entity: media_player.kitchen
entities:
- entity: service.light.turn_on
icon: mdi:lightbulb
entity_id: light.schreibtischlampe
color_name: "green"
You just need to do it with whatever service needs to be called to play this music on the player.
If you can provide an example I would like to add it to the documentation.
What do you mean example?
I basically want 4 buttons to start 4 different mp3 streams, with different icons
for the service that you need to call to start that stream; the example I posted is for setting an lightbulb to green isn’t exactly what you want to do, but shows how to configure it
Okay third pizza on the way - what a wonderful job you are doing. 7 panels running down under in Vic - how stocked am I. My friends see a useful panel,
Anyway a minor issue the second icon is not showing inside the box. For me only need 1 decimal place though would love to be able to use a Template i.e {{sensor.xyz | round(1) }}
type: cardPower
title: Home Power
key: homePower
sleepTimeout: 0
entities:
- entity: sensor.pv_daily_yield
icon: mdi:home
speed: -20
color: [255, 255, 0]
icon: mdi:solar-panel-large
speed: -20
- entity: delete
- entity: delete
- entity: sensor.modbus_sma_pv_power_kw
speed: -10
- entity: sensor.white_goods
speed: -20
icon: mdi:fridge
- entity: delete
- entity: delete
- entity: delete
